- 1 The comparison of the best object trackers for your luggage in brief
- 2 Table of Content
- 3 The best object trackers to stop you losing your stuff
- 3.1 The best object tracker: Tile Pro
- 3.2 The best Bluetooth tracker for iPhone and iPad: Apple AirTag
- 3.3 Pros of the Apple AirTag
- 3.4 Cons of the Apple AirTag
- 3.5 The tracker with the best value for money: Chipolo One
- 3.6 The best Bluetooth tracker for your wallet: Tile Slim
- 3.7 The best GPS tracker: Invoxia Mini Tracker GPS
- 4 Buying advice: Criteria to consider before buying an object tracker
Table of Content
- The best object trackers so you never lose your stuff again
- Buying advice: Criteria to consider before buying an object tracker
The Tile Pro is the best object tracker on the market. It has a rectangular design with rounded corners and is made of high-quality plastic. You can remove one side to access the stack. Keep in mind that it’s rather imposing compared to its competitors, but it makes up for it with the integration of a key ring. Tile’s tracker relies on Bluetooth to find your lost objects.
With a direct range of 120 m, it can find lost items even if they’re quite a distance from you. Tile offers an app available on iOS and Android, but on iPhones it’s a little more limited. On Android, you’ll be able to add, rename, and share trackers with friends, view a map of recent locations or assign ringtones to your trackers.
- See also our selection of the best surveillance cameras to choose from in 2023
The Tile network lets you tag your lost device and report when you find someone else’s Tile. The brand has placed a QR code on the back of the trackers so that the average person can scan it to help you.
The Tile Pro is compatible with Google Assistant, Siri, and Amazon Alexa. The replaceable battery lasts up to a year. Please note, however, that some features are reserved for a paid subscription, which costs €3.49/month.
Read our full review of the Apple AirTag
The AirTag has established itself as a market leader thanks to its ease of use and, above all, Apple’s Find My network. It’s a small, round, fairly flat plastic pebble. It also allows you to remove one side to change the battery. However, it doesn’t come with a key ring, so you’ll need to buy a special case designed for this purpose.
In addition to Bluetooth, Apple’s tracker incorporates a UWB chip that enables it to search for lost objects with pinpoint accuracy. Apple promises a range of up to 60 m. But thanks to the Find My network, this is much greater and is in fact limited only by the number of Apple devices present in an area.
The AirTag also stands out for its user experience. It can be added to the Find application in the blink of an eye, and once connected, you can name the tracker, track its position, and so on. Apple’s tracker doesn’t, however, allow you to find your iPhone at the touch of a button, as the competition does.
Apple obliges, so forget about compatibility with Google Assistant or Alexa. You’ll be able to use it for a year before having to change the battery.
- Intuitive operation
- Reliable tracking especially in combination with the U1 chip
- Good data protection
- Long battery life (approx. 1 year)
- Personalizable via engravings
- Accurate tracking only possible on iPhone models from iPhone 11 onwards
- Key fob available only as an additional purchase
The Chipolo One is an effective object tracker with a simple, sleek and compact design. It comes in a circular shape and is made of solid, high-quality plastic. With an integrated hole, it attaches easily to your keys or other objects, offering great practicality.
Chipolo One relies on Bluetooth technology to find your lost items. With a range of 60 m, it enables you to find your objects close by, whether at home, in the office, or on the move.
The Chipolo app also offers handy features such as a map of your items’ last known locations, and the ability to share trackers with friends and family for collaborative searching.
- See also our selection of the best connected air purifiers for your smart home in 2024
With a powerful audible alarm, reaching up to 120 dB, it lets you quickly locate your objects, even in the most crowded places. Chipolo One is fitted with a replaceable battery offering up to one year’s autonomy, ensuring long-lasting, hassle-free use.
Note that this is the classic version of the Chipolo One, which can be used on both iOS and Android via the Chipolo app. There’s also an iOS-only One Spot version based on Apple’s Find my network, and an Android-only One Point version using Google’s Find my network.
The Tile Slim is designed to prevent you from misplacing your wallet. It takes the form of a credit card, which you can place in your wallet.
With its 60 m range and compatibility with Google Assistant, Alexa, and Siri it’s a pretty versatile tracker. You can use the app on Android or iOS to find your items quickly. As with the Pro model, the app lets you rename, share trackers with friends, display a map of recent locations or assign ringtones to your trackers.
You’ll also benefit from the Tile network and the ability to mark your device as lost or report when you find someone else’s Tile. The QR code on the back will enable the average person to contact you if they find your tracker.
The Tile Slim is equipped with a non-replaceable battery with three years’ autonomy. Once again, you’ll have to pay for certain features.
The Invoxia Mini Tracker GPS is a compact, elegant tracking device. Rectangular in shape with rounded edges, it is made from high-quality plastic. Its discreet design makes it easy to attach to your objects thanks to its integrated ring. Unlike other models, it’s extremely lightweight and almost unnoticeable.
