Common Nexus 5 problems and how to fix them
androidpit nexus5 problems 16
Now that the Nexus 5 has made the jump to Android 6.0 Marshmallow it's time to take a look at some of the issues the update brought with it and how to fix them. No Android update is perfect and, as always, there is no shortage of Android Marshmallow problems to work through following the jump to Marshmallow. Let's take a look at some common Nexus 5 problems and how to fix them. As more people get Marshmallow on their devices, we'll add to the list of solutions and workarounds.
How to fix Nexus 5 Android update problems
The problems below generally relate to the latest version of Android, but some are persistent bugs that have carried over from older Android versions. The solutions will be the same for whichever version of Android you're using, however.
Solutions to Android Marshmallow problems should work for the same problems in Android versions too. / © ANDROIDPIT
But keep in mind that some bugs will have been patched in later Android releases, so make sure you have the latest firmware available for your device before you try anything else. Go to Settings > About Phone > Software Update to check whether there's an update available.
Jump to a specific Nexus 5 problem and its solution by hitting the links below:
But first, back everything up
As always, you should always make sure you have a done full backup before you start troubleshooting Nexus 5 problems. You can follow our guide on how to back up Android or make use of Google's default backup option, which can be found in the settings under Backup and Reset.
androidpit nexus5 problems 14
The Nexus 5 is to battery problems what peanut butter is to jelly: inseparable. / © ANDROIDPIT
Nexus 5 battery drain
As with all Android updates, battery drain is usually the most immediate problem you'll have to deal with. So if you're suffering Nexus 5 battery drain following the update to Marshmallow, never fear. You're not alone. Fortunately the solution is quite simple.
You have three options: clear your app cache, clear your system cache or do a reset. These are guaranteed to clear up any Lollipop leftovers that might be causing excess battery consumption. The first step is to clear your app cache. To do this you can go to Settings > Storage and USB > Cached Data > OK.
androidpit nexus5 problems 2
The first cache you should clear is the app cache. / © ANDROIDPIT
If your Marshmallow battery drain persists, the next step is to clear the system cache. Turn your Nexus 5 off, press and hold Power and Volume Down to access the Fastboot menu and use the volume buttons to highlight Recovery Mode. Press Power to select.
You'll see the robot with No Command beneath it. Hold Power and press Volume Up once to access Recovery Mode. Use the volume buttons to highlight Wipe Cache Partition and press Power to confirm. Highlight Yes and press Power again. Once you've wiped the system cache you can reboot.
androidpit nexus5 problems 3
The next stop is your Android system cache. / © ANDROIDPIT
If you're still having Nexus 5 battery problems after the cache wipes, your next step is to back up all of your important data – you can follow our guide on backing up Android – and then do a factory reset, either through the Backup and Reset section in the Settings or via Recovery Mode. Then just restore your apps and data and your battery drain problems will be history.
androidpit nexus5 problems 4
A factory reset is the one solution to rule them all. Just back up first. / © ANDROIDPIT
Nexus 5 Wi-Fi problems
Another staple of the Android update problems buffet is all-you-can-eat Wi-Fi connectivity problems. This was a very common Lollipop problem and an equally common KitKat problem, so it's par for the course. If your Nexus 5 Wi-Fi connection is not stable or won't connect at all, there's a few things you can do: toggle Airplane Mode on and off, forget and reconnect to your Wi-Fi network, toggle mobile data on and off, or reboot your phone.
androidpit nexus5 problems 8
You might be surprised by how much toggling Airplane Mode can solve. / © ANDROIDPIT
Another possible solution is to change your Wi-Fi frequency from automatic to either 2.4 GHz or 5 GHz in the Advanced Wi-Fi Settings on your device or to change the frequencies on your Wi-Fi router.
  • Enter your router address into a web browser on a device that's connected to it (usually 192.168.1.1 or 192.168.0.1).
  • Enter your router login details (you can find a long list of default router passwords here)
  • Each router varies, but you'll want to go to the Wireless settings menu (possibly by clicking through Settings or Advanced Settings first), choose the 2.4 GHz or 5 GHz band, then select a channel
  • As a general rule, channels 1, 6 and 11 tend to work well, while channels 12 and 13 are best avoided.
androidpit nexus5 problems 5
Try switching the Wi-Fi frequency on your phone and router. / © ANDROIDPIT
Nexus 5 stability issues
If your Nexus 5 is behaving weirdly after an update, you first need to identify the source of the problem. Work your way through the list of fixes here and see if clearing the cache, looking for the culprit in your installed apps or rebooting solves the problem. If they don't you need to figure out what to blame for your Nexus 5 stability problems.
