Pros of the Xiaomi 14T Pro
  • Excellent daily performance
  • Versatile camera in both hardware and software
  • Fast charging wired or wireless
Cons of the Xiaomi 14T Pro
  • Average gaming performance
  • No charger in the box
  • Bloatware and ads
Xiaomi 14T Pro in a nutshell
The Xiaomi 14T Pro is a flagship phone from the Chinese brand that follows the second semester’s refresh cycle. As usual, it tries to offer a flagship experience at a lower price point, and like with its predecessor, the phone starts at €799.00 in Europe, with no plans for a release in the US.
For that money, Xiaomi offers a balanced set of specifications, including a big and bright OLED display that refreshes at up to 144 Hz, 12 GB of LPDDR5x RAM, three storage options ranging from 256 GB to 1 TB, a triple camera setup with the help of Xiaomi’s partner Leica, and a Dimensity 9300+ chip from MediaTek. Charging can reach 120 W, but unlike past Xiaomi models, the required adapter is not included in the box.
Solid, big-screened phone
With the never-ending appetite for big screens, the Xiaomi 14T Pro is another phone from the brand to use a 6.67-inch OLED panel. The display dictates the overall build of the phone, with thin bezels around it, and ample space in the back for the triple camera module.
Pros:
  • Good build quality.
  • Bright and smooth display.
  • Premium feel.
  • IR blaster.
  • IP68 rating.
Cons:
  • No headphone jack or microSD support.
Measuring 160.4 x 75.1 x 8.39 mm with a weight of 209 grams, the Xiaomi 14T Pro feels solid in the hand, with a nice grip. The phone is available in gray, blue, and black versions (all prefixed “Titan” in marketing materials), with a textured glass back that stays mostly free of fingerprints.
Xiaomi 14T Pro smartphone displayed with a sleek design and triple camera setup on a dark background.
The textured glass back feels good to the touch. / © nextpit Image source: nextpit
The flat sides returned from the previous generation, as well as the placement of all buttons on the right side, in easy-to-reach positions—with a textured power button to avoid mistakes.
The top features a microphone and the traditional IR blaster, with the other microphone on the bottom surface, next to the USB-C port, and the dual SIM card tray—there is also support for eSIM. The left side is empty. And finally, there is a protective case in the box, which is always welcome.
Xiaomi 14T Pro smartphone displaying the home screen with app icons and a clock at 4:59.
The OLED screen is both smooth and bright, with thin bezels. / © nextpit Image source: nextpit
The OLED display dominates the front with small bezels around it. Our test units (one blue and one black) came with a screen protector pre-applied, but it was slightly off-center in one of the devices.
Xiaomi quotes a 4000 nits peak brightness, something that we couldn’t confirm, but the screen was usable under daylight without issues. Color reproduction and viewing angles were excellent (OLED panels are pretty much a commodity these days).
Close-up of the top edge of a Xiaomi 14T Pro smartphone
The top features the traditional IR blaster. / © nextpit Image source: nextpit
The flat display on the Xiaomi 14T Pro offers similar specs to the phone’s predecessor: 2712×1220 resolution, a smooth 144 Hz refresh rate, but no LTPO tech for extra power savings, only an option for a fixed 60 Hz mode.
HyperOS with its ups and downs
Powered by HyperOS 1.0.5.0 over Android 14, the 14T Pro phone brings the usual pros and cons of Xiaomi’s interface, with lots of third-party apps and ads, but tons of customization options.
Pros:
  • Fluid and customizable.
  • Shorter setup than before (feat. Google).
Cons:
  • Bloatware and ads.
  • Shorter update policy than rivals.
One positive point in the Xiaomi 14T Pro usage came right in the initial setup. Apparently, Google reorganized the process to delay non-crucial steps depending on the user’s selections. The first screen still holds the accessibility options, but we found the process more streamlined from there.
Screenshots from the Xiaomi 14T Pro HyperOS interface
HyperOS is still evolving from its MIUI origins.
Quelle: nextpit
We counted 12 third-party pre-installed apps, plus some shortcut ads to 7 more on the ‘More apps’ folder.
Quelle: nextpit
The HyperOS 1.0.5.0 installation during the test had the June/2024 security patch.