Invoxia’s Mini Tracker uses a combination of GPS and low speed network to locate your lost objects, offering extensive coverage even outside urban areas. Thanks to the Invoxia app available on iOS and Android, you can track the position of your objects in real-time, define safe zones, and receive alerts in the event of suspicious movement.
This tracker stands out for its impressive autonomy, up to six months thanks to its rechargeable battery. The Invoxia Mini Tracker is compatible with voice assistants such as Google Assistant, Siri, and Amazon Alexa.
Whether you want to monitor your luggage while traveling or quickly find your misplaced keys at home, Invoxia’s GPS Mini Tracker offers a reliable and practical solution for protecting your most important items.
With its ease of use and proven reliability, it will quickly become an indispensable part of your daily routine, giving you added peace of mind. Subscription to Invoxia Tracking Services costs €24.95 per year, making it a cost-effective option for long-term monitoring.
How do object trackers work?
Object tracker design
Object trackers come in a variety of designs to suit different uses. For example, the Eufy Security SmartTrack is a compact, square tracker that’s easy to attach to keys, while the Tile Slim takes the shape of a credit card for easy insertion in a wallet.
These varied designs allow you to choose the model best suited to your specific needs. Most models are IP67-certified, so they’re safe from water and dust.
The different types of object trackers
Object trackers use different technologies to locate objects: Bluetooth, which offers a limited range, ideal for close objects such as keys; GPS, which enables precise global location in real-time for more distant objects; and UWB, which provides very high location accuracy at close range, useful for finding objects with great precision.
The audible alarm of object trackers
Bluetooth and GPS object trackers are equipped with powerful audible alarms to help you quickly find your lost belongings. With sound levels of up to 120 dB, these alarms are audible enough to be heard even in the noisiest environments. They make it easy to locate your lost items quickly, offering extra peace of mind in the event of loss.
Object tracker compatibility with connected home ecosystems
Some Bluetooth trackers are compatible with voice assistants, enabling you to launch the search for your lost items via voice command. While the AirTag, for example, only supports Siri, Tile’s trackers are compatible with Google Assistant, Siri, and Alexa at the same time.
Object tracker range and location technologies
Bluetooth object trackers have a limited range, usually up to a few hundred meters, depending on surrounding obstacles. Location networks such as Apple’s Find My and Samsung’s SmartThings Find leverage the Bluetooth network of millions of iPhones and Galaxy smartphones to help locate lost objects.
GPS trackers, on the other hand, offer global coverage, enabling objects to be located anywhere in the world as long as they have a satellite connection. These networks rely on a global satellite infrastructure to provide precise coordinates of object location, offering unlimited range but requiring a constant connection to a satellite network.
The differences between Bluetooth and GPS technologies are summarized in the table below:
| Advantages | Disadvantages | |
| Bluetooth tracker |
| GPS tracker |
Object tracker battery life
Bluetooth object trackers generally have long battery life, thanks to their low power consumption. They can often operate for a year or more with a standard replaceable battery. This long life makes them ideal for everyday use without the need for frequent recharging.
The vast majority of trackers sold today are powered by CR2032 batteries. Battery life ranges from 1 year for models with a replaceable battery, such as the Galaxy Smart Tag 2, to 3 years for models with a non-replaceable battery, such as the Tile Slim.
GPS trackers, on the other hand, consume more energy due to their constant connection to satellites for real-time tracking. They use rechargeable batteries that need to be recharged after a few months, depending on use. The Invoxia Tracker GPS Pro, for example, can last up to 3 months.
The privacy risks of object trackers
Like many connected objects, object trackers represent a danger to privacy, particularly in terms of unauthorized tracking. Fortunately, brands have become aware of this and developed solutions to avoid privacy violations. For example, Apple’s AirTag raised concerns that it could be used to track people without their knowledge.
But Apple has introduced measures. The AirTag can ring after 8 hours away from its owner to signal its presence. The brand even enables the detection of unknown AirTags on Android.
Samsung protects privacy by making the device’s location accessible only with the owner’s authorization. In addition, SmartThings Find enhances security with Unknown tag alerts, which warn of unauthorized tracking by sending a notification when an unknown SmartTag follows the user.
Similarly, Google’s new Locate feature for Android, which will detect unknown trackers, aims to counter these risks by alerting you when an unknown tracker moves with you. For other brands, Google offers recognition of unknown trackers moving at the same time as you directly in Android smartphones’ settings. Compatibility of this feature is being extended over time to various tracker manufacturers.
Despite these measures, the potential for misuse remains a concern, requiring ongoing vigilance and constant improvements in security protocols to protect your privacy.
So much for our comprehensive object tracker buying guide. Now you can choose the right tracker for your needs, so all that’s left is to jump on one of the models in our selection to guarantee a peaceful summer without lost luggage or personal belongings.
Have you ever lost your belongings while traveling? What solution do you currently use to prevent such losses? Are you planning to buy an object tracker? If so, which one?
