LG G3 Lollipop problems and how to fix them
lg g3 lollipop
A few carriers have now delivered the Android 5.0 Lollipop update to the LG G3 in the US and elsewhere. The first bugs are now raising their ugly heads, causing complaints, frustration and distress. We're here to set those issues at ease with our list of LG G3 Lollipop problems and solutions.
lg g3 lollipop
The Android 5.0 Lollipop update on the LG G3 has caused some issues. / © ANDROIDPIT
LG G3 battery drain
This problems is about as common as they come, so don't fret. Almost every phone suffers from battery drain immediately following a firmware update. The first thing to do is turn your phone, leave it for 30 seconds and reboot. If that doesn't clear it up, try clearing the cache.
To wipe the cache on the LG G3, go to Settings > Storage > Cached Data and confirm. If that still doesn't help, back up everything on your LG G3 (we recommend you download Helium for PC and install Helium on your phone if you don't have root access) and then doing a factory reset.
AndroidPIT LG G3 Android 5 0 Lollipop clear cache
Clear the cache in settings, or do a backup and factory reset with Helium. / © ANDROIDPIT
To factory reset the LG G3 go to Settings > Backup and Reset > Factory Reset Phone. This will wipe all of your apps and data and reboot your phone fresh. Once it has finished rebooting, restore your apps and data from your backup and everything should be running smoothly.
If your phone won't even start up properly following the update, from an off-state, press and hold Power and Volume Down until you see the LG logo, then quickly release and re-press the same buttons until you see the factory reset screen.
g3 screenshot
If your G3 won't even start, press and hold Power and Volume Down to Factory Reset it. / © ANDROIDPIT
LG G3 lock screen notifications
This is just a straight-up mess on LG's behalf. Following the Lollipop update you can only access two lock screen notifications. You know, one of the coolest things about Lollipop in the first place. You also can't swipe to expand or double tap to open the notification.
Why LG has chosen to do this we don't know, but the quickest solution is to install a lock screen notification app to replace the Lollipop feature until LG sorts it out. The uproar has been sufficient enough that we expect it's being worked on right now. We'd recommend Dynamic Notifications as your lock screen replacement.
AndroidPIT LG G3 Android 5 0 Lollipop lockscreen notifications
Lollipop lock screen notifications on the LG G3 (left) are limited to two unexpandable notifications. Dynamic Notifications (right) shows you multiple messages. / © ANDROIDPIT
LG G3 poor performance
This is another common problem following an update: sluggish or irregular performance. The best way to clear this up is with a quick factory reset. So, as mentioned above, do a full backup of your data first and then reset either through the Settings menu or with the hardware button method outlined above.
LG G3 screenshot problem
The ability to swipe up to take a quick snapshot with QMemo+ has also been removed following the update to Lollipop. Now the only way to screen grab is to use the hardware buttons: press Power and Volume Down at the same time until you see the screen flash.
androidpit lg g3 screenshot 2
Take a screenshot by pressing the Power and Volume Down buttons simultaneously. / © ANDROIDPIT
LG G3 home screen widgets are jumpy and laggy
Sadly, there's no quick fix for this other than removing your widgets until the problem is fixed. You can try a reboot or factory reset and described above, but this seems to be one of those problems with no quick solution.
LG G3 no silent mode
This feature removal from Google has quite a few people irritated, regardless of which device you own. Fortunately, a simple widget exists called Silent Mode Lollipop to turn silent mode on or off direct from the notifications shade. It's still the easiest way we've found to bring back silent mode on the G3.
AndroidPIT LG G3 Android 5 0 Lollipop silent mode
Silent Mode Lollipop lets you finally shut all sounds off on your LG G3 with Lollipop / © ANDROIDPIT
LG G3 restricted profiles
This is another weird oversight by LG's engineers. Somehow the ability to set details for a restricted profile (or Guest Mode) didn't seem important enough to bother with in the LG G3 Lollipop update.
Now you can simply decide whether phone calls are allowed or not, but not choose the apps that can be accessed by a guest. There is sadly no fix for this problem until a patch brings the function back.
AndroidPIT LG G3 Android 5 0 Lollipop Guest Mode calls
Guest Mode on the LG G3 with Lollipop loses app controls. / © ANDROIDPIT
LG G3 high RAM usage and overheating
The LG G3 is also reportedly suffering from unusually high RAM consumption following the Lollipop update. This is also contributing to more heating than is normal as well. A factory reset has resolved a lot of the overheating issues I've read about.
High RAM usage is fixed by going into your G3's Settings > Apps > Running tab and checking to see which apps are consuming the most RAM. Just tap the offending apps and Stop the processes.
AndroidPIT LG G3 Android 5 0 Lollipop running apps ram usage
In the LG G3's settings you can see which apps are using the most RAM. / © ANDROIDPIT
You can also install an app like System Monitor to keep an eye on RAM usage and shut down processes that are causing the problem. Google is also reportedly pushing a patch for the memory leak in the Android 5.0.1 Lollipop update so keep an eye out for that.
What Lollipop problems are you getting on your LG G3? Do you have any other solutions?