Quelle: nextpit
34.8 GB of used storage is almost nothing on the 1 TB review unit, but the impact on the 256 GB model is big.
Quelle: nextpit
The EU-mandated default browser and search selection, for example, were moved to the post-setup steps, together with Assistant settings. The change can be attributed to Google (the Pixel 9 family showed similar improvements) and we expect to see it reaching the entire Android ecosystem.
After updating the apps on a fresh install with default settings, we counted 12 third-party apps and 34.8 GB of used storage, something that not even flagship Xiaomi phones are immune to.
Another typical weak point is the number of notifications and ads all over the interface, for which my colleague Antoine wrote a comprehensive guide to clean up and make the phone yours. Ads even reached the “More apps” folder on the home screen, with suggestions of additional apps to install.
Xiaomi advertised a lot of AI features, true to any 2024 phone, but most of them were unavailable during the review. The company promised that most of them were going to be offered with an update on launch day (AKA as you are reading this).
Close-up of a Xiaomi 14T Pro smartphone showing its camera layout and side buttons.
The power button has a subtle texture to make it easy to summon your favorite assistant. / © nextpit Image source: nextpit
One exception we could test was AI subtitles, which worked fine with the media we tested. Gemini AI features are also onboard, with the standard Gemini app already pre-installed, and Circle to Search promised with an update in October.
Finally, Xiaomi promises five years of security updates and four years of system upgrades to the 14T Pro. The policy is good enough for most people but still lags behind alternatives from Google and Samsung in the same price range.
Good showing from the Dimensity 9300+ CPU
The Xiaomi 14T Pro sidesteps the company’s long relationship with Qualcomm to use the rival MediaTek Dimensity 9300+ SoC. On top of that, there is plenty of RAM and storage to offer snappy performance. Gaming, however, is not the phone’s strong point.
Pros:
  • Great CPU performance.
  • Good thermal management.
  • Modern GPU with Ray Tracing support.
Cons:
  • Disappointing GPU performance.
In our tests, using the interface, apps, browsing the web, and taking pictures, the Dimensity chip performed on par with any other flagship processor in the Android ecosystem.
Despite using the same cores found on the rival Snapdragon 8 Gen 3, the Dimensity 9300 simply skipped efficiency cores and went with four Cortex-X4 performance cores and four Cortex-A720 balanced cores, instead of the 1+5 setup on the Qualcomm chip, which adds 2 efficiency cores (A520).
  Xiaomi 14T Pro
(Dimensity 9300)
Xiaomi 14 Ultra
(Snapdragon 8 Gen 3)
Google Pixel 9 Pro
(Tensor G4)
Galaxy S24 Ultra
(Snapdragon 8 Gen 3
Poco F6 Pro
(Snapdragon 8 Gen 2)
AnTuTu 2,013,101
(Perf. mode: 2,077,622)
1,939,484 948,187 1,851,716 1,563,987
3DMark Wild Life Extreme Stress Test Best loop: 2983 (2958)
Worst loop: 2633 (2641)
Stability: 88.3% (88.4%)
Best loop: 4708
Worst loop: 3606
Stability: 76.6%
Best loop: 2559
Worst loop: 2046
Stability: 80%
Best loop: 5160
Worst loop: 3013
Stability: 58.4%
Best loop: 3035
Worst loop: 1639
Stability: 54%
3DMark Steel Nomad Light Stress Test Best loop: 1132 (1142)
Worst loop: 1086 (1089)
Stability: 95.4%
Best loop: 1685
Worst loop:  1335
Stability: 79.2%
Best loop: 1043
Worst loop: 873
Stability: 83.7%
Geekbench 6 Single: 2188 (2243)
Multi: 7158 (7304)
Single: 1828
Multi: 6317
Single: 1934
Multi: 4466
Single: 2252
Multi: 7107
Single:  1442
Multi:  5318
While we doubt most people will ever notice a difference between the two chips, the Dimensity 9300+ topped our main CPU Geekbench by a decent margin, while only losing in the AnTuTu test to an overclocked version of the Snapdragon 8 Gen 3 on the niche RedMagic 9S Pro Casi tested a few months ago.
The same cannot be said about gaming performance, however, despite the Xiaomi 14T Pro using ARM’s flagship GPU core, the Immortalis-G720. The GPU—with 12 cores on the Dimensity chip—is compatible with all the latest features, including ray tracing (RT) support.
