How to Open SIM Card Tray Without a SIM Tool
nextpit how to open sim slot hero
Do you recall the location of your SIM ejector tool? Those small metallic items that sometimes accompany a new phone? If you're like me, the answer is probably no. However, there's no need to worry. I've ingeniously managed to access the SIM card tray and microSD card slot on numerous occasions without the official tool. Let me share several effective methods for opening the SIM card slot without needing a specific ejector tool.
Earring or piercing
The right tool for the job might be closer than you think, as in on your body. Traditional earrings with thinner wires or hooks work best. On others, you might need to unscrew the ball/spike on the end. More extreme piercings might be too large to serve as SIM tray openers. (Be careful not to bend your earrings!)
a person opening a SIM slot with an earring
Earrings are the most common and simple DIY SIM tools around. / © nextpit
Paperclip
Probably the next most common thing, if you happen to work in an office. Not the fat plastic-coated paperclips, but pretty much any small metal paper clip will get your SIM tray ejected. And when you're done, you can use it to attach various bits of paper together.
A person opening the SIM tray with a paper clip.
It looks like you are trying to open a SIM tray! / © nextpit
Needle
If you repair socks and pants as much as I do (you don't want to know), then you'll have a needle floating around the house somewhere. Just use the not-pointy end in the SIM eject hole and press down on the edge of a table. I'd advise you not to try this using your hand. But desperate times call for desperate measures!
A person opening a SIM tray with a needle
Often, a needle will just do the trick. / © nextpit
Thumbtack/staple
Another ubiquitous object that you may find in most homes and offices is the humble little thumbtack. There are many shapes and sizes, but pretty much all of them are capable of opening your SIM tray. If you're embracing innovative approaches, then you've probably realized that you could also use a staple.
Safety Pin
A safety pin is very ubiquitous and found in nearly every household. Thanks to its sharp, pointed edge, it makes for a great sim tool. The fact that its design allows for more force to be (safely) exerted makes me think the safety pin is a better sim ejector tool than needles.
Toothpicks
Now, this is an option that can be used as a last resort if none of the objects above are at your disposal. But you'd be already aware that most toothpicks aren't thin enough to be inserted into the tiny SIM hole. To get around this, you might be required to whittle away some buts towards the bottom using a knife.
A person opening a SIM tray with a skewer
Yes, we were able to open the SIM tray with this monster toothpick. / © nextpit
Once again, if none of these things is an option, just look for any pointy thing you have lying around—and if you still failed in your mission, it's time to get to a store for a solution.
Go to a store and ask nicely
If you ever find yourself needing to eject your SIM card tray while on the go, as I have, one of the most convenient solutions is to step into a nearby shop. Admittedly, if you're deep in a forest, this might pose a challenge, but in a city environment, surrounded by shopping centers or storefronts of mobile phone carriers, there's no cause for alarm.
During my last visit to a cell phone shop for this very reason, I encountered an accommodating staff member who sported a SIM tool as a necklace. He was more than willing to assist me with my dilemma at no cost.
Do you have any other secret SIM tools to share? Please let us know in the comments.
Go to comment (24)
Benoit Pepicq
Benoit Pepicq
Benoit is passionate about new technologies and everything related to computers. A big Android fan since 2011, he joined the AndroidPIT team to satisfy his passion and to share his knowledge on Android with readers.
24 comments
    Immy Nov 19, 2020 Link to comment
    I cannot eject the sim card holder from my new Xiaomi Mi Note 10 Lite. No ejector supplied and nothing else works
  • F.Alam 7
    F.Alam Jan 1, 2019 Link to comment
    Thanks
    Brittany McGhee
  • Waqar Ghafoor 7
    Waqar Ghafoor Sep 7, 2018 Link to comment
    I usually do it with needle :)
    Brittany McGhee
  • Rusty H. 33
    Rusty H. Sep 6, 2018 Link to comment
    Got one on my keychain, but in a pinch, a paperclip always works.
    Brittany McGheeSorin
    • Brittany McGhee 21
      Brittany McGhee Jul 19, 2019 Link to comment
      Paperclips are my favorite alternative, too!
