Have a problem with WhatsApp? Here are the solutions
WhatsApp is one of the most popular messaging apps out there - with over 10 percent of the global population actively using it every month. Given this volume of use, it's clear it gets a lot of things right, but today we will be concentrating on what it gets wrong. Here are some of the most common WhatsApp problems on Android and how to solve them.
I can't install WhatsApp
In order to download the latest version of WhatsApp, you need to have a smartphone running Android version 4.0.3 or above. You can check your phone's current Android version in Settings > About Phone. WhatsApp also recommends having an unlimited data plan (or Wi-Fi). Note that WhatsApp does not officially work on tablets.
If you're trying to install the WhatsApp app from the WhatsApp website on your Android phone, you'll need to make sure the Install unknown apps option is checked on the browser you're using. In case you use Chrome for Android, this is how you can enable it.
  • Open Settings, scroll to Apps, and tap.
  • Scroll down to Chrome (or the browser you're using to download WhatsApp).
  • Scroll down, and look for Install unknown apps under Advanced.
  • Toggle the option to ON.
Install Unknown Apps
If you're installing WhatsApp from a website, make sure the 'install unknown apps" option is enabled on your browser. / © NextPit
If you're an iPhone user, make sure you're running iOS 10 and above. iPod and iPad devices are not supported. You can download WhatsApp for iOS from the Apple App Store.
I didn't get my activation code
If the installation went smoothly, but the automatically generated message with your activation code never comes through, first ensure you entered your number correctly. Double-check that you chose the right country from the drop-down list. This is the country your phone number is from, not necessarily the country you reside in.
If you still do not receive the code, try requesting a voice call. This way you will have the code read to you by a computer over the phone.
Remember, you have to have a SIM card to register for WhatsApp. Also, you can only use one device per phone number.
whats app receive sms confirmation code
It sounds obvious, but make sure you used the right number and international dialing code. / © NextPit
I can't sign in to WhatsApp, WhatsApp not working, or WhatsApp is down
WhatsApp connection problems are usually caused by your Wi-Fi or network data connection. If you aren't able to send a message, here are a few solutions:
  • Make sure your phone is switched on (one for the newbies)
  • Install the latest version of the app from the Play Store (link above)
  • Check your internet connection, Wi-Fi, or 4G (in Settings > Wireless and Network)
  • Make sure that a Task Killer app isn't affecting WhatsApp
  • Empty the app cache (Settings > Applications > WhatsApp > Clear Cache)
  • Finally, the most extreme solution: uninstall the app and then reinstall it
While uncommon, WhatsApp does experience occasional server issues. If you think WhatsApp isn't working because the service is down, head over to the WhatsApp Status Twitter account, or DownDetector where outage updates are provided.
WhatsApp doesn't recognize my contacts
On Android
There are a few reasons why WhatsApp wouldn't recognize your contacts, so here is a simple checklist to make sure it does:
  • Make sure you have the correct contact numbers (the ones they use for WhatsApp).
  • Make sure that they are currently using WhatsApp.
  • Make sure you have the latest version of WhatsApp.
  • If your contact is using a foreign phone number, make sure the number is stored on your phone using the full international format with the country code.
  • Make sure you have granted WhatsApp permission to access your contacts.
Note: WhatsApp no longer gives you an option called 'Show all contacts' which used to be a troubleshooting step on older versions.
On iOS/ iPhone
If you can' see contacts while using WhatsApp on iPhone, try these steps:
First, you need to ensure that you have granted WhatsApp access to your contacts. Here's how you can do that.
  • Open Settings and then tap Privacy.
  • Tap on Contacts
  • Make sure WhatsApp is turned on.
In case you see that WhatsApp is grayed out (or if it doesn't appear in privacy settings at all), you need to try these steps:
  1. Open Settings and then tap Screen Time.
  2. Go to Content and Privacy Restrictions and make sure that WhatsApp does not have any restrictions.
If these steps do not work, you might have to reset your iPhone.
Note that even if you do not provide WhatsApp access to your contacts, you will still be able to send and receive messages and change WhatsApp settings. You will not be able to see the contact names (just their phone numbers). You can also start new groups and broadcast lists.
In case some contacts are missing on iOs, here are some more steps:
  • For international numbers, make sure you have saved their contact in the correct international format.
  • If you're using iOS version 11.3 or above along with a Microsoft Exchange account, make sure your account administrator allows WhatsApp or other apps to access your contacts.
  • An alternative would be to copy your Exchange contacts into your phone’s address book or iCloud.
WhatsApp has duplicate contacts
While this problem has been largely eradicated through updates to WhatsApp, if you have duplicate contacts in your address book, it might persist in some way. Find out how to remove duplicate contacts in Android.
What does 'Last Seen' mean in WhatsApp?
The Last Seen timestamp tells you when a user was last using WhatsApp. This does not necessarily mean that they have read your messages, only that they opened the application.