Screenshots showing the Xiaomi 14T Pro results in the AnTuTu benchmark
AnTuTu score in the ‘Balance’ mode.
Quelle: nextpit
Small gain under the ‘Performance’ mode.
Quelle: nextpit
Screenshots showing the Xiaomi 14T Pro results in the 3DMark benchmark
Performance in 3D graphics is on par with the Pixel phones, and much lower than Snapdragon alternatives.
Quelle: nextpit
The Xiaomi 14T Pro showed good heat management despite the big performance cores.
Quelle: nextpit
Screenshots showing the Xiaomi 14T Pro results in the Geekbench benchmark
Geekbench scores were on par or better than Snapdragon rivals in both ‘Balance’ and ‘Performance’ modes.
Quelle: nextpit
The Immortalis GPU supports ray tracing, but cannot challenge Snapdragon phones in performance.
Quelle: nextpit
3DMark Solar Bay results with the performance mode.
Quelle: nextpit
3DMark Steel Nomad Light scores with the Balance mode.
Quelle: nextpit
3DMark Steel Nomad Light scores with the Performance mode.
Quelle: nextpit
In practice, however, the Xiaomi 14T Pro didn’t run games much better than the Pixel 9 Pro with a more modest 7 cores of the older generation ARM Mali-G715 GPU. Performance was perfectly fine in titles such as Call of Duty Mobile or Genshin Impact, but the 3DMark scores shows the chip’s limitation next to the Snapdragon’s Adreno GPU.
By default, the Xiaomi 14T Pro comes set at a “Balanced” performance profile, but the improvements using the “Performance” mode—set at the Battery settings—were within the margin of error. The Performance mode can be identified by a blue battery icon with a double arrow in the status bar.
Regardless of performance mode, the Xiaomi 14T Pro managed the temperature well, with no excessive heat generation—which was a problem iwe found in older phones from the brand. We were initially worried that the inclusion of only performance cores would affect thermals and stability, but Xiaomi and MediaTek (and TSMC) did a good job here.
Xiaomi 14T Pro camera
With a true triple camera setup, the Xiaomi 14T Pro offers the usual set of cameras for a flagship phone: A main sensor with 50 megapixels, an ultra-wide lens with 12 MP, and a 2.6x telephoto with 50 megapixels. On top of that, Xiaomi adds its suite of AI features plus image processing and styles from its Leica partners.
Pros:
  • Versatile camera.
  • Usable 10x zoom shots.
  • Many image modes and filters.
  • Excellent night shots.
Cons:
  • Inconsistent colors between lenses.
Despite not using the big 1-inch sensors from its Ultra series, Xiaomi did a good job on the 14T Pro’s cameras, with a good dose of help from Leica’s color processing (or “science”, if you spend time on photography websites).
Close-up of the Xiaomi 14T Pro smartphone
The oversized camera islands house pretty good hardware inside. / © nextpit
The main camera is powered by a proprietary 1/1.3’’-size “Light Fusion 900” sensor, which is identified as OV50H40 in hardware (suggesting an OmniVision sensor). It performed very well in our tests, with a nice level of detail and sharpness, and realistic color reproduction.
The camera app offers two photographic styles for the back cameras: Leica Authentic and Vibrant. With the first one resulting in more “moodier” images, and the second one with a little bit more punch (but not on the same saturated levels found in Pixel or Galaxy shots). Unless noted, all shots were taken with the “Leica Vibrant” setting.
