Samsung Galaxy A5 and A3 (2017): here are all known problems and solutions
AndroidPIT Samsung Galaxy a5 2017 4814
Technology has its issues. Like all devices, the Galaxy A3 (2017) and A5 (2017) have their share of problems that can sometimes spoil the experience a little. Of course, these devices aren't exploding like the Note 7, but there are some are minor problems which happen to some users. Fortunately, we have the solutions for you here.
The battery drains very quickly
Problem
Several users have reported the following problem on the Galaxy A3 (2017) and A5 (2017): the battery empties in just a few hours. The strength of the A5 being its battery life, it's all the more irritating.
Solution
If the loss of battery life seems really drastic, your phone likely has a defect - because the battery life of the A5 (2017) is well above the average. The A3 (2017) isn't bad either. It normally allows you a full day of use, including social networking, surfing, video and more. But, if you only get a few hours out of it, you've got a problem.
Go into the battery settings to see which applications are consuming the most energy to find the culprit. Some applications can work in the background, and, if they are poorly optimized they can seriously drain your battery.
AndroidPIT Smartphone Overheating 2588
Smartphones and batteries: will they ever get along? © NextPit
The fingerprint reader doesn't recognize your fingerprints
Problem
Some fingerprint scanner are quite finicky, but it is difficult to make a generality because several factors come into play: the way you registered your fingerprints, the condition of the finger, and so on. Several users have complained about the fingerprint scanner of the Galaxy A5 (2017), especially my colleague Jessica who had noted a big problem with it in her review.
Solution
In most cases, the problem comes from the user: make sure you have registered the fingerprint from various angles, in the same position as when you try to unlock your phone. This seems silly, but many users simply put their finger on the scanner during configuration, without swiping it correctly. Also, remember to keep your finger dry.
It seems from reports that the A5 (2017) is more affected than the A3 (2017). That said, it is still possible (in theory) that Samsung could offer some kind of an update to fix the problem.
AndroidPIT Samsung Galaxy a5 2017 4851
The fingerprint scanners of the A3 (2017) and A5 (2017) do not always work well. © NextPit
The device does not connect to the computer
Problem
Normally, your computer detects your Galaxy A3 (2017) or A5 (2017) phone when you connect it using a USB cable. But, sometimes the phone is not recognized by your computer.
Solution
First of all, you need to use a quality cable (either from the manufacturer or another reliable brand). If you don't see anything on the screen when you connect the phone, don't panic. Look at your phone: maybe it has detected the connection is prompting you about what to do next. If you still do not get any response from the device, check out the developer options (see how to enable them in this article) and enable USB debugging.
The WiFi connection is unstable
Problem
You are connected to the Internet with your Galaxy A3 or A5, and all of a sudden the connection is interrupted. This problem occurs from time to time (and not just on this model). It's difficult to determine the exact origin of the problem with this one.
Solution
Samsung has not communicated anything official about this problem, at least for now. This kind of issue is difficult to diagnose as there are several factors that can cause it. If you are sure that the problem is with the device and not with the connection (which is rather unlikely), check your network configuration and update your apps. Keeping your apps up-to-date to ensures their stability. If the problem persists, leave us a comment.
AndroidPIT router wifi 2
The problem sometimes comes from the router. © ANDROIDPIT
The touch screen is unresponsive
Problem
The touch screen of the phone leaves something to be desired, and sometimes you get no response from it at all. Navigation is complicated on the Galaxy A3 (2017) or A5 (2017) and sending messages seems to be an impossible mission.
Solution
The problem can be with the device hardware: if you have just received your phone, then it may have a defect, and if it has been dropped, that's another very likely cause of the trouble. It's difficult to do much yourself in this case, so get it repaired.
If the problem is software, simply restarting your phone may be the fix (it worked for me, in any case). If you are a more advanced user, you can try installing another ROM to see if this fixes the problem, but be sure you won't void the warranty first!
Did you encounter any other problems with these devices? Need help? Leave a comment below!
Go to comment (45)
45 comments
    hippy Feb 7, 2022 Link to comment
    lack of internal storage,it is showing full but when you delete any thing it still shows full
    Marat Dec 30, 2018 Link to comment
    I was just given a Samsung A5 for Christmas and I found it so horrendously difficult for what I needed that I just gave up and threw it in the trash. I mean, seriously, am I really expected to read through and learn the whole 125-page online manual just for a portable phone? Computerization is now just making things too difficult, not better. I prefer the old days when nothing was more complex than finding a public phone, opening the door, putting in your coins, and talking into the receiver. It doesn't take 125 pages to explain that, now does it?
    Bob W Dec 2, 2018 Link to comment
    Hello, I've had my Galaxy A5 2017 for a couple of days. All is well except the actual telephone only works with the earplugs plugged in. Without there is no sound and the person on the other end can't hear me, but the call time is ticking so there's a connection, and when the speaker is activated, the phone works as normal. Any suggestions why the phone doesn't work as normal? Anything I can do to remedy this?
