Android Lollipop tips and tricks: Get the most out of your device
Android Lollipop was launched back in 2014 and is available on many Android devices. To help you get the most out of your handset, here are some of the best tips and tricks for Android Lollipop – and they might help you avoid some of its problems, too.
Quickly access more settings
You can get access to more options in your notifications bar. Instead of swiping down with one finger, twice, try swiping with two. This shortcut will bring you immediately to your quick settings menu, where you can adjust your brightness and access Wi-Fi options, among other things.
Optimize your lock screen security
Android Lollipop comes with a variety of lock screen security options. You can choose from the classic pattern, PIN, password or fingerprint reader (so long as your device is equipped for it). Whatever device you have, make sure you choose to secure your device against unauthorized use.
Getting to your security settings in Android Lollipop is easy. Go into Settings and tap Lock screen and hit Screen lock, which should appear at the top (for some, it will be in the Security settings). From there you can choose between the different options. It's recommended that you choose the PIN or password option because they are the most difficult to crack. Swipe is easy to figure out as someone glancing can easily pick up your pattern.
Customize your lock screen
Speaking of your lock screen, you can also customize it to your liking on many Lollipop devices. Go back into your Lock screen from the Settings menu. From here you can choose between a number of different items you want on it.
On Samsung TouchWiz devices, for example, you can choose what kind of clock you want by tapping on the Clock size and Dual clock settings. The Clock size menu is pretty self-explanatory. In the Dual clock settings you can choose whether you want the phone to display the local time along with your home time when you're roaming. You can also choose whether you want the date under the clock.
You can get a camera shortcut in the lock screen if you take a lot of pictures and don't mind if the device is unlocked first. You can get weather information too by checking the box. If you want more time before your phone locks you can tap Lock automatically and choose another duration. You can also choose whether the phone will lock automatically by checking the Lock instantly with power key box.
Put Chrome tabs back in Chrome
This isn't a huge problem — and maybe you like having your Chrome for Android tabs spread across your recent apps stack rather than in the browser — but for me, it's an irritating default setting.
Fortunately, all you need to do to get your Chrome tabs back to their rightful place is to go to Chrome settings and disable Merge tabs and apps. Your Chrome tabs will now be accessible via the traditional button on the URL bar in the Chrome browser.
Ditch that dead Email app
For some odd reason, Google decided to keep the now useless Email app in Android Lollipop. When you launch it for the first time, you'll get a splash screen that tells you Gmail is now handling Email services, and you can check the box to launch Gmail instead.
But why do that and have a hollow app sitting in your app drawer? Go to Settings > Apps > All tab, find Email and disable that useless waste of space. Your emails will still be handled by Gmail but you won't have the dead app icon cluttering up your precious app drawer.
Make your battery go further
Android Lollipop comes with a new battery saving modes. For most devices you just need to go to Settings tap Battery hit the menu (the three dots at the top right of the screen) and choose Battery saver. You will save battery as a result.
If you have a Galaxy S5, HTC One M8 and a few other devices you have a new power saving mode. Just go to your Settings and tap Power saving. From here you can toggle Power saving mode. You can also activate Ultra power saving mode to really save your battery.
What other Android Lollipop tips and tricks do you know about? Tell us in the comments below.
I have an Excelvan D6 smartwatch, actually, a stand-alone phone. It is a label engineered No.1 device with an Excelvan version of the operating system loaded. It is running Android 5.1.
Naturally, it is cut down to some extent, but there is no idiot's guide on running this system in this, or any other smartwatch I know of.
It is a pain to have to thumb through the index page to find the phone and contents list to make a call, and the ok google software had to be downloaded, and the version I got seems not to work correctly, or am I just stupid?
This is a nice smartwatch, but setting it up to be user-friendly is a pain.
Is there anyone out there who knows of a good idiot's guide, or is prepared to write one?
How do I leave a text note on my lock screen like my email or alternate phone number in case I lose my phpne?
I am using Android 5.0.1
Thanks!
In Settings, tap Security then Owner Info
Just put it this way: Lollipop is real crap. My phone shuts down itself, resets to January 1st 1970 when restarted, WiFi turns itself on, camera storage settings go back to internal storage instead of SD card on restart or after shutdown. Of course, needless to say it is after factory reset to try to get rid of these bugs. I was before on Jelly Bean, it was soooo much better!
That was good article.. thanks.
Michelle
What I have is a 5.1.1 so I can't tell if it works the same. But I do know apps like BOA, PayPal, CapOne360, Express Script don't work with lollipop.
The other thing that is bothering is the fact that the only thing I can save on my SD are photos and videos. Great if I could transfer from Google photos but not allowed therefore is taking too much space. No good. ..
Iraida, I can not use my wells fargo app with my kitkat. it tells me I need 5.0 to deposit checks with my phone. this is the reason I am trying to update. you say there are apps that dont like the 5.0 that liked the kitkaty? do you mind telling me which ones?
For an upgraded version I was please but at the same time confused. Why is it that so many apps are not compatible with this version when my previous v 4.4 worked fine. If something is works don't break it, just improve what needs to be done. I missed Inbox instead of Gmail and apps like Bank of America, just to mention one within others that I like and is not compatible with this version. ?
