Samsung Galaxy Note 7: battery explosion cause has probably just been found
An independent engineering company launched an investigation into the cause of the Samsung Galaxy Note 7's battery explosions and came across a big flaw in the design of the smartphone.  Did Samsung push too far and compromise safety in the name of innovation? Read on to find out what the company saw when they took a closer look inside the Note 7.
Samsung hasn't officially revealed the cause of the Note 7 explosions yet. At first, Samsung said faulty batteries were responsible. Even after exchanging the batteries the problem didn't go away. In October, Samsung pulled the smartphone from the market entirely. Since then, the company hasn't said much. However, they are planning to officially reveal the reasons why they believe the devices were exploding by the end of 2016, as has been previously reported by AndroidPIT .
Independent expert investigation
The American engineering company, Instrumental, conducted its own investigation and has published its results. The company specializes in the analysis of production processes and helps to identify possible problems. During its investigations, it found a weakness that is the likely cause of the disaster: even during the course of normal operation, the design can compress the battery.
Samsung Galaxy Note 7 Southwest The Verge 840x560
A brand new Galaxy Note 7. / © The Verge
Pressure is a major problem. To understand why, we must understand how the battery is designed. To put it simply, there are two layers, positive and negative, kept apart by two separator layers in the middle. If the positive and negative layers touch, the energy flow and heat leads to an explosion. If you put pressure on the battery's important separator layers, even through just normal use and mechanical swell, it can explode. Samsung says these separator layers may have been thin to begin with due to aggressive manufacturing parameters.
In addition to the separator layers being thin, the battery may not have had room for usual mechanical swell. The smartphone was designed without enough ceiling room for the 5.2 mm battery to swell in its 5.2 mm pocket. Instrumental says it should have been given a 0.5 mm ceiling to expand into. The company said, "This is what mechanical engineers call line-to-line – and since it breaks such a basic rule, it must have been intentional".
instrumental galaxy note 7 battery
Not enough space for the Note 7's battery. / © Instrumental
Instrumental suspects that if the Note 7 hadn't been recalled, the natural expansion of the battery would have caused the devices to slowly push themselves apart. Therefore, the only option left for Samsung would have been to install a smaller battery in the Note 7, which would obviously sacrifice some battery capacity.
It is clear from the results of the investigation that Samsung installed too large of a battery in too small of a space. Why did Samsung's designers not leave enough room for the battery? Instrumental says that the design reveals "an intellectual tension between safety and pushing the boundaries."
If the results of this investigation are correct, then the whole debacle was caused solely by this particular flaw. Whether or not Samsung will put the phone back on the market with a smaller battery, only time will tell. Given the damage to the brand thus far, it is unlikely.
Would you want a Note 7 with a smaller battery? Do you trust Samsung enough to still buy their products?
Source: Instrumental
11 comments
  • hotspring21 Dec 8, 2016 Link to comment
    Wow that's pretty incredible - simply because anyone who used a smart phone with removable battery know that battery can swell. Any smart phone which tightly seals in a battery with little space to expand will be asking for trouble. No need for highly trained engineers to figure out that one! Samsung in all it's wisdom decided to ditch removable battery, but if Note 7 still had removable battery, that would have negated all explosion issues and there would have been no Note 7 fiasco!
  • Stephen Bradley Dec 6, 2016 Link to comment
    I'm using the S7 edge, hope it doesn't have this flaw.
  • Greg1100 Dec 6, 2016 Link to comment
    Slip a smaller battery in the Note 7- and resell them- get some of your money back. Call it a Note 7 R (resale).
    • Brittany McGhee Dec 12, 2016 Link to comment
      That's a good idea, Greg! I wonder if people would still trust the device, even with a new battery...
  •   46
    Deactivated Account Dec 5, 2016 Link to comment
    For me it is Hello LG V20. I do not like the all glass design, to fragile for me. Plus the non removable battery. The S pen will be slightly missed but not a deal breaker. The DAC in the V 20 is awesome.
    • Brittany McGhee Dec 6, 2016 Link to comment
      The V20 is a good alternative. Thanks for sharing, Mark.
  • Greg1100 Dec 5, 2016 Link to comment
    I would buy one too
  • Jerry's W. Dec 5, 2016 Link to comment
    Yes I would like to have one with smaller battery. Refurbished pulled back one for half the price please -:)))
    • Brittany McGhee Dec 5, 2016 Link to comment
      Half the price would be very tempting!
        Well, since the phones they drawed back it ARE secondhand ones... therefor IT would be a waste to shred them.
        I'd pay like max 325 euro for such one with adapted battery.
