- 1 Always on AMOLED for that Samsung feel
- 2 Hi Locker for affordable customization
- 3 LokLok turns your lock screen into a fun messenger
- 4 CM Locker for no-nonsense functionality
- 5 Exercise your grey matter with Semper
- 6 AcDisplay for minimal elegance
- 7 C Locker Pro knows a few shortcuts
- 8 DynamicNotifications saves you power and stress
Jump to:
- Always on AMOLED for that Samsung feel
- Hi Locker for customization
- Loklok for doodles and messages on the lock screen
- CM locker for serious security
- Train your brain with Semper
- AC display for the minimalist feel
- C Locker Pro is full of features
- DynamicNotifications for power saving
Ever wanted that always on lock screen typically found on Samsung smartphones? Well, now you can have it no matter what device you have. Always on AMOLED is not really a lock screen per se, but it does emulate one. It can show the clock, notifications and various other things. You do have to hand over an excessive amount of permissions to the app to get it to run, however, and it an LCD screen doesn’t really do it justice but if you’ve got an OLED display it’s a cracker.
Hi Locker’s offers a CyanogenMod-style quick launcher that works by holding and swiping over to one of your favorite apps to quickly open it from the lock screen. It has 3 styles of lock screen: classic, Lollipop and iOS, and a separate screen dedicated to your calendar, where you can quickly view upcoming events. It’s got a decent array of ways to customize it, too, including custom greetings, different fonts, and automatic wallpaper changes.
Hi Locker usually costs 2 bucks, but as it’s currently on sale, it’s well worth installing for free and taking it for a test drive.
INSTALL (mobi.appplus.hilocker)
LokLok is a fun idea, but your friends need to get involved too if you want to get the most out of it. LokLok lets you draw on your lock screen and then send the drawing as a message to a friend who uses the same app. This message will then appear on their lock screen for them modify and send back to you, if they wish.
Loklok is free to try and fun, so definitely worth a shot. IAPs exist for extra features like sticker packs.
CM Locker has a slide-to-unlock function, à la iOS, as well as power-saving feature that cleans out batter-draining apps directly from the lock screen. You can choose to use a pin or pattern to unlock your device, and there’s an intruder alert feature that will take a photo of anyone who unsuccessfully attempts to unlock your phone. It’s a no-nonsense screen locker that lets you control your music playback, view recent messages and check the weather forecast and it comes highly recommended.
The app formerly known as UnlockYourBrain turns unlocking your phone into something quite valuable. It uses the 80 or so times you unlock your phone every day to keep your brain ticking using simple maths and vocabulary exercises. Does this mean you can’t access your phone if you don’t know what 12 x 8 is, or what ‘el amigo’ translates to? No, thankfully UnlockYourBrain lets you skip questions and access your phone anyway, so no pressure.
Plenty of lock screen apps go for a minimal look, but none do it quite as well ad AcDisplay. Small icons appear for notifications, and you simply hold your finger on one of these icons to see the notification in more detail, after which you swipe down to dismiss it. AcDisplay even uses your device’s sensors to detect when it’s in your pocket or in use, so the screen switches on and off accordingly.
C Locker Pro is a sizable lock screen package that offers a ton of features and shortcuts to refine your lock screen. There are more than 30 custom shortcuts you can create to make calls, access apps or read notifications from your preferred social networks. One of our favorite options is being able to double- or triple-tap your screen to turn it off – a feature usually reserved for high-end phones.
INSTALL (com.ccs.lockscreen_pro)
DynamicNotifications is a subtle lock screen app that’s easy on the eyes as well as on your phone’s battery. By default, it has a plain black background, and notifications only switch your screen on when the phone is not in your pocket, bag or face down. This app doesn’t actually have to be used as a lock screen, but the option exists if you buy the premium version (US$1.99). You can customize what what happens to notifications when you swipe them, and also set a ‘night mode’, in which you won’t receive notifications when you’re asleep.
INSTALL (com.greatbytes.activenotifications)
Are there any lock screen apps that we missed out? Let us know, then maybe they’ll make it into our next lock-screens list!
Zui locker and Snaplock is cool
My phone recently upgraded from Lollipop to Marshmallow. I like my native lock while I was on Lollipop. Once the update to Marshmallow happened, Marshmallow crapped up my lock screen. While on Lollipop I was using a pin which had the nice clear circle numbers which still allowed me to view my lock screen wallpaper (of my family). Marshmallow has put this ugly white/opaque box in place of the clear circular numbers and that is the native lock screen under Marshmallow. I was trying to find a replacement lock screen but most of the ones I have tried are free with the native Lollipop lock screen features but with a boatload of ads. I attempted to pay for a few but none had the feature set I wanted. Any help here would be greatly appreciated.
Forgot to mention that CM lockers provides an fingerprint option if your mobile has a fingerprint 😀
When ever I remove my main lockcreen (to prevent having two lockscreens.) My phone gets glitchy and doesn’t work properly. I tried all kinds of lockers. But on s7 edge, When u put the lockscreen password on ‘none’. I think it causes some kind of a glitch. Just putting this comment here in case other ppl run into same issue. They know why it is happening. I didn’t know it was the lock screen at first I had to reset my phone and re install all apps one by one until I realized something is wrong with the system when you remove your lock screen.
the lightest (in background data) and the most efficient security is probably the one you’re phone came with….
great having options but a lot of these apps have advertising and compromise security for the features they offer… I tried a few and now I’m happily back to stock Moto display and stock Nexus lock screen.
Yep, and way too much advertisements. More than 3/4 of apps on Google Play are full of ads. It is so annoying but these developers rather annoy than offer it without. That is just more reason I will not keep their apps on my phone and I will never rate more than a 1 star either for the darn ads. Wish someone could let me know if there is one without ads that does slide unlock like the iphone, so I do not have to try every single app and get infested with ads.
please try Lock Screen Iphone Lock
Any one’s that let’s you use your fingerprint scanner for security
I have never used any screen locker after reading this article I will also give a try. Best one which is inbuilt.
Well put together article. I have found Good Lock. Why not listed love it to bits.
I think Lock Screen – Iphone Lock app is the best. My phone now is a Iphone
How about No Pause Lock on google play. It simply allows you to lock your phone without pausing active app
I use Pin Genie Locker. It is great that nobody can see my password!
All the above Lockers are same nothing different why don’t to post different and cool apps
wait…Are you telling me that an article titled "best android lock screen apps" only shows apps that lock your screen? this is some new level BS!!!
Lock Screen – Wallet theme is what I use. No pin(i really don’t need one) but looks really cool. And its very simple to use.
***EDIT: Sorry their recent version does have a PIN lock. It has to be activated from settings…lol…
Personally, I do not use lockouts, I’m not their follower, because they can do a thing: bothering me because I rearrange icons, change menus and overwhelm all settings, and unfortunately I have to test each screen and menu to get used to new settings. It’s frustrating for me to do that.
Obviously, as people who prefer to be "in agreement with fashion," call the phone depending on the clothing, depending on the season, and why not, depending on the person or persons you have an important meeting!
I suspect there are apps that automatically change the background, depending on the season, or change randomly. It is very interesting how to turn a phone with these applications, changing the look.
People, you should try Tap Locker, it supports widgets and has some great unlock features.
I have used Hi Locker and you know what, its simply amazing. The other one which I have tried is Dynamic Notifications – I must include "What an amazing lock screen" Thumbs up to both app devs for creating these Apps
CM Locker clock was the best app for me. Other apps were also very useful.
