Help, Connecting Android Phone to PC(Bluetooth Dongle)
Ernesto Hilvano
  • Forum posts: 3
May 21, 2012, 1:30:44 PM via Website
Hi. i am having a problem on connecting android phone to pc using bluetooth
can anyone help me?
its hard for me to understand the tutorial on android developer forum(bluetooth chat)
because the tutorial is for 2 mobile phone
in my case. i will send a message from phone to PC using bluetooth
i hope i can found the answer here in android pit. thanks a lot.
Judy Zhao
Eric McBride
  • Forum posts: 1,781
May 22, 2012, 4:19:02 PM via Website
Which phone do you have and which version of Android?
Judy Zhao
Ernesto Hilvano
  • Forum posts: 3
May 23, 2012, 4:01:01 PM via Website
thanks for replying bro.
i have samsung gt553 ( i dont know what exactly the name of the unit)
and the android version is android 2.1
i can only turn on and discover the available devices
but i am having to connect it to a bluetooth dongle device
Judy Zhao
Eric McBride
May 25, 2012, 2:37:36 PM via Website
I cant seem to find that particular phone. Can you send a link to it? Im not familiar with it and want to make sure Im looking at the right device.
Judy Zhao
Eric McBride
Jun 6, 2012, 2:26:36 PM via Website
Ah ok. Thanks :-)
First off, you're PC definitely has Bluetooth right? Not all of them do. If it does, go into your phone and turn on Bluetooth, and make sure its also on on your PC. Then go into Bluetooth settings on your phone and make your phone visible. I would set the time for at least 5 minutes visible.
Now try to see if your PC can see the phone or vice versa, and let me know how it goes.
Judy Zhao
Judy Zhao
Mar 10, 2014, 10:38:11 AM via Website
Hi here I would like to share with you our new product PTV8000 that supports airplay mirroring+ miracast+ DLNA
You can search keyword of "PTV8000" to see demo on YouTube.
Skype: judyzhao906