When you're in WhatsApp and one of your contacts also opens it, you'll see their status change to 'Online', but again, this doesn't mean they're looking at your messages, just that they are using WhatsApp.
I can't see 'Last Seen' on WhatsApp
If you are unable to see the Last Seen timestamp in a conversation, it could be for a number of reasons. If you've disabled your Last Seen time in Settings > Account > Privacy > Last Seen, then you won't be able to see other people's Last Seen times, either.
whatsapp how to last seen feature
The 'last seen' feature can be easily turned off or on and even customized. / © NextPit
If the problem is only with one or some contacts, then it might mean that they've disabled the Last Seen time in their WhatsApp settings. If they're still receiving and responding to your messages, this is almost certainly the case.
The final reason is that a contact has blocked you. If your messages never get past the one gray tick, then this makes it more certain that you've been blocked. If you can't see changes to the contact's profile either, then you've certainly been blocked. Sorry to break it to you.
androidpit whatsapp single tick
No Last Seen timestamp and only grey ticks likely mean your (ex) friend has blocked you. / © NextPit
What do the blue checkmarks mean in WhatsApp?
There is a lot of confusion about what the two checks (or tick marks) in your WhatsApp message window mean. If you want a complete breakdown of all the markings in WhatsApp, take a look at our detailed What do the WhatsApp check marks mean? article, which also covers the microphone markings for audio messages.
Here is a quick summary:
  • The clock symbol means your message is yet to be sent from your device
  • One gray tick means that the message has been sent and has been received by the WhatsApp server
  • Two gray ticks mean the message has been delivered to the intended device
  • Two blue ticks mean that the recipient/recipients have seen the message. (In group conversations, this means when all participants in the group have viewed the message)
I have problems with voice calls or can't answer calls
If you are experiencing poor quality voice calls, dropouts, or you can't make or receive calls, it is almost certainly related to your connection. Voice calls are carried out over Wi-Fi or mobile data. Ensure your connection is strong. If you're using mobile data, you will need at least 3G. Perhaps also try disconnecting and reconnecting to the network. The problem might not even be on your end: the person you're talking with will also need to ensure they have a good connection.
whats app voice call
The quality of voice calls is subject to the quality of your data connection. / © NextPit
I can't hear audio messages or WhatsApp can't play audio
This could be related to the proximity sensor that WhatsApp relies on. It is found near the front-facing camera on your phone, and detects when you're holding your phone to your ear. If the sensor is activated, audio will play through the ear speaker very quietly. Ensure you keep your phone away from your face, and the audio should play through the normal speaker. Check to make sure the volume is turned up as well.
I can't download videos or photos on WhatsApp
Head to Settings > Data usage and see if you only have media auto-downloads enabled when you're on Wi-Fi. If they are, you will either need to connect to a Wi-Fi network or enable auto-downloads on mobile data and/or when roaming.
whatsapp data usage
These settings might affect your ability to download photos and videos. / © NextPit
The fallback, as is often the case, is to restart your router if you're on Wi-Fi and to restart your phone, as well.
WhatsApp is blocked in my country
If you're one of the unfortunate few to have WhatsApp blocked in your country, there is a way around the problem. Use a VPN. You can find out what a VPN is, why you need one, and how to get one here.
I can't save photos to send to another contact
The way this is done has changed. Long press on the image in the chat that you want to share, and at the top-right of the page, a right-facing arrow will appear. Press on this, and you can select the contact you want to share the image with.
whatsapp forward image2
You can easily forward photos in WhatsApp. / © NextPit
What should I do if my phone is lost or stolen?
First, lock your SIM card by contacting your carrier. This should always be your first step. Once this is done, WhatsApp can no longer be activated on that device. Once you have a new SIM (presumably with the same number) you can reactivate WhatsApp on your new phone.
In the meantime, send WhatsApp a message asking them to deactivate your account. Send an email with the subject "Lost/Stolen: Please deactivate my account" to support@whatsapp.com, and include your phone number (complete with international dialing code) in the email body. If you don't do this, WhatsApp can still be used over Wi-Fi.
AndroidPIT stolen smartphone 1608
Make sure you ask WhatsApp to deactivate your account if your phone is stolen. / © NextPit
"You may have new messages" notification
At times it may happen that you'll receive a notification from WhatsApp stating: "You may have new messages". You might be puzzled by this rather vague and cryptic message, especially when you open WhatsApp and don't see any new notifications. The explanation is quite simple! WhatsApp uses push notifications to inform you of messages but uses a different channel to deliver the actual message.
If you are in an area with a bad or low data / Wi-Fi connection, the network will be able to deliver the push notification but not the actual message. This problem occasionally occurs when you turn on the data saver mode on your smartphone. Now there might be an actual problem with WhatsApp that could cause this notification to pop up, but it's most likely related to a bad data connection.