"Ditch that dead email app"?! What a silly remark. I had always used that app for any email accounts that weren't Gmail. It certainly wasn't a dead or useless app to me!! As for allowing Google to handle my other private accounts, I am not comfortable with that! This is yet another example of Google showing their ugly side, taking away a person's choice, as well as forcing you to use their apps or services instead of someone else's.
I already knew this stuff but "Ditch that dead Email app" killed me. I use the Email app for my Outlook/Hotmail account.
nice article but I already know these stuff..
Pinnin is useless because if someone tries to exit the screen they are on a message comes up telling them how to unpin....totally pointless. Defeats the purpose of pinning in the first place. I cant see any option anywhere to lock it with a swipe pattern or pi number. Also stellarium stopped working after i updated to lollipop. And why does lollipop have a white background all the time..battery lasts nowhere near as long as it used to on kitkat..im not happy with lollipop at all..so far the only advantage o have seen in lollipio is being able to use apps that dont work with kitkat..this is the only reason i switched to lollipop. I was running kitkat till last week.
Darren: In Settings, Security, Screen Pinning, turn the "require unlock" toggle off, then on again. If you have a pattern, pin, password, it will require that to unpin; or will ask you to set one. Voila, now someone unpinning an app has to provide the unlock key.
There's a bug that you have to disable, and reenable, the lock option for it to take hold if you have it enabled (as I did).
When I updated my moto g to lollipop it screwed my phone up to where the battery all of a sudden will show 83rd dead and shut off, plug it in and it might show 30% to 100%. 5 min or so it'll beep that it's got 5% again. I have factory reset the phone and wiped the catch partition several times but that's not working. Please help!
And yes it was an actual update sent by the manufacturer, it's not rooted and I didn't try and flash lollipop on.
William, I had the same problem with my Moto G when it upgraded to Lollipop. The way I fixed it was to recalibrate the battery. You need to let it go totally flat to 0%, then recharge it to 100%. That's what fixed it for me, hope it helps you too. I now have a new Moto X Style, and I'm in no rush to upgrade to Marshmallow for fear of having similar problems again, Lollipop is okay for now. Good luck William.
Pull tab, for multi window missing. Anyone else experiencing this? Could this be a lollipop problem?
Where is Trusted Faces in Lollipop 5.1.1, or is that just a 5.0 thing. Note 4 UK (O2)
screen pinning is not available on the Verizon S4 Lollipop update.
you should post tips and tricks about rooted phones....come on man grow up u have already given a few year to these normal things....this is ur every year article
Thanks for the article. Netflix app, Hulu, or BBC is great on Android. If live outside USA, you can use tools like UnoTelly to get Netflix on your Android.
Thanks.. nice info...
I've just got (after what seemed like a very long wait) a Umi Hammer S. I like it so far - but it won't download the PayPal app - 'not compatible with this device' or the eBay sniper - and a helpful contact there suggested the Beta version but that looks clunky. I had no problems on the HTC One so can only presume it's the Lollipop?
Anyone any helpful ideas for someone not very techie, but with a son who can when he's around?
Try searching for 1mobile market app in your phone's browser,you will have to tick allow apps fro unknown source option in security settings, and then download and install 1 mobile market app and then search for PayPal app
I must be in the minority, I actually like the native email app. It runs faster than the gmail app for me.
i have installed lollipop 5.0.2 on my samsung a5.but he cannot show battery option in setting
plz help me
I just bought a Elephone P8000, but i having problems :
How to do to use Flip silence ?
How to do to reject private numbers ?
Paulo
I am using Lenovo A-6000plus. I got updation of 5.0.2, after updation my contact list is not readable by any of app like Trucaller, Whats App and even phone dialer, it behaves like I don't have any number in my phone book....what to do...?
Settings -> Backup & reset -> enable all the options and then "Factory data reset" the phone.
By the way thanks. Learnt a lot from this. Thank you so much
Hi, i have a LG L90, now over 1 year old. Since the up-date i have been having problems with google. Depending on how i tab the screen I will go to rhe google starting screen. Witch is not a problem when the wifi is on, when it's off, I have to restart the phone or it will be stuck on pop-ups saying i have network problems.
My Samsung S5 doesn't have the Battery Saving settings mentioned, only the ability to switch on "Power Saving" or "Ultra Power Saving" .
Also doesn't have the "Screen Pinning" option. **edit: found it! **
Email app was one of the 1st disabled. (though I could see a use if I was using multiple email accounts).
Cloud magic, multiple accounts
There is new AppUseFree app on qooqle play only for lollipop. Android app that allows you to monitor and get real time views on how much time you spend on your smartphone. You will see detailed applications usage time history for unlimited time.
My Samsung Note 4 (and prev Galaxy S3) do not allow me to disable the stock Email app.
The email app is not useless. I use it everyday for my corporate email and my gmail app for my Google mail and I like that separation. I think you provide a very narrow review when you state things as being "useless" either because you don't see the value or it doesn't have a place in your regular day to day. Just because you don't use it doesn't mean no one else uses it.
The email app is in useless on stock android 5.1.1.
The best tip is to actually have lollipop ! My Nexus 7s last OS update was the Ten Commandments !!!! ?
Excellent humour Jeff!
great!informative read!
