NextPit
OnePlus 6 software update wrecks battery life
Since its launch, OnePlus 6 has already received several software updates. The latest update introduced OxygenOS version 5.1.8, but for many users the joy was soured by a new problem, excessive battery consumption. What is the cause of the problem? How can this be solved?
OxygenOS 5.1.8 caused a battery drain problem
Since the software update that introduced OxygenOS version 5.1.8, several OnePlus 6 owners have complained about an unusual increase in battery consumption. You can read different comments from users in the OnePlus forum:
5.1.8 upgrade aggregated the battery drainage issue!!! If the issue was with Cell Phone Signal reception, I've tried using an alternative network provider and issue seems to be the same... I'm guessing it's a BUG, which needs to be FIXED at the earliest. I'm ending up charging my phone 2-3 times a day with a very minimal usage...
battery drain is serious.. in 5 hrs of phone idle the battery drain was -9%
battery draining very quickly as quick as dash charge
I am also facing the battery drain issue. it was working fine before the update.
Several users have encountered the same problem, and all after downloading and installing the update. Fortunately, if it's any consolation, the issue has not affected all the updated units. Some users also experienced a slowdown of the fingerprint reader and overheating of the device after the update.
The solution
The OnePlus team is aware of the problem, and it's impossible not to be after the avalanche of messages left on the forum. The only solution, at the moment, seems to be the release of a new update capable of fixing the bug that causes the battery drain of the OnePlus 6.
Have you experienced excessive power consumption on your OnePlus 6?
Join the discussion
6 comments
  • Dustin Purciel Jun 26, 2018 Link to comment
    The problem can be fixed by going into settings then select battery. You'll see Android System at the top using the most battery life. Select Android system And then at the bottom you'll see Background activity. Switch it off. It fixed the battery drain issue for me. Hope this helps.
  • Akanbi Kehinde Azeez Jun 26, 2018 Link to comment
    Also facing battery draining problem too
  • David Martrano Jun 25, 2018 Link to comment
    Maybe not the bargain that was a bargain. Don't you test things out first instead of rushing it out!
    • Rusty H. Jun 25, 2018 Link to comment
      No they don't. You want a less expensive phone with pretty good hardware, and want it now, YOU have to be the beta tester for the Oppo OnePlus phone ;)
      "Best" (if there is one) to buy one, is to wait just before they roll out a T version, then get one, or, if you want the T version, wait til they roll out the 7.
    • laci baca Jun 27, 2018 Link to comment
      Mine is ok after update works like a rocket
  • storm Jun 25, 2018 Link to comment
    I've said it before. The OP engineers don't know what they're doing and they don't test things.
