androidpit Nexus 6P speed up
How do I speed up my 3G data?
  7. Reboot the device.
androidpit speed up 3g one
androidpit speed up 3g two
Review: Google Pixel 7
Go to comment (28)
Scott Adam Gordon
Scott Adam Gordon
28 comments
  • Joaquin Breslin 1
  • nt196140 2
  • 10
  • Jinka Varalakshmi 1
    its working :)
    • 12
      Corey Dorsey
    Before:
    Upload: 1.86
    Ping: 669
    After:
    Upload: 0.02
    Ping 282
    • 12
      Remove and reboot the phone.
      Corey Dorsey
  • Junaid Q. 17
    will it work on 2G network ?
  • Bojan M. 23
    Ha, it works. Very nice.
  • My1 37
    Scott Adam Gordon
    descarga 6,74 m
    carga 0,86
    ping 28 ms
    lg g2
  • 12
  • Loony 17
    LG G2 CM11 O2 Germany
    Befor:
    Signal: 2 of 4 Bars
    Upload: 1.65
    Ping: 114
    After:
    Signal: 2 of 4 Bars
    Upload: 3.41
    Ping: 355
    Edit 17.10.14
    Did it again today.
    Signal: 3 of 4 Bars
    Upload: 4.88
    Ping: 55
    Saem Sarguroh
  • My1 37