  • Youness.Ziaee 1
    Youness.Ziaee Oct 30, 2018 Link to comment
    Hello support team.
    I have A320F(A3 2017)
    After Install Last Version Of Android(Android 8.0-Samsung Experience Version 9.0) In All Time (Always):
    1_The off Pixels On LED Has Ligh and it's Copletely Visable (It's Completely Vasable On Always On Display In Dark Place)
    2_It's Very Hard To See Movie On Mobile In Dark Place.
    The Colors Are Mixed Up And Details of the dark sequences of the movie can not be seen.
    * There were No Problem Before The Install Last Update.
    The Corresponding ROM Was Manually Installed On The Two similar devices (Two A320F) And Both Of Them Have This Problem.
    Attached information.
    Please Answer And Help Me.
    Thank you.
    uziaee@gmail.com
    Lisa Hardy Mar 18, 2018 Link to comment
    Hi, I have the samsung galaxy a5 2017 version the past month or 2 sending & receiving texts has been a hit or miss process. Now the last few days when anyone calls me they tell me my phine echoes. I don't hear it but, they can hear themselves talking.
    Any idea how to resolve these 2 issues?
    Farid farid Jan 12, 2018 Link to comment
    Hi i am using samsung A5 7..this phone whatsapp and imo any using app send voice message not send 3 seceand Above...what soliusiion iits problam
  • Chris Elliott 1
    Chris Elliott Jan 8, 2018 Link to comment
    messenger does not work correctly. Flashes when trying to make a video call and cannot accept any video calls and screen just continues to flash. Tried re-installing messenger but that did not work. anyone else experiencing this problem?
  • Gustavo Luiz 1
    Gustavo Luiz Oct 27, 2017 Link to comment
    My A5 2017 needs to have its proximity sensor recalibrated almost every day. Any suggestions on how to fix this?
    • Paul D. 2
      Paul D. Dec 18, 2017 Link to comment
      After the Android 7 Nougat update? With Android 6 the proximity works correctly. I have no fix at the moment
      • Gustavo Luiz 1
        Gustavo Luiz Dec 18, 2017 Link to comment
        Yes, it was with Android 7, but there was a Samsung update recently and I had not to recalibrate for a while since then. If anything changes I'll comment here and update.
      • Paul D. 2
        Paul D. Dec 22, 2017 Link to comment
        I have tried the firmware update and the problem still persists. I had to roll back to Android 6 to get rid of it again.
      • Gustavo Luiz 1
        Gustavo Luiz Dec 22, 2017 Link to comment
        Hey Paul, I just tested my sensor and it is not working again. If it works rolling back to an older version of Android it probably means that this problem is not related to a Samsung firmware failure, but rather to some incompatibility between the newer android and that firmware. Perhaps we should try and report this issue and information to both Samsung and Google
      • Paul D. 2
        I believe that it's Samsung's issue and they are not aware of the problem with Nougat.
  • Milda Lechny 1
    Milda Lechny Oct 1, 2017 Link to comment
    Have A5 2017 and have problem with wifi signal. Maybe know why. If i lput my second hand on top of phone (viewing internet, watching youtube, playing games etc.) and hold phone with both my hands, the signal is almost imidiately much more worst, sometimes lost. Whe i get hand out, its return to strong signal of wifi. Its really bad and problém with construction. Maybe its only my phone, dont try another one.
    • Zain Ali 2
      Zain Ali Feb 20, 2018 Link to comment
      same problem in my phone
  • cree 2
    cree Sep 4, 2017 Link to comment
    i have A5 (2017) over 2 months and sometimes it just turn of and i noticing it when i need to use it and screen is black. Few times pushing all buttons and nothing. Sometimes i feel short vibration when i hold 'turn on' button for few seconds. In the end i hold 'volume down' and 'turn on' buttons for 8-10 sec and it tun on. And today was odd situation, somebody calls me and i take phone and screen is black and cant turn it on, but ring tone is working...
    • Zain Ali 2
      bro i have same problem
      • cree 2
        cree Feb 20, 2018 Link to comment
        Also i had problems with charging and battery lasted just 1 day with medium power saving, after night 10-20% off, but now after few Android updates, everything works prefect. I don't need to charge battery every day even when i play online games, and don't turn it off by it self.
  • IHaveProblem 1
    IHaveProblem Sep 1, 2017 Link to comment
    Look +-5 comments down, there is my comment with urgent problem.
    Danial Khaledi Aug 2, 2017 Link to comment
    I have got screen flashing problem, specially when puting brightness to low, it flashes a purple color. also screen wont turn on sometimes and i try to turn it up for few minutes by pressing power button many many times and that is really annoying.
Show all comments
