T-Mobile auto-sharing your financial data? Don't panic! Our quick guide shows you how to easily switch off these privacy settings and protect your data.
In Samsung One UI 7, the notification panel has been separated from the quick settings. Find out how to get your Samsung Galaxy to work the way it used to.
iOS 18 introduces layered recordings to iPhones. Here's how to use the feature to create and add voiceover to musical tracks and how to listen to them.
IP67, IP68, and now IP69. Those codes represent different levels of water and dust protection for our gadgets. Learn how they differ and which offers more.
How do you photograph fireworks with your smartphone? Find out here how to set the shutter speed, ISO sensitivity, white balance etc. correctly.
Recommended editorial content