Xiaomi 14T Pro: Ultra-wide-angle camera (0.6x)
Quelle: nextpit
Xiaomi 14T Pro: Main camera
Quelle: nextpit
Xiaomi 14T Pro: Main camera (2x digital zoom)
Quelle: nextpit
Xiaomi 14T Pro: Telephoto camera (2.6x)
Quelle: nextpit
Xiaomi 14T Pro: Telephoto camera (5x digital zoom)
Quelle: nextpit
Xiaomi 14T Pro: Telephoto camera (10x digital zoom)
Quelle: nextpit
Xiaomi 14T Pro: Ultra-wide-angle camera (0.6x) - Leica Authentic
Xiaomi 14T Pro: Ultra-wide-angle camera (0.6x) – Leica Authentic
Quelle: nextpit
Xiaomi 14T Pro: Ultra-wide-angle camera (0.6x) - Leica Vibrant
Xiaomi 14T Pro: Ultra-wide-angle camera (0.6x) – Leica Vibrant
Quelle: nextpit
Xiaomi 14T Pro: Main camera - Leica Authentic
Xiaomi 14T Pro: Main camera – Leica Authentic
Quelle: nextpit
Xiaomi 14T Pro: Main camera - Leica Vibrant
Xiaomi 14T Pro: Main camera – Leica Vibrant
Quelle: nextpit
Xiaomi 14T Pro: Main camera (2x digital zoom) - Leica Authentic
Xiaomi 14T Pro: Main camera (2x digital zoom) – Leica Authentic
Quelle: nextpit
Xiaomi 14T Pro: Main camera (2x digital zoom) - Leica Vibrant
Xiaomi 14T Pro: Main camera (2x digital zoom) – Leica Vibrant
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Xiaomi 14T Pro: Telephoto camera (30x digital zoom)
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Ultra-wide shots usually had totally different color processing, resulting in more saturated and brighter images (maybe overcompensating the much smaller OV13B10 sensor also from OmniVision). I must say, however, that in many cases, the “overprocessed” ultra-wide shots would win over the main camera pictures in blind tests.
The 2.6x telephoto lens, on the other hand, tended to be more consistent with the main camera. And while it usually performed very close to the 2x digital zoom from the main camera, it allowed to go even further, with usable results at 5x or 10x zooms in daylight.
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Night photography also had some good results from the main and telephoto cameras. Zooming in usually introduces digital artifacts, and the ultra-wide camera usually can’t capture enough light. But between the two 50 MP cameras, results were mostly sharp with a good level of detail and keeping light sources under control.
We also took portrait shots during the night, using both styles available on the Portrait mode: Leica Portrait and Master Portrait. Side note: Portrait photography is apparently on the rise in China, with both Xiaomi and Honor advertising the mode heavily in their materials, but back to the review.
Xiaomi 14T Pro: Main camera - Leica Portrait mode
Xiaomi 14T Pro: Main camera – Leica Portrait mode
Quelle: nextpit
Xiaomi 14T Pro: Main camera - Master Portrait mode
Xiaomi 14T Pro: Main camera – Master Portrait mode
Quelle: nextpit
Xiaomi 14T Pro: Telephoto camera (2.6x) - Leica Portrait mode
Xiaomi 14T Pro: Telephoto camera (2.6x) – Leica Portrait mode
Quelle: nextpit
Xiaomi 14T Pro: Telephoto camera (2.6x) - Master Portrait mode
Xiaomi 14T Pro: Telephoto camera (2.6x) – Master Portrait mode
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Without any kind of portrait photography experience (or studio lighting), we didn’t have the ideal conditions for judging the images, but in general we liked to play with the options. Master Portrait returned more realistic results, while Leica Portrait better highlighted the subject from the background. And both styles presented excellent subject separation.
Xiaomi 14T Pro: Selfie
Quelle: nextpit
Xiaomi 14T Pro: Selfie - Portrait mode on
Xiaomi 14T Pro: Selfie – Portrait mode on
Quelle: nextpit
Quelle: nextpit
Quelle: nextpit
Selfie shots were also good—not as much as with the back cameras, though—but don’t offer the same Leica or portrait styles. Skin tone and texture were realistic, and the default options are free from the excessive processing from “Beauty effects”.
Xiaomi 14T Pro battery
With a 5000 mAh battery capacity, the Xiaomi 14T Pro offers enough battery life for an entire day of usage, probably two for more frugal users. Xiaomi’s highlight is once again when it comes to charging, with 120 W wired and 50 W wireless, but no charger included in the box.
Pros:
  • Fast charging with or without wires.
Cons:
  • Charger not included.
Close-up of a Xiaomi 14T Pro smartphone showing its sleek design and charging port.
It charges fast, but the required HyperCharge adapter is optional. / © nextpit Image source: nextpit
Xiaomi finally caved in to the market and stopped bundling a charger with the Xiaomi 14T Pro. A real shame, since the phone is capable of very fast charging times with a compatible HyperCharger 120 adapter. Just remember to activate the required “Top speed” charging mode if you are in a hurry.
