Huawei EMUI 8: Definitely not the evolution we were hoping for
AndroidPIT huawei mate 10 pro review 1885
Huawei is one of the first manufacturers to have an Oreo-based smartphone in its portfolio with the Mate 10 Pro. Its customized EMUI 8.0.0 will also be rolled out to other Huawei smartphones, bringing new features along with some quirks that we will take a closer look at below.
Android 8.0 itself brings numerous improvements that make it much easier to work with your smartphone. The first improvement that deserves mention is automatic form filling followed by changeable icons with context menus, Picture-In-Picture, improved Bluetooth, app links for highlighted text massages, support for multiple displays and theme preparation using Substratum, all of which are some of the benefits of this major update. However, it’s up to manufacturers, like Huawei, to implement these functions in their variants.
huawei emui 8 home
EMUI 8 looks a lot like EMUI 5./ © NextPit
EMUI 8 is the successor to EMUI 5.1
Huawei is skipping a few version numbers, making it seem that the Android and EMUI versions are now the same. Both Android and EMUI version 8.0.0 are running on our review devices, the Mate 10 Pro and Mate 9. Whereas Android obtained some new features when updating from 7.1 to 8.0, the jump from EMUI 5.1 to 8.0 was not such a major one. Au contraire, Huawei hides some of the new Android features or implements them in an incomplete manner.
Context menus are available, but hardly given attention
First and foremost, anyone hoping for a comprehensive facelift of the Huawei interface from the version jump will be disappointed: EMUI 8 looks like EMUI 5 at first glance (and at second glance, too): Huawei made no changes to the user interface. You may stumble across the new context menus in the app icons; to do so, press and hold the app icon for 300 milliseconds.
huawei emui 8 app starters
Huawei’s telephone app does not offer any useful shortcuts, other than perhaps WhatsApp./ © NextPit
A comparison between third-party apps such as Twitter, WhatsApp, or Inbox and a Huawei app like the telephone reveals that Huawei is not taking advantage of this feature: Instead of placing you favorite contacts in one or two of the entries, you get a deep link to the app’s favorites section as a sort of consolation. In any case, the context menu entries can be individually placed as shortcuts on the homescreen, even if this hasn’t been made clear.
App Fill: You can only fill with Google
Huawei’s initial implementation of the autofill API seems flawed. The choice of autofill service does not appear in the settings’ search function and you manually need to look for it instead; it is located in both the default apps and input method menus. For some reason, third-party apps such as Lastpass do not detect that an Autofill API-compatible Android version is being used and thus, you are stuck with either Google’s Autofill service or none at all. Huawei still hasn’t fixed the error, even after two updates for the Huawei Mate 10 Pro.
huawei emui 8 app fill
Full-text search is worthless: Go through the menus manually if you want to find something./ © NextPit
Quirks and features
EMUI 8 is still new and requires quite a number of updates until it is mature. When the Mate 10 Pro review was completed, the software was newly updated to version 8.0.0.111(C432) and therefore ran smoothly. In contrast, the next and still latest update to version ~115 brought about numerous problems.
Since the update, notification pop-ups have almost always caused the user interface to freeze, which already made me miss an incoming call. The alarm failed numerous times, which is a problem that Sophia had also observed with the Honor 8 and EMUI 5. It seems as if Huawei alternates between releasing features and then bug fixes.
AndroidPIT Honor 8 2614
The Honor 8 was quick, but the software was annoying. / © NextPit
In addition, the EMUI interface in some ways behaves annoyingly different from the Android standard: If you install a third-party launcher, you first need to go out of your way and enter the default apps menu to activate it. Nearly every other manufacturer’s Android interface lets you select the new launcher simply by pressing the home button.
These baffling software decisions even extend to parts below the interface: Huawei once again foregoes the A/B partition system for background system updates that was introduced in Android Nougat, which is annoying since the smartphone’s initial system updates put it out of commission for quite some time. The A/B system would reduce the process to a conventional restart that hardly takes a minute.
But a lot has currently changed for the better; one such example is that you can finally use the fingerprint sensor with a pattern lock. And as a consolation, Huawei offers Phone Clone, the only good 1:1 backup feature on the market for Android smartphones, as long as both devices are from either Huawei or Honor. However, we had already praised this feature in an older article on EMUI 5, in addition to numerous other EMUI features that are still there:
Verdict
In light of all the criticism, I have to hand it to Huawei for significantly improving their software like no other manufacturer has. However, when adapting the interface to the world market from the Chinese market, minor mishaps occurred. On the top of that list were the missing notifications, since EMUI’s automatic battery saver system had automatically killed the background processes of chat apps, but you can now control this manually.
Nevertheless, the remaining day-to-day defects are consistently annoying and prevent me from unconditionally recommending these otherwise outstanding devices.
Which EMUI quirk do you think Huawei urgently needs to change? And which feature do you think is great and would make you want to keep buying Huawei or Honor devices?
Go to comment (5)
Eric Ferrari-Herrmann
5 comments
  • 48K Dova 1
    48K Dova Sep 27, 2018 Link to comment
    I'm disappointed... HUWEI... NEVER MORE
  • 48K Dova 1
    Is there any chance of getting rid of that EMUI shit? I bought this phone P8 lite about a month ago... And already asked me to actualize to EMUI 8.0 and 2 days after is asking to download 8.1...well I hate this EMUI system.... First like ASUS its impossible to root... At at least with king root and similares... Now this 8.0 EMUI shit turned my super fast phone in a wheel chair.... It's any way I can get ride of this crap and use just the the android SO... and by the way this 8.0 shit freezes my phone and that never happen
    Luka rogošić Jul 15, 2018 Link to comment
    I have Huawei p10 lite and I upgraded to EMUI 8 (C432) and I have a problem with network
    Not only internet but whole network
    It just turns off sometimes and to fix it I have to turn on airplane mode and turn it off
    It's not a hardware problem because phone is 7 months old and it never touched a ground and it worked perfectly day before the update
  • Matthew Hymer 2
    Matthew Hymer Nov 16, 2017 Link to comment
    I've had the Huawei Mate 10 for a week now and here are my list of problems (115/C636):
    Widgets not refreshing (really annoying, especially for BBC News & Sport which I rely on)
    Homescreen and notification shade scale much larger than on EMUI 5.0/Mate 9 (think the overall view mode is missing a "smallest" setting? Feels like screen real estate is being wasted anyhow)
    Cannot delete/archive Gmail emails from notification shade (button is there, but does nothing!)
    On the plus side, screen/camera are definitely a step up from Mate 9. And I also love having the finger scanner on the front and have quickly got used to controlling the user interface with it (no on screen buttons anymore!)
    Audio with earphones outstanding, external speakers as loud as Mate 9, overall build quality superb - as always with Huawei!
    Just praying for a software update to sort out the niggles and this phone will be perfect.
  • Iqbal Hossain 9
    Iqbal Hossain Nov 16, 2017 Link to comment
    I have seen the post and was very much excited. But it disappointed me. This kind of updates is not worthy at all. I don't find anything that much upgraded here.... :/
    48K Dova