To see if an app is causing the problem, boot into Safe Mode – easily accessible by long-pressing the Power button and then long-pressing Power Off. Safe Mode disables all downloaded apps so you're only working with what Google gave you and nothing else.
androidpit nexus5 problems 6
Safe Mode will help you diagnose either apps or Android as the source of a problem. / © ANDROIDPIT
If your problems disappear in Safe Mode you know it's an installed app problem and not Marshmallow-related. The next step is to reboot again (to exit Safe Mode) and then systematically disable apps to find out which one is causing the problem.
If the instability isn't app-related you can start with a reboot. Turn your Nexus 5 off and wait for a minute before turning it back on. If that doesn't help follow the steps in the battery drain section for clearing cache. Your last solution is to factory reset your Nexus 5 or manually install Android Marshmallow.
Nexus 5 won't charge
Android 6.0 Marshmallow is intended to deliver prolonged battery life to the Nexus 5 and for the most part, it does. But strangely enough, charging has become a bit of an issue for some users following the Android Marshmallow update.
androidpit nexus5 problems 12
Charging problems seem to be plaguing Nexus 5 phones on Marshmallow. / © ANDROIDPIT
Google's solution to this problem is to do a factory reset, but before you go to that extreme you can try a few of our general charging tips to make sure it isn't related to something else:
If none of these general guides help you out, you should also try to calibrate your Android battery before doing a factory reset. Having said this, a factory reset is nothing to be scared of. It is a very useful technique for maintaining good smartphone health. As long as you back up first you've got nothing to lose and everything to gain.
androidpit nexus5 problems 7
If your battery is behaving strangely, you might need to calibrate your battery. / © ANDROIDPIT
Nexus 5 Bluetooth problems
Just like Wi-Fi connectivity, Nexus 5 Bluetooth problems generally rear their ugly head following most Android updates. The solution here is about as scientific as it is with Wi-Fi problems: toggle things on and off, forget and re-add connections, jump into Airplane Mode and back out again, and generally just fiddle about. Nine times out of 10 that will solve your problem.
androidpit nexus5 problems 9
Updates frequently wreak havoc on Bluetooth connections too. / © ANDROIDPIT
If you're still having Bluetooth connectivity problems, either dropouts or problems connecting in the first place, then you might want to contact the maker of your Bluetooth device to see if it might be related to any associated software. Occasionally all you need is an update to the drivers to solve the problem, depending on the type of Bluetooth device to which you're connecting.
Nexus 5 lags on Marshmallow
If your Nexus 5 lags on Marshmallow, the best thing to do is back up your data and do a factory reset. Some problems are worth fine-tuning, while others require the carpet-bombing approach. Doing a factory reset after a major Android update will clear up 99 percent of the problems that commonly plague users.
Lag or excessive battery drain are so detrimental to your Android experience that doing a reset is definitely the best option. Simply follow our guide on how to create an Android backup and then go to Settings > Backup and Reset > Factory Data Reset > Reset Phone. Once your Nexus 5 has been wiped and restarted, you can restore your apps and data and enjoy a lag-free Marshmallow experience.
androidpit nexus5 problems 11
Lag means general slowness when launching apps or navigating Android. / © ANDROIDPIT
General Nexus 5 problems
If you don't know what's causing your Nexus 5 Marshmallow problems, then there are a few things you can try that might help. First up, turn your phone off for a minute and then turn it back on. Toggle Airplane Mode on and off. Forget and re-add Wi-Fi and Bluetooth connections. Calibrate your Android battery.
Try Safe Mode to see if an app is the culprit. Make sure your apps have all been updated since you updated your Nexus 5 (there are lots of Marshmallow-specific updates coming out for apps at the moment). Try disabling or uninstalling apps systematically to rule app problems out.
androidpit nexus5 problems 13
If you have no idea what's wrong you can still run through some common solutions. / © ANDROIDPIT
Next, try to clear the app cache and the system cache (as outlined in the battery drain section). If neither of those works you can try a factory reset. If that still doesn't help you can manually install Android Marshmallow on your Nexus. If you're still at a loss you might have a genuine Google problem on your hands that will require an official patch to solve.
What problems are you experiencing? Have you found any other solutions to these Nexus 5 problems?
Go to comment (60)
60 comments
    Floyd3000 Mar 14, 2019 Link to comment
    Google usage and diagnostics turning off automatically when I back out of the page and return to see it turning on in front of my eyes . what's up?
