How to get Android 5.0 Lollipop on the Galaxy Note 3
The official Samsung firmware for the Galaxy Note 3 has been pushed out OTA across the US, bringing Android 5.0 Lollipop to the device. But you can install Android 5.0 on your Note 3 manually if you need to, by following our tutorial below.
How to update Galaxy Note 3 to Android 5.0 with Kies
The easiest way to install the update is by using Samsung Kies. Download the latest version of Samsung Kies on your computer and connect your Galaxy Note 3 with a USB cable. Kies should notify you that there is an update available. Then you simply follow the steps to install it.
- Buy Now: Galaxy S3 from AT&T | Amazon.com | Amazon.co.uk
How to install Android 5.0 Lollipop on Galaxy Note 3 with Odin
If Kies doesn't let you update the Android 5.0 firmware, you can flash it manually using Odin. Here's how to do that.
Note: the Android 5.0 Lollipop firmware, build number N900XXUEBOA5, is official Samsung firmware for the Galaxy Note 3 LTE, SM-N9005. While the firmware is Polish, it will also work on any international Note 3. Attempting to flash this firmware on carrier-branded Note 3's may cause problems, so we don't advise it.
As always, manually tinkering with your device has risks involved. Please be aware of them before proceeding.
Prerequisites
- Download Samsung drivers
- Download N900XXUEBOA5 firmware for the Galaxy Note 3 SM-N9005
- Download Odin v3.09
- Charge your battery to at least 80 percent
- Enable USB Debugging in Settings > Developer options (in case you need to troubleshoot later)
- Back up your essential data for safe keeping
Install Lollipop on Galaxy Note 3 instructions
1. Unzip the downloaded firmware zip file on your computer.
2. Launch Odin.
3. Reboot your Galaxy Note 3 in download mode (Volume Down + Power + Home).
4. Connect your Galaxy Note 3 via USB cable to your computer and wait for Odin to recognize it (a blue box should appear next to ID:COM).
5. Make sure only Auto-Reboot and F.Reset Time are checked in Odin.
6. Make sure Re-Partition is not checked.
6.5 If you're experiencing an ext4 error message, you need to download the correct PIT file for your device (Google your model number and "PIT file" to find one). Then check Re-Partition, click on the Pit tab and then the PIT button and locate the file. Then continue.
7. Click the AP button and locate the tar.md5 file in the unzipped firmware file and hit Start.
8. Wait patiently until the procedure ends and do not disconnect your Note 3. It may take a while.
9. You should see a green PASS message when successful.
10. Once your Galaxy Note 3 restarts, you should be running Android 5.0 Lollipop.
Now you can restore any backed up data. If you get stuck in a bootloop or encounter some buggy behavior, reboot your Note 3 in Fastboot (press and hold Volume up + Power + Home) and use the volume keys to navigate and the power button to access recovery mode. Clear the cache partition and then reboot.
If you have any major bugs at startup, do a factory reset on your Galaxy Note 3 from recovery mode and then restore your data again.
How do you like Android 5.0 on the Note 3? Why do you think the Note 3 beat the Note 4 to Android Lollipop? Share your thoughts in the comments.
Installed lolipop some error including app appear on top permission.
Bought a Note 3 in Spain and it came with android 4.2.2
Since i'm from the Netherlands the update to android 5.0 didn't appear...
Tried and searched everywhere and I didn't find a way to install lollipop the normal way so i got my stuff together and used the Odin Turtorial to install it on my device.
I must say the first tries didn't work and i almost bricked my Phone, but I didn't gave up and also needed to find the proper PIT file and eventually it worked!
However the Phone kept hanging on the samsung logo at first boot, so first wiped the cache and rebooted.. didn't work..
So I chose for the factory reset option and BOOOM! there it was!
I'm using it for one day now and all my problems (like connection and OTG cable didn't work) are gone!
Super stoked right now so a BIG thank you for the clear and easy how-to !
Is it works for Samsung galaxy Tab 3 ?
Hi All, There is no tar.md5 file. Please help me.in Which folder it is available. my mail id is rajamk@gmail.com
Hello I have just tried this method on Note3 N9005 and got stuck with many errors. But after spending all night finally done it. If anyone is facing errors in ODIN then I will be happy to help you for free. (m.bilasarfraz@gmail.com)
No Error But Downloading All Day? A Little Bit Frustrating....
<ID:0/011> SetupConnection..
<ID:0/011> Initialzation..
<ID:0/011> Get PIT for mapping..
<ID:0/011> Firmware update start..
<ID:0/011> SingleDownload.
<ID:0/011> aboot.mbn
<ID:0/011> NAND Write Start!!
