Lucy Martin
- Forum posts: 1
Apr 27, 2010, 3:56:15 AM via Website
Apr 27, 2010 3:56:15 AM via Website
How to convert Blu-rays and DVDs to Motorola Droid with the best settings on Mac
Take web browser, better messaging and contact management, excellent call quality and long talk time aside, its 3.7-inch,854x480 screen makes Motorola Droid perfect for watching HD movies, camera footage, TV shows, music videos, and more. However,because of copyright and format issues, to play commercial Blu-ray and DVD movies on this amazing device is not an easy thing. You have to use a blue ray ripper mac to remove copy protections as well as ripping them to Motorola Droid compatible format. This tutorial intends to show you the best way to experience Blu-ray and DVD movies on your Droid with Pavtube Blu-Ray Ripper for Mac, please feel free to check the following detailed instruction.
Step 1: Download, install and launch Pavtube blue ray ripper for mac
Once launched it, you can click "BD/DVD Folder" or "IFO File" to load Blu-ray/DVD files.
Step 2: Select subtitle and audio track
Click pull down menu of "Subtitle" and "Audio" to select your needed subtitle and audio track respectively. The drop-down list will show you all the info clearly, including language and stream ID of subtitle, language, audio codec, audio ID, and channel of audio. You can choose one according to your own requirement. The preview window will show you the changes in real time.
Step 3: Select output format for Motorola Droid
Click the drop-down menu of "Format", and then follow "Common Video H.264 Video (*.mp4)".
Step 4: Do optimal settings
Click"Settings" button to optimize video and audio parameters, the optimal settings of Pavtube blue ray ripper mac for Droid are recommended as below:
Optimal Video and audio settings:
Video codec: H.264 MP4
Size (resolution): 848*480pix
Bit rate: 2500kbps
Frame rate: 24fps
Audio codec: AAC
Sample rate: 48khz
Bit rate: 64kbps/ 96kbps/ 128kbps
Channels: Stereo
The above mentioned settings will ensure you a perfect playback quality at full screen, without frame skipping and any video/audio out of sync issues. If you prefer a smaller file size, just adjust the video bit rate down to 1,500kbps and it will still look well while watching on the screen.
Step 5: Start ripping Blu-ray and DVD movie to watch on Driod
Once all settings are done, you can click "Convert" button to start Blu-ray and DVD ripping.
The output MP4 files can be found out via clicking "Open" button effortlessly, what you should do next is adding the MP4 files to the SD card and enjoy them freely on Motorola Droid.
Learn more about Motorola Droid Blu-ray ripper for Windows.
Bit rate: 2500kbps
Frame rate: 24fps
Audio codec: AAC
Sample rate: 48khz
Channels: Stereo
Recommended editorial content
