Pros of the @VARIANT
  • Practical
  • Qi Global standard
  • Smart design
Cons of the @VARIANT
  • Poor color options
  • No cable or charging adapter
@VARIANT release date and price
You can buy the Premium wireless charger from Samsung for $89.99. The device can also be found on other online stores for a bit cheaper.
AndroidPIT samsung galaxy s8 fast charge 1522
Samsung’s Premium wireless charger blends in easily to any workstation. / © NextPit Image source: NextPit
@VARIANT design and build quality
Samsung has offered manufacturer support for its two main wireless chargers since the launch of the Galaxy S6 and Galaxy S6 Edge. Since then, the pad has always been circular, but with the launch of the Galaxy S7, the manufacturer gave users the option of charging their devices in two positions: laying on the pad or standing.
AndroidPIT samsung galaxy s8 fast charge 1550
Laying position / © NextPit Image source: NextPit
This wireless charger is light, it doesn’t take up much space, and it can be used anywhere as long as it has access to a power source. The device itself can’t store power, but a battery pack would work.
Keep in mind that Samsung doesn’t include the charging cable or AFC (Active Fast Charging) adaptor. This means that you’ll have to get some additional compatible accessories yourself. Due to questions regarding the device’s guarantee, Samsung forces you to use only those devices that are approved by the company. Plus, remember that non-recommended accessories could also cause performance issues.
AndroidPIT samsung galaxy s8 fast charge 1540
Standing position / © NextPit Image source: NextPit
The model only comes in one color, black, and it blended into the decoration of my house and workstation well enough. However, in the future, it would be great if Samsung could offer the device in more colors since it’s quite handy to have around and you might want to buy a few and stick them around your home.
AndroidPIT samsung galaxy s8 fast charge 1579
Samsung’s Premium Wireless charger is discrete and easily blends into your home decor. / © NextPit Image source: NextPit
The finish on the Samsung Premium Wireless charger is frosted silicone. The wireless charging surface has three spring-loaded holders in the center, aligned from top to bottom so that you can charge the Galaxy S8 in two different positions: vertical and horizontal.
If you’re looking to charge your device while listening to music on your headphones or even taking a call, this charger is perfect. Furthermore, since the wireless charger works as a stand for your device and the screen is facing you, you can stay up to date on your Netflix series while making dinner or take a look at your Facebook newsfeed while it’s charging.
AndroidPIT samsung galaxy s8 fast charge 1534
Using your smartphone while it’s charging isn’t a problem . / © NextPit Image source: NextPit
When it’s in the stand position, the charger can hold the device either vertically or horizontally. It also has a LED that indicates the wireless charger’s status:
  • Blue > Green > Light blue: connected to a power source
  • Blue: smartphone is charging
  • Green: device is fully charged
  • Flashing blue: device isn’t charging correctly for some reason
  • Disconnected: device is removed from the wireless charger or it’s not connected to a power source
AndroidPIT samsung galaxy s8 fast charge 1537
Blue means your smartphone is charging . / © NextPit Image source: NextPit
@VARIANT performance
In addition to wirelessly charging the Galaxy S8, or any other model compatible with the Qi standard, this charger also offers quick charge technology. Compared to the last model (EP-PG9201), the current version cuts off an hour of charge time. In other words, it’s much more efficient.
AndroidPIT samsung galaxy s8 fast charge 1557
USB Type-C port to connect a charging cable. / © NextPit Image source: NextPit
The connection port has also been upgraded from one generation to the next, and now there’s a standard USB Type-C port. Plus, as we saw in the Galaxy S8 kit, it comes with a USB Type-C to MiscroUSB 2.0 adaptor. So, if you need to, you can also use a microUSB 2.0 cable, as long as it’s approved my Samsung, of course.
AndroidPIT samsung galaxy s8 fast charge 1585
The Samsung Premium wireless charger kit comes with a USB port adaptor. / © NextPit Image source: NextPit
That said, Samsung’s new wireless charger is convenient and, above all, offers excellent performance. Naturally, using the cable and AFC adaptor shortens the charging process. Your phone will reach 100% charge about an hour faster than using just wireless charging. However, the experience with Fast Charge Wireless is much nicer, since instead of having to connect cables and outlet adaptors, the pad is always ready. All you need to do is place your device on top of it.
Keep in mind that with Active Fast Charging, the system will recognize the exact moment it should stop charging the device. Over the long run, this will make your battery last longer.
The device also comes with a built-in fan and thanks to this cooling system, the charger never heated up while I was testing it out. The fan will also keep your hardware at a decent temperature. And, in my case, I didn’t hear the fan make any noise.
AndroidPIT samsung galaxy s8 fast charge 1554
The cooling system uses a built-in fan. / © NextPit Image source: NextPit
The charging time for the Galaxy S8 (3000 mAh) on the wireless charger with fast charging technology, connected to an outlet with an AFC adaptor and original cables from Samsung, took an average of about 2h and 40 minutes to completely charge the battery (starting anywhere between 0 and 5% battery).
If you use a protective cover on your phone, that could affect the wireless charge time or even make it so it doesn’t charge correctly. I’d recommend taking off the cover to make sure you get the best experience. Obviously, the charger you use needs to support quick charge as well  (9 V/1.67 A, 9 V/2 A, 12 V/2.1 A).
Officially, Samsung states that only devices in its Galaxy S and Note series are compatible with the Premium Wireless Charger. However, since it uses Qi global standard inductive charging, it could technically be used to charge any device that supports it.
@VARIANT technical specifications
Compability and features
Color Black and Tan
Compability Galaxy S8, Galaxy S8+, Galaxy S7, Galaxy S7 Edge, Galaxy note 5, Galaxy S6 Edge Plus
Items included Carregador sem fio conversível, guia de início rápido, conector micro USB
Features Carregamento sem fio, padrão WPC (Qi), fator de forma conversível (apoio e suporte)
Dimensions (WxHxD) 117.4 x 28.6 x 117.4 mm
Weight 227 g
Input Voltage (Normal charge max.) 5V
Input Voltage (Fast charge max.) 9V
Input Current (Normal charge max.) 2A
Input Current (Fast charge max.) 1.67A
Output Voltage (Normal charge max.) 5V
Output Voltage (Fast charge max.) 9V
Output Current (Normal charge max.) 1A
Output Current (Fast charge max.) 1A
My experience with the Galaxy S8 significantly improved after using the Samsung Premium Wireless Charger. In the past, I would get to work, and my battery would already be at 50% since I always forgot to charge it the night before. By lunchtime, that meant I’d be essentially phoneless. Now, it’s pretty much automatic. I put my S8 on the wireless charger as soon as I get in and when the LED turns green, I take it off.
The Samsung Premium Wireless Charger deserves 5 stars.
Nowadays I don’t need to charge my smartphone at night, which is great for my health since I always put it on my bedside table. When I get off work, the battery is at 100% because, thanks to its practicality, my desk has been transformed into a phone charging station. Since I never have any free space, the dock has now become my S8’s home when I’m not using it.
As for cost/benefit, Samsung’s Premium Wireless Charger deserves 5 stars.