Charging Xiaomi 14T Pro
(5000 mAh | 120W ) [“Fast” option]
Google Pixel 9 Pro
(4700 mAh | 300 W USB-PD)
Pixel 9 Pro XL
(5060 mAh | 140 W USB-PD)
Galaxy S24+
(4900 mAh | 45 W USB-PD)
5 minutes
  • 23% [23%]
  • 8%
  • 11%
  • 12%
10 minutes
  • 41% [50%]
  • 18%
  • 24%
  • 26%
20 minutes
  • 70% [85%]
  • 37%
  • 45%
  • 49%
30 minutes
  • 95% [-]
  • 56%
  • 57%
  • 70%
1 hour
  • 90%
  • 91%
Full charge
  • 32 min [25 min]
  • ~1h25
  • 1h20
  • 55 min
PC Mark Battery test
  • Default: 13h28
    (14830 points)
  • Performance mode: 13h11 (16337)
  • Default: 16h34
    (13287 points)
  • High-resolution: 15h29
    (13444)
  • 15h39
    12986
  • 15h06
    18099
With the default option, we got a charging time of 32 minutes. Turning on Top speed mode dropped that time to 25 minutes, with a 50% charge in just 10 minutes.
Screenshots showing the Xiaomi 14T Pro results in the PCMark battery test
The battery life score was average, but the performance score was quite good at 14830 points.
Quelle: nextpit
Performance mode decreased the runtime slightly, but the performance score jumped to 16337 points.
Quelle: nextpit
Not only that, the phone can also be recharged wirelessly with a proprietary 50 W stand or at a lower input power with any standard Qi charger. There is no reverse wireless charging on the Xiaomi 14T Pro, however (at least with the tested firmware).
Xiaomi 14T Pro technical specifications
  Xiaomi 14T Pro
Display
  • 6.67-inch OLED
    2712 x 1220 pixels
    144 Hz refresh rate
SoC
  • MediaTek Dimensity 9300+
Memory
  • 12 GB LPDDR5x RAM
    256 / 512 / 1024 GB UFS 4.0 storage
    No storage expansion
OS
  • HyperOS + Android 14
    Four years of system upgrades
    Five years of security updates
Camera
  • Main: 50 MP, f/1.6, OIS
  • Ultra-wide: 12 MP, f/2.2
  • 2.6x telephoto: 50 MP, f/2.0
Selfie Camera
  • 32 MP, f/2.0
Battery
  • 5000 mAh
  • 120 W wired charging
  • 50 W Qi wireless charging
Connectivity
  • 5G | eSIM | Wi-Fi 7 | Bluetooth 5.4 | NFC
IP Certification
  • IP68
Dimensions and weight
  • 6.3 x 2.9 x 0.33 in, 7.4 oz
  • 160.4 x 75.1 x 8.39 mm, 209 g
Other points that may interest the nextpit community:
  • The Xiaomi 14T Pro includes NFC support and is compatible with Google Pay for contactless payments.
  • The review unit packaging included a USB-C to USB-A charging cable, a protective case, and a SIM tray tool.
  • The software version during the test was HyperOS 1.0.5.0 with the June 2024 security patch.
  • After resetting the updated handset, the operating system indicated 34.1 GB of used space.
The Xiaomi 14T Pro offers a sensible balance of features and hardware for the price. The performance and user experience leave nothing to be desired when compared to its competitors in the same price range, except maybe for those who prioritize AAA gaming on their phones.
The company’s investment in photography over the past years already showed excellent results in 2023 and the new phone is another good step forward in the field, with a nice package both in hardware and software. It gives competitive shots without having to use expensive huge sensors or lenses.
Charging is once again a highlight in the phone, but the omission of the charger in the box is a sad development, as the 120 W adapter is required to take advantage of the feature. Another issue is the the amount of bloatware and ads in the system, but at this point, we imagine that Xiaomi customers unfortunately take that for granted.
In the end, while we can’t recommend the Xiaomi 14T Pro as an upgrade for someone with a recent flagship, it is a good option to consider if you have an older high-end phone or are looking to step up from any mid-range phone.
