We’ll see how excited you are about an iPhone with wireless charging once you see how much we’re going to charge you for it. WE’LL SEE…
— not Jony Ive (@JonyIveParody) February 13, 2017
In the medium term, Apple could try to establish wireless charging as a standard, and thus abolish the last physical interface. However, this step requires more courage than simply killing off the USB Type-C port.
...in practice, it’s a flop.
No problems here
My 2 cents
Peace 🖖
haha nice trick you got
The basic question is: What are the advantages of wireless charging? I can think of two. First, no repeated plugging and unplugging of the USB cable, which might damage the port. Second, the ability to charge the phone where it's not possible to keep it near the power supply. That is, if the power point is at a location in the room where it's not possible to attach your power cord and keep the phone, wireless charging comes in handy.
Next, the refutation of these two advantages. From my experience, the USB port outlasts the mobile phone. The situation where your phone USB port is malfunctioning due to repeated plugging and unplugging of the power cord, yet your phone is functioning flawlessly, is rare. The solution to the second point, is to simply use a power bank where it is inconvenient to bring your mobile close to the power point.
So, goodbye wireless charging. It's one of those important landmarks of technological innovation that prove ultimately useless yet serve to mark what aspects of our daily lives could REALLY be improved by technology.
Good post
Its to slow for charging when we have fast charging on phones
It was never an important selling point or well implemented technology.
I use my wireless charging on my S6 at work. It's a lot more convenient for me.