How to save data on WhatsApp
Does WhatsApp chew through all your phone data in your daily use? Here's how to keep the hungry app under control.
  • Open WhatsApp
  • Touch the 'three dots' on the top right-hand side
  • Select Settings
  • Tap the fourth option, Data and storage usage
  • Select the third option, When using mobile data
  • Deactivate the four options (Photos, Audio, Videos, and Documents) and press OK
  • Scroll down to Low data usage and check the box on the right side
This disables the automatic downloading of any file type when using mobile data. This will prevent these files from being downloaded with your data plan. It will wait for you to connect to a Wi-Fi network in order to do so.
WhatsApp Messages don't send
If you can't send or receive WhatsApp messages, then the cause is usually a bad internet connection. But if you're positive that your phone is connected to the Internet, then try troubleshooting with the following steps:
  • Try restarting your phone or turning it off and on again
  • You need to complete the initial SMS verification process for WhatsApp
  • The number of the contact you're trying to message on WhatsApp hasn't been saved correctly on your phone
Generic fixes for other problems with WhatsApp
If you're having other problems with WhatsApp that aren't listed here, you might as well try these generic fixes.
Download the latest version of WhatsApp
In case you haven't turned auto-updating on, WhatsApp could act up if you are using a really old version. Make sure you are always on the newest version of Android. You can check if you're on the newest version by simply opening the Google Play Store and searching for WhatsApp. If you're not on the newest version, you will see an option to 'Update' the app here.
Clear App Cache
At times, cleaning the app cache can be a very good fix. We have a decided article where we deal this topic.
But if you're too lazy, here's what you need to do.
  • Open Settings and tap on Apps.
  • Tap on See all apps and find WhatsApp in the list.
  • Tap on Storage and cache and then tap clear cache.
how to solve buggy android apps delete cache
Sometimes, the clear cache option can work wonders! / © NextPit
What do you think of the advice offered in this guide? If you have anything more to add to this, do let us know. If you have more questions, you can check out our forum or leave your requests in the comments below. We'll also update this article with more solutions for your WhatsApp problems.
This article was last updated in June 2021. Older comments have been retained.
295 comments
  • I hava a problem with 2 of my whatsapp contacts.Their profiles just disappear and when i try send messages they only get 1 tick.At times it lasts for a whole day or a few hours.When this happens the same contacta also complain that they are unable to see my profile and all their messages only make 1 tick.What could be the problem? please help.
  • I continue to see messages from a blocked contact.
  • I am connected to my internet, but WhatsApp just won't connect, why is that?
  • Hello, Photos sent to my Wattsapp will not fully open, when I click on the photo a message displayed reads, This download was unable to complete, please try again.
    I do, but to no effect. Any suggestions, Thank you.
  • Hello. I need help. My old phone got broken and I wasn't able to log out on WhatsApp. I took my sim and moved it to another phone and redownloaded the app again. I had it before but I uninstalled it. After I downloaded the app, I can't log in anymore. It just said WhatsApp service is operating normally. I don't get the verification code either. Can't log in on my Mac because it's asking for a QR. What to do now?
  • Jwj 6 months ago Link to comment
    I have a android phone and what apps works fine but if the phone goes into standby mode and someone tried to phone me on whats app the phone does not notify me a call is coming in the caller just hears it riinging. But if a caller calls me direct not via whats app the calls come through. any ideas??
  • I have blocked 1 number from my WhatsApp, the problem is when the number I blocked suddenly is in my outgoing call list.
    is that a system problem?
  • julia 10 months ago Link to comment
    Reinstalled Whats App on my phone but most recent messages are 3 months ago, why
  • Wallis 11 months ago Link to comment
    When I click on the + to add a photo to a message the screen that appears is covered in black icons and is unreadable
  • rocky23 11 months ago Link to comment
    Thank you for sharing your thoughts. I really appreciate your efforts and I will be waiting for your next write. thank you once again<br />
  • I keep on getting this message when I try and add someone to a group. "You've added too many contacts to groups too quickly. Try again later." I use this groups for business purposes and need to fix it.
  • My WhatsApp account is saying it expired yesterday but won’t upload new one ‘as not currently available in your region’
  • after I receive a call when I hang up the number of calls increases on my app logo ie I have just rung off from paul and that was call number 6 then peter rings and when I have finished my call to him my logo now shows 7. how can I stop this.
  • when doing a video call the recipient gets a picture from me all broken up
  • imus May 27, 2020 Link to comment
    Hi, I cannot open PDF files on my phone WhatsApp. I can open images, audio or vidro files on whatsapp no problem. Only problem is with PDF files. But I can open PDF files on my email in the phone, problem only with WhatsApp. It says, "The download was unable to complete. Please try again later."
  • cant open received videos or photos
  • take a long time to open incoming videos or photos
Show all comments