      Rusty H.
    sixpack Jun 28, 2018 Link to comment
    fuse wire!
  • 27
    Sorin Apr 5, 2018 Link to comment
    I used a paper-clip because I was not willing to buy a special device to remove the card!
    marco sarliBrittany McGheeDeactivated Account
  • Rusty H. 33
    Rusty H. Feb 18, 2018 Link to comment
    LOL, I've always used a paper clip. But, a phone I got several years ago, came with a sim tool, so it's always on my key chain.
    marco sarliBrittany McGheeSorin
  • 26
    Andrew Burgin Feb 18, 2018 Link to comment
    Why couldn"t Samsung use the Bixby button to open the sim tray,as not many blokes carry needles or pins with them
    HaleyJ1008ElfynSorin
    Tom S Feb 17, 2018 Link to comment
    I have always carried about 3-5 paper clips on my wallet. When you work on Tech Support for several years, you carry them for when a CD/DVD rom won't open the easy way or any other type of situation. Nowadays I wear a bracelet that has a sim picker tool. Anytime I see someone trying to pick the sim out, I pull a clip from my wallet and I get a Mcgyver comment.
    SorinRusty H.
  • 46
    Deactivated Account Feb 17, 2018 Link to comment
    One more reason why I like the removable battery the sim card was always under the back cover no tools needed
    ElfynSorin
    john cocktosen Jan 26, 2018 Link to comment
    My moto g5 plus tray will come out with NOTHING but the friggin tool, which of course EVERYONE LOSES. Why in the world would they engineer it so?
      Abby Nov 5, 2020 Link to comment
      so you have to buy one from them!!!!
  • chuuchu 2
    chuuchu Jan 11, 2018 Link to comment
    Should've come up with a better method to insert the SIM card. It's gonna be annoying when you have to open it up but you can't find anything to help.
    Rusty H.john cocktosen
    • Rusty H. 33
      Not only that, but the SIZE of the cards have gotten so small, you can lose one without even trying, if your card is on the side of the phone, and you don't know which side is up, if you don't have your hand on it, or over a table. ;)
      ElfynSorin
  • Brenda Chilson 1
    Brenda Chilson Jun 12, 2017 Link to comment
    Does anyone else think it is a stupid setup? New phone did not come with one, Verizon gave me one, put it on my keychain, lost keys a week later...first time ever in my life doing that! AND does anyone know what to do when the Samsung Galaxy battery quits and needs replacing, since who knows how to get to that. I used to think prying the whole back off the S4 was stupid, but this is worse.
    • Mats Engelsvoll 1
      Mats Engelsvoll Nov 4, 2018 Link to comment
      I bought a cheap Huawei because the screen on my S4 is broken, but shit, I think I'll stay wit hthe S4 as long as it still works. Prying the back is a pleasure. Easy and you can use anything. The ejection tool thing is just completely unnecessary.
  • Joe Hiltabidel 2
    Joe Hiltabidel Feb 17, 2017 Link to comment
    A toothpick grips the tray after releasing it and pulls it out like prom night.
  • Vince Garcia 1
    Vince Garcia Nov 17, 2016 Link to comment
    The paperclip worked like a charm. Thank you.
  • Ash Veen 1
    Ash Veen Nov 17, 2016 Link to comment
    Mechanical Pencil worked like magic .
    baba yaga Aug 13, 2016 Link to comment
    Mechanical pencil works perfectly
    Ronie Rea Jan 23, 2016 Link to comment
    This is not a reply to the comment on the paper clip being stuck in sim hole...although thats a tricky one considering you cant really see down inside that well. I lost tool to unlock sim card tray... I used an earing, it unlocked but did not open much at all.. Maybe a centimeter. So i used two razor blades and used sharp edges to grip both sides of tray and pull while my husband held phone on counter top.. Sure enough it came out after hours of trying before thinking about razor blades.
    Adam Regan Jan 16, 2016 Link to comment
    I have a part of a paper clip stuck in my sim hole. What do I do to get it out?
    • Jason Elliott 1
      Jason Elliott Feb 17, 2017 Link to comment
      Did you try a magnet to get it out?