FROZEN HERE ALL DAY!!!! :( :( :(
Mine failed, just keeps going round and round....what. tar file should i exactly use?
many many many many thanks admin its works fine on my SM-9005 wifi and others things r also works fine thank u again
I am getting an error message saying Complete(Write) Operation Failed.
all Threads completed, Succeded 0/ failed 1
Thank you it worked and I most grateful
really helpful.. thanks a ton
I am really surprised at the number of Note 3 users who haven't been updated to Lollipop yet. Shame on you Samsung!!! My hope is that Samsung will have a heart and upgrade ALL Note 3 users to Marshmallow in the new year.
Please could you help me, I followed the procedure step for step and it faild. Here is the error log, please help!
<ID:0/006> Added!!
<OSM> Enter CS for MD5..
<OSM> Binary Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/006> Odin engine v(ID:3.1100)..
<ID:0/006> File analysis..
<ID:0/006> SetupConnection..
<ID:0/006> Initialzation..
<ID:0/006> Get PIT for mapping..
<ID:0/006> Firmware update start..
<ID:0/006> SingleDownload.
<ID:0/006> aboot.mbn
<ID:0/006> NAND Write Start!!
<ID:0/006> boot.img
<ID:0/006> cache.img.ext4
<ID:0/006> hidden.img.ext4
<ID:0/006> FAIL! (Size)
<ID:0/006>
<ID:0/006> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Seems somethings wrong with "Firmware"make sure you have downloaded the correct one as per phone model. I'm sure you have solved the problem, would mind if share how did you overcome this error?
Hi frds I am not getting new android update for note 3 32gb pls help me out
Just updated my 32gb version succesfully. So far everything works just fine. Thanks for the links :)
- South Africa!
After flashing the stock firmware, my wifi doesn't work. It doesn't even start.
Any suggesstion?
It is awesome, only drawback is that passwords for wifi are not saved, have to enter them every time i connect with any network.
Hi ,will i still be able to use knox?
Today after waiting long time for Lollipop OTA update, I manually updated the polish version. Instructions were easy to follow and process took only 15 minutes to update. Update working well up till now and I am very happy to have active LTE network selection option. I bought Note 3 SM-N9005 only to use LTE in Pakistan and after purchase I found that I have to wait for an update in order to use LTE (Samsung Sucks) though I was still able to use LTE by manipulating some codes. After waiting a long time today I am able to use this bloody LTE service.
This worked good on my 32GB version! I got my Lollipop update from Mega (remove space):
https: //mega.co.nz/#!qk12UYYB!4fg39KkeatkTtcShS4rUljWpU1rGnMC9XL3C17z8Crk
Also, the first boot takes like 10 minutes. It isn't a bootloop. Just so ya know.
Odin download link is busted.
Mike you can search for the same odin version on Google and download. I did the same and it worked.
Deutsch
Dieses update funktioniert und hat mein Note 3 erfolgreich auf Android 5.0 Geflasht
Bevor ihr dieses update/neue Android Runterladet informiert euch bitte ausreichend über Odin wenn ihr es mit Odin machen wollt
Es ist eigentlich esay
LG Simon
PS:ich bin 16 :D und habe es hinbekommen ....
Viel Glück
thank you. works like a charm.
Thanks worked a treat for me all updated even kept all my info and apps in the same place.
I have followed until step 7, then got error...Invalid ext4 image. Now stuck cannot even get back to previous system..
I have SM-N9005 - 16GB Hongkong will this update work? can I use the same steps? please let me know.
mine odin stoped at nand write statt!! , pls what am i going to do
Mine stops at "NAND WRITE Start!!" for a long time is it suppose to do so?
I have installed 5.0 successfully in my SM-N9005,
Now my phone belongs to polland region g
From UAE , My question is , will i get any further official update from phone "software update " without any probes ?
successully installed the lollipop firmware. u need to set note 3 in download mode i.e vol down+powr+home button until android logo came up. then press vol up. i notice 2 features do not work: air command n clock for s view. any suggestion? my region is Malaysia.
will android 5 update work on note 3 n9005xxugng1?
I did follow the step but nothing happnd. I did it with another video tutorial. Mine runs now on lollipop nd it too cool
Let me help u brother
Be sure to run odin as administrator. Right click on the application > Run as administrator. Let me know if this works for you.
i did the same process as u requested but it says FAIL ... i dont understand. i also installed the same odin 3.09 version instead of 3.10 ... and whats the purpose of samsung usb driver that u have mentioned cz i dont see any use of it. please reply. thanks
i try to install the rom but after adding files and press start get fail message please advise
there is no tar.md5 file in the unzipped firmware
only nandroid.md5.
