wifi problem on my archos 43.
navin
Nov 7, 2011, 7:49:22 AM via Website
hi guys
The wifi works fine in the start but gets disconnected after not being used for a while.
After it gets disconnected it doesnt seem to get connected back.
The device just keeps scanning and disconnecting.
can anyone help me out?
Aaron Tilton
  • Forum posts: 834
Nov 7, 2011, 2:48:30 PM via Website
Hi Navin!
I don't have an Archos 43 myself but I did some asking around and apparently a lot of wifi connection issues are caused by the powersave feature on the device which automatically disconnects the wifi to save power under certian conditions.
Try this:
Go into settings> wireless and networks>wifi settings> and then longpress your wireless connection.
You should get a menu which will let you disable you power save for your connection.
Hope that helps!
Android News I Android Apps I > App Center
