How to fix screen burn-in on your AMOLED or LCD display
Ghost image or screen burn-in are names given to a permanent discoloration of your smartphone’s screen caused by irregular pixel usage. The prolonged use of static images can create a permanent shadow or ghost of that image on the screen. This problem is more common than you think and happens most often on AMOLED screens (although LCD displays aren’t always immune). Fortunately, there is a solution to restore the image quality of your device.
The screen ghost happens when phosphor compounds that emit light to produce images lose their intensity with prolonged use. Moreover, the irregular use can "burn" an image onto the screen which will be visible all the time.
burnin1
Does this look weird to you? This is how you'll fix the issue / © NextPit
Many apps are available in the Google Play Store promise to reduce or even stop the problem. You'll want an app that's compatible with your display type.
For LCD screens: there's a dedicated app, LCD Burn-in Wiper. However, this tool is not suitable for OLED or AMOLED displays, such as those found on Samsung Galaxy devices. For that, you'll need a different app.
For OLED/AMOLED:
The concept is simple: a sequence of primary colors is displayed on your device, restoring the "burnt" pixels. In fact, this was the original function of computer screen-savers: one dynamic image that appears when the screen is idle to makes the pixels "exercise" and ensure that the same area of the display doesn’t remain constantly illuminated.
Has your smartphone ever have this problem? Did you use another app to fix it? Let us know in the comments.
Latest articles at NextPit
Recommended by NextPit
27 comments
  • Ken 11 months ago Link to comment
  • marco sarli
    Good to know
  • I just came up with a fix to the screen burn-in for Amoled device. The longer you use it, the more pronounce the buurn-in trace. I could easily recognize the problem, so I went there and take a screenshot of the problem, saved it and looked for an app to revert the image. From Play Store I found one, Negative Image, (there are several, but I was happy with this one).
  • Sorry Storm that is no correct. I use my phone all the time and not for gaming and I have screen burn in from the task bar at the top which some Idiot at samsung thought was a good idea to leave it on permanently. Previous phones let the task bar disappear if not used.
  • storm Oct 4, 2018 Link to comment
    • I have screen burn-in from G-Board, and despite keeping my phone's brightness at around 70%, I've now twice had the keyboard burn-in to my phone. I'm either a novelist that for some inexplicable reason writes stories on their phone for hours on end, or there's an underlying fault within OLED or Gboard. I'll leave it up to you to decide which of the two scenarios is more rational.
  • Never had the problem on my LCDs, because of quick screen blackout setting and using KeepScreen only for active apps. I'd guess it mainly affects gamers and long video watchers who have top and bottom elements always on during play. I recently learned about and tried this currently inactive app to full screen over that fringe area, and found it works surprisingly well on a new Android N tablet:
  • Nice LOIE FAVRE , Downloaded and I am Enjoying the App, Thanks For Sharing
  • "Hey, my screen shows burn-in! Why is that?" -- "Well, some pixels on the screen are worn out more than others. Especially the pixels that mostly show brighter colors age quicker." -- "I see. Can I fix it?" -- "Yes, you can. Just download an app that destroys the better pixels until you don't see the difference anymore!" And that, folks, is how you get people to download an app which systematically destroys the screen.
  • Enjoyed the Omni, now it's time to learn!
  • This stuff needs a freaking epilepsy warning, God Damn
  • Is this a permanent fix ?
  • Works on LG G5 (confirmed) I had a Snapchat chat burned partially into my screen. I let this run while I slept when I woke up I checked it and it was fixed. Thanks alot definitely didn't want to drop another $400 on a g5
    • eekoh Jul 20, 2017 Link to comment
  • Thanks for verifying it works ! Going to try it on my old note 2 tonight
  • That did happen to me yesterday, i installed the app, and definitely worked for me, i had to let it run more than 8 hours, it's worth trying, trust me, i had the doubts, it really works
Show all comments