    Google usage and diagnostics turning on/off automatically I can visually see it returning to the page. What's up?
  • parthasarathy srinivasaraghavan 1
    parthasarathy srinivasaraghavan Aug 9, 2018 Link to comment
    My Google Nexus 5 is not booting and messaging " unfortunately UI has been stopped" Please let me know how to fix this problem
    mehr Jul 14, 2018 Link to comment
    hi,my nexus 5 can not turn on?
  • Anker Yang 1
    Anker Yang Nov 20, 2017 Link to comment
    It is good and I have written another article about how to fix Nexus 5 Wi-Fi Problems, learn more here:etradesupply/blog search fix Nexus 5 Wi-Fi problems
  • Mohamed Busneina 1
    Mohamed Busneina Jul 9, 2017 Link to comment
    I am facing battery drain problem, and I am trying your solution, I'll let you know if it worked with me ,, thank you
    • Brittany McGhee 21
      Brittany McGhee Jul 12, 2017 Link to comment
      Thanks, Mohamed. We look forward to hearing if it worked for you.
  • Bob McArthur 1
    Bob McArthur May 10, 2017 Link to comment
    my Nexus5 is locked on the opening screen {firmware update} and it was plugged in for 12 hours. the screen is locked and on/off ,volume + / - are both locked . HELP what is going on?
    Shoiab Mohammed Mar 21, 2017 Link to comment
    I am using nexus 5 for 3 year,but the wifi wont turn on do you have a solution for it
    I have tried rebooting,format,turning wifi on and off
  • Ġorġ Sciberras 1
    Ġorġ Sciberras Dec 15, 2016 Link to comment
    Having a problem with Photos. There is something that stops me viewing my photos. Notice pops up at random.
    Uma Narasimhan Sep 16, 2016 Link to comment
    Hello everyone!!
    I have been using nexus 5 for past 2years . First i faced the problem of power button.. from oct 2015 whenever I touch power button it reboots automatically. So from then I didn't use power button ( increased my display timing) . Now I'm facing a different problem.. my volume button keeps appearing on my screen ..even though I didn't touch it. Quite annoying as I'm unable to watch Facebook or movies. Can anyone help me with this issue?
  • Bruno Cunha 2
    Bruno Cunha Jul 20, 2016 Link to comment
    The Power button and the vol down works. But after "You'll see the robot with No Command beneath it. Hold Power and press Volume Up once to access Recovery Mode" does not work to get back to recovery mode. I'm with the latest update
    Taha Kidwai Jun 16, 2016 Link to comment
    Hey have u guys noticed overhrating problem on nexus 5. It overheats when i play high graphic game Please suggest any solution for it
  • LaftanZa 1
    LaftanZa Mar 1, 2016 Link to comment
    The power button has a manufacturing fault and it sometimes gets stuck and the phone keeps rebooting!
      ZrillexZ Mar 4, 2016 Link to comment
      yeh, my nexus keeps on turning off when i'm in the middle of doing stuff, do you know if there is a fix or do you think i should be looking into a new phone?
      • 16
        Viktor jovanović v. Apr 4, 2016 Link to comment
        Yry to clean cashe and uninstal some apps which you don't need to get more storage.
        I slso have Nexus 5 2013 and haven't any problems with it. Good lyck.
  • Priya Surana 1
    Priya Surana Feb 27, 2016 Link to comment
    Hie all
    I am using nexus 5 since last 1.5 yrs. But from last 20 days my phone is not catching 3g, although airtel 3g recharge has been done. Also network dropping issue is there. I have done everything. factory reset, network reset, preferred network -3g, LTE, Flight mode on off....... but its s till 2g. though my sim is working finr in other phones, connecting to 3g and no connectivity issue. But in nexus 5 its not catching 3G. Can anybody help me in this?
    Needhi Feb 17, 2016 Link to comment
    Hi
    I have been using Nexus 5 since more than 1 yr ,suddenly my phone got switched off , checked with LG gallery , they says it's a mother board issue , only solution is the replacement of mother board , which cost around 13000
    How can it happen all of a sudden
    Really upset with it
    Kindly suggest what can be done
      Sandeep Arya Apr 4, 2016 Link to comment
      I am having US made motherboard which I will give u for Rs 7000. Contact no is 9911033522.
  • Kayla 1
    Kayla Feb 16, 2016 Link to comment
    What about boot loop???
Show all comments
