NextPit
The battery revolution is up and running
AndroidPIT Smartphone Overheating 2588
© NextPit
It isn’t always easy to be objective when discussing smartphones. Some people prefer one kind of design over another, some like TouchWiz while others prefer stock Android. Some want a very powerful smartphone, while others simply want a device to chat on WhatsApp with. There is, however, one area in which everyone is in agreement: the battery life of a smartphone is never enough and must be improved on. An American study offers a solution. It's only experimental at the moment, but looks very promising.
NEXTPITTV
Heading toward end of lithium-ion batteries?
We know that the batteries currently used are lithium-ion and that, up until now, the only way to increase their capacity is to increase the size of the battery. In other words, the larger the device, the more it is possible (at least in theory) to use a larger battery, but with an equally larger screen, the power consumption also increases so the benefits are not really noticeable. Of course, software optimization improves the battery life, but only up to a certain point.
The University of Central Florida has made a discovery that could revolutionize the field of electronic equipment: a supercapacitor that can store much more energy than a battery, and function just as well after 30,000 recharges as it did on its first use! The researchers claim that not only will it be possible to fully charge a smartphone in a few seconds, but also to provide it with enough power to last for at least a week.
AndroidPIT Smartphone Overheating 2583
Does this discovery spell the end of traditional lithium batteries? / © NextPit
Better capacity and faster charging time…but not yet!
This is not ready yet though. The technology is far from simple and it will take a while before it is fully tested, accessible and the manufacturing processes probably need to be streamlined. The material used is graphene which is, by definition, very thin and heats extremely slowly, providing a clear technical advantage. The key to success with this kind of battery relies on the technology: the tube format prevents problems similar to those seen in traditional bi-dimensional forms.
It will still take a long time before they are fully tested
Thanks to their innovative materials integration process, it will have more cyclic stability, meaning that it can be recharged much more often. Graphene is highly conductive which helps the electric current to move more easily, that means the recharging time is much faster.
Which are you more excited about?
View results
The research leader, Yeonwoong Jung, has emphasized that the technology is not ready for commercialization, but that this study will have a "very high" impact on many technologies.
What are your battery expectations? Would you invest more money in getting better battery life?
Article written in collaboration with Luis Ortega.
Join the discussion
6 comments
  • Mansoor Bozdar Dec 18, 2016 Link to comment
    How is the battery of Samsung galaxy j5 (16) and how i safe it more
  • Shane Davis Dec 10, 2016 Link to comment
    The battery Companies are the ones funding the research into grphene batteries. When the time comes it will be a very controlled release. Believe that. And these batteries will probably be sold separately and be expensive I'm sure.
  • Nisha Patel Dec 9, 2016 Link to comment
    The battery companies will be crapping themselves if this is allowed to come out to market!
  • rick Dec 8, 2016 Link to comment
    just make thr phones a little thicker, instead of longer and wider. then they can put a thicker battery in them . just because they can make a phone dime thin, dosnt make it practical.
    • Reg Joo Dec 8, 2016 Link to comment
      If they're gonna make it dime thin, it's time to use something else. This problem reminds me of Moore's law, and the limitation of silicon, sooner or later they gotta use something else. The clock is ticking on these technologies.
  • Andrew Burgin Dec 7, 2016 Link to comment
    How many times do we get promised new type of batteries and they never get made available, its just amazing with all the modern technical projects, that no one as been able to solve the battery problem for PCs or Phones
