We use cookies on our websites. Information about cookies and how you can object to the use of cookies at any time or end their use can be found in our privacy policy.
androidpit Nexus 6P speed up
How do I speed up my 3G data?
  7. Reboot the device.
androidpit speed up 3g one
androidpit speed up 3g two
28 comments
  • User Oct 30, 2016 Link to comment
  • Doesn't really work like it says. My results of internet speed before applying this file are: Ping=49ms Download=81.3kBps Upload=150.6kBps
  • It's working 2day for me but now not working
  • For speed up in browsing in chrome there is a way, normally chrome uses 120 mb ram for browsing and this is in default settings, but this can be changed into 256,512,1054 as the availability of free space in ram. This is an experiential test so read the warnings in site, now open chrome browser and type "chrome://flags" hit ,see in the next page after scrolling more than forty notifications " default tile width " tap here on Default button and select your choice, then tap "#default-tile-width" and see below launch button tap to activate, then next see below the notification " default tile hight " do the same with this also. When need to cancel this open this site and at top see the button " reset all to default " tap here to go to default settings or open settings>storage>apps>chrome tap on this and tap to clear data. See the next way to increase speed in browsing, if you don't need images and surfing only for text you can disable image mode and enable text mode only ,for this go to above site scroll down for "Reader mode triggering" tap on Default and select choice then tap on #reader-mode-heuristics" and see below the launch button tap on to activate.
  • Thank you for the post!!! My speed literally increased!
  • Before 2 day I net recharge 3g but 2g going and how 3g doing me
  • Lot of time came unwanted apps I am useing browser it is correct ?
  • I use samsung galaxy s4..i cannot turn on the root explorer...I cannot paste the option file..please help me
  • google chrome data saver will also help to boost internet speed.
    • That doesn't actually speed your connection up, it compresses the data and allows you to use less data by running it through Google's servers. It will raise your latency as well.
  • its working :)
  • Thanks for replying, it's just really frustrating that if it does happen to be my carrier's fault, there is not much I can do about it right now because the one I use has the best plan I can get without having a contract, which is kind of important to me. But, they did pinpoint my exact location twice, and told me that I was in a great spot for full coverage, and when I still had a basic phone it worked fine. I tried having them send me refreshes, taking the battery in and out, etc., but to no avail. And my current phone will not send or receive MMS messages at all, and I haven't even bothered to let them know because I am so tired of the whole thing. I even have to use the WiFi calling in my house, then use the regular service once I am away from my house.
  • I have a Samsung Galaxy S III, and I can't seem to get good 4G LTE coverage no matter what I do. This is my third Android phone, and the one before this was the exact same phone, and had the same problem before it somehow got a virus and broke down. My one right before that was a Kyocera Hydro XTRM, and yup, no coverage, so I'm pretty much frustrated and annoyed with the whole thing, to the point where I'm not sure what to do anymore because everyone has tried everything to help me fix this problem.
    • Then is not the phone is the Carrier coverage. If 3 phones have failed it definitely not the phone.
    • The S III is the worst phone off all Samsungs. You will never get good 4G coverageand 4G LTE is a piece of junk. LTE light and like mean the cheapest 4G possible you will never get good coverage with an LTE phone and Samsung galaxy s3 is drunk getting s 5 or one of the brand new S6's..!! I hope this answers at least a couple of your questions. Good bless.!!
  • Before:
    Upload: 1.86
    Ping: 669
    After:
    Upload: 0.02
    Ping 282
  • will it work on 2G network ?
  • Ha, it works. Very nice.
  • My1 Oct 13, 2014 Link to comment
  • descarga 6,74 m
    carga 0,86
    ping 28 ms
    lg g2
  • WHAT A SPEED I HAVE GOT ....JUST SALUTE TO THIS ....
  • Thanks for this! Im not really sure how this works but my ping was drastically reduced from 650+ to just 52 (FIFTY TWO!!!) and went from 2MB/0.3MB to 5MB/0.3MB.
  • If your internet connection is slow, then you're not the only one. But, with this tip connection can be resolved and improved.
  • Loony Oct 13, 2014 Link to comment
    LG G2 CM11 O2 Germany
    Befor:
    Signal: 2 of 4 Bars
    Upload: 1.65
    Ping: 114
    After:
    Signal: 2 of 4 Bars
    Upload: 3.41
    Ping: 355
    Edit 17.10.14
    Did it again today.
    Signal: 3 of 4 Bars
    Upload: 4.88
    Ping: 55
  • My1 Oct 12, 2014 Link to comment