Go to comment (44)
44 comments
    NRGT86 Dec 31, 2016 Link to comment
    Hello, I have an lg g3. The screen doesnt work after boot loop. When having boot loop, i hard reset my phone and it solved the problem. But now, the screen sometimes responding sometimes not. Please help. Thanks
  • Koua Vang 1
    Koua Vang Mar 10, 2016 Link to comment
    The only issue i have is the overheating issue and the wifi hanging issue when scanning and away from wifi and the slow sluggush issue that occurs once a whil when playing HD (ex.GTA)games. Batery life is better. -LG G3 D850 AT&T Lollipop 5.0.1
  • Chilli 1
    Chilli Oct 16, 2015 Link to comment
    I've two major problems with my G3:
    1) Bad mobile receiption plus frequent hangs during network search driving mobile network availability down .
    2) Android keeps kicking out apps from memory without any reason. Memory leaks could be an explanation but what helps a Lollipop 5.0.1 fix if it's not available for G3? I will try cyanogenmod but if it does not help I'm done with the G3.
  • AnooshaAbruption 1
    AnooshaAbruption Jul 24, 2015 Link to comment
    Finally got the update and so proceeded and it took 6 hours to update and now my phone won't even turn on. Well this is super convenient and exactly what I need /(-______-)\
    Donna Henthorn Jul 1, 2015 Link to comment
    Play Store, Minesweeper and Mahjong all stopped working. Why do I still have this phone?
  • Andrew 1
    Andrew Jun 20, 2015 Link to comment
    I enjoy most of the features added in the Lollipop update, but here are some of the issues I'm experiencing.
    Phone will switch itself out of vibrate mode if certain actions happen. I believe making a call or answeing a call is what does it, but I'm not entirely certain if that's the case.
    Running Chrome using the new tab system will sometimes lock Chrome up to a state where it won't function at all until all Chrome tabs are closed and the app is fully restarted.
    My biggest issue is:
    If I lock the phone while viewing a conversation in the messaging app, I will not receive any notifications for messages received by that contact (no vibration, no sound, no notification on lock screen). I have to remember to go back to the home screen before locking the screen to avoid this.
    David Stephens May 1, 2015 Link to comment
    Updated my G3 to 5.0.1....not so much looking for a fix as wondering if anybody else's phone has volume problems after the update? My ringer volume drops out and cannot be turned up unless I reboot the phone....really an inconvenience, especially if you are expecting a call.
      Ray H Jul 1, 2015 Link to comment
      I am having the same problem.....can't find a fix yet....and I don't know when the ringer is going to randomly stop working and I have missed calls because of it....
    jdog7747 May 1, 2015 Link to comment
    I like everything in the new update EXCEPT for the fact that I don't get any pish notifications on my LG G3 it is a VERY annoying problem that I hope is fixed soon.
    A Cole Apr 30, 2015 Link to comment
    How do I remove this HORRIBLLY ANNOYING lollipop update from my G2? I hate it to the point I deactivated the phone. Verizon and LG are no help whatsoever. Now it is religated to being an alarm clock. I HATE LOLLIPOP!
    assd
      A Cole May 2, 2015 Link to comment
      Deactivated the phone because I hate it now because of the update. To makers of the update GO FUCK YOURSELF WITH A CACTUS!
      assdRyan Torncello
        assd Jun 5, 2015 Link to comment
        Yeah same here, YOU CAN GO FUCK YOURSELF WITH THIS UPDATE taken away notifications on lock screen, flashlight widget, green led on front no longer works, homescreen doesn't rotate so much more, I FUCKING HATE MY PHONE NOW, FUCK YOU!! FUCK YOU!!!!
  • RuBa Sawalha 2
    RuBa Sawalha Apr 24, 2015 Link to comment
    How i can back to the previous update ??? i HATE this one !!!
    denisem0720
  • RuBa Sawalha 2
    how i can back to the previous update plllllllllls !!! i HATE this one
    Luis Saavedra Apr 20, 2015 Link to comment
    Im having Wi Fi issues. Its so slow it has become unusable. Im getting a bit less than 1mbps. How do I fix it?
      Phil Apr 29, 2015 Link to comment
      To fix some issues, if you don't use Google+ you can disable that, didn't see much difference when I did that. Google webview on the other hand fixed a lot of things for me. Just disable webview in app manager and that might fix your WiFi problems.
    Kings Hockey Apr 19, 2015 Link to comment
    wth, now i dont get notifications from any apps. Takes the email app hours to even know there is an email waiting to be opened. Should have gotten an apple.... at least they dont fuck up this bad
    MinDah Le'Lumiere Apr 16, 2015 Link to comment
    Um yeah , big problem for me for this android update..my phone can never get to play music again after making a call ): . i gotta restart the phone everytime i make a call ... Someone please help!
    Unclephilly72 Apr 16, 2015 Link to comment
    Updated to Lollipop yesterday...so happy...wait a minute...what the heck is going on with the slow internet speed.
    Wifi connection extremely slow. Like 5 years ago slow. 4g is super fast, but as soon as I switch to wifi...snailsville. wth? anyone have a fix? I already did a factory reset.
    Brandon SmithKings Hockey
      Brandon Smith Apr 26, 2015 Link to comment
      I have the same issue. I can clear cache by removing my battery and I will have excellent WiFi speed for a limited amount of time. Soon my phone is right back to the slowest WiFi speed I've ever experienced. 4g works great no matter what I do. The system storage option to clear the cache does not help the issue. Has anyone figured out a solution to this problem?
Show all comments
