Samsung Galaxy S5 Lollipop problems and how to fix them
s5 lollipop
The much-anticipated Lollipop update promises to make Android even more awesome - but for some Samsung owners it’s been a big disappointment. Forums are packed with reports of Samsung Galaxy S5 Lollipop problems. Here’s what they are along with the top fixes and improvements.
s5 lollipop
Here's what to do if Lollipop isn't lickable on your Galaxy S5. / © ANDROIDPIT
First things first
Before you install any major Android update it’s a very good idea to take a few sensible precautions. Dig out the login details for any online accounts you use - the update may reset your apps and require you put the details back in again - and give your Galaxy a good spring cleaning to get rid of any stuff you don’t need. Uninstall unwanted apps, update the ones you’re keeping, pare back your photo library and of course, make absolutely sure that you have backup copies of anything that matters to you. Most Android updates go perfectly smoothly but you should always expect the worst. That way, when it doesn’t happen you’ll be pleasantly surprised. Oh, and connect your Galaxy to the charger or ensure it has a full battery before you install the update.
Achieve peak performance
AndroidPIT Nexus 5 Android 5 0 Lollipop clear app cache
Clearing app data and caches can fix some crashes and performance issues. / © ANDROIDPIT
The most common post-update issue for any OS is sluggish performance, and you can fix that by removing app data and wiping the cache partition. The cache partition is where the OS stores temporary system stuff such as downloads, and if it get messy it can hit your phone’s performance.
App data first. Go into Settings > Apps and choose the app whose data you want to clear. Tap Clear Data and then Clear Cache to make it all shiny, and repeat for other apps you suspect are hogging space.
Once you’ve done that, turn off your phone and then press and hold the home, power and volume down buttons. Wait until the phone vibrates and the Samsung logo appears before letting go, and then use the volume down button to navigate to Wipe Cache Partition. Select that and go and do something else for a while - the process can be time consuming. Reboot your phone when it’s finished.
Still no joy? If the problem appears to affect specific apps only, uninstalling, rebooting and reinstalling is dull but often works, and there’s also the nuclear option of a full factory reset, which cleans the parts other settings can’t reach. Once again, it’s really important to ensure you have backups of any data you can’t afford to lose and that you’ve got a note of any logins and other key information.
Beat battery bugs
AndroidPIT Android 5 0 Battery Saver 3
Battery Saver is good, but it can mess with your Wi-Fi. Boo. / © ANDROIDPIT
If Lollipop is eating battery life, boot into Safe Mode by switching the phone off and then pressing and holding the Power button and volume-down button until the phone reboots. You can tell whether you’re in safe mode because if you are, the screen displays the words “safe mode”. Cunning. This disables third-party apps that might be draining the battery in the background, enabling you to see whether the problem is with Lollipop itself or more likely, an app that isn’t behaving properly.
It’s possible that even after disabling apps, your battery will continue to drain: we’re seeing unhappy Galaxy owners on Verizon and Sprint forums talking about too-fast battery draining. That one may require a Lollipop update from the network providers or from third parties.
Bad Bluetooth and wonky Wi-Fi
At the risk of sounding like a bored IT tech, have you tried turning it off and turning it back on again? A quick reboot often repairs mysterious connectivity issues. If your Wi-Fi is still wonky, pop into Settings and disable Battery Saver (if it’s on), and try forgetting the network you’re trying to connect to - but make sure you’ve got the password handy, because you’ll need it when you reconnect.
If all else fails…
galaxy s5 shine
If all else fails, you can make your Samsung shiny by downgrading again. / © NextPit
As much as we love Lollipop, if it won’t play nice on your Galaxy there’s no point in putting up with it. If you find yourself pining for the golden days of Android KitKat, there is a way to downgrade your phone again. Simply search for “Galaxy S5 downgrade from Lollipop to KitKat” and you’ll find stacks of how-to guides, but make sure you’re looking at the right one for your particular model and territory: there may be differences between Galaxy models and between different operators’ settings. It’s not particularly difficult or time-consuming but you’ll need to get your hands on the Odin firmware tool from Samsung and the correct firmware for your phone and territory, and you’ll need to wipe the phone’s data when you’re done.
Do you have a Galaxy S5 running Lollipop? Did it make your phone more lickable or are you desperate to downgrade? Let us know in the comments - and let us know if you’ve found any other great S5 tips!
Review: Google Pixel 7
Review: Google Pixel 6a
Go to comment (23)
Gary Marshall
Gary Marshall
Freelance writer
23 comments
  • Gunji Otaku 1
    Gunji Otaku Aug 13, 2016 Link to comment
    Why is everything white now... using more battery, thats a retarded design.. WTF I want it back to black ...
    Lisa Ann Aug 8, 2015 Link to comment
    when I change and save my lock screen and home screen pictures, at first they do save and stay, and then eventually they jus change back to something else on its own, please help me understand this and what if anything I can do
    mohammad hamed Jul 1, 2015 Link to comment
    The lollipop upgrade has literally ruined my S5 :
    The home button , back button and list button don't work most of the time and the device freezes a lot usually with no obvious reasons
    It is a total disaster and I am stuck with it and don't know what to do .'
      MikeT45 Jul 8, 2019 Link to comment
      Wowthat sucks
    Ëmir Àhmëd Ëş Jun 19, 2015 Link to comment
    I have Galaxy S5 SM-G900F The UAE model, whel will I get the lollipop 5 update ??
    Craig Goslan Jun 1, 2015 Link to comment
    Get a hammer, take your Galaxy device into your garden and smash your device to smithereens. Now buy a phone that actually works, just not an Android phone.
    Isaac Hook IV May 5, 2015 Link to comment
    My Galaxy Note 4 is now a disgrace. We literally had a firm device against iPhone users. Now we're the laughing stock of the phone world.
    Mustafa Nadeem Malik Apr 9, 2015 Link to comment
    I m nt receiving service messages after update :/ push settings nt available :/ : /wtf
    Wilson Ndebay Mar 28, 2015 Link to comment
    I'm not regretting downloading this update at all. it is working great on my S5. I never had to remove cache or perform any other operations to get it right. There is no such problem like battery draining, overheating, lagging, etc. In fact the battery life is improved and the performance is much better.
    Wilson
    John Mar 26, 2015 Link to comment
    If you download GO locker and open it up the third or fourth option is to disable system lock, that can help you out concerning those cases.
    Morgan Reed Mar 24, 2015 Link to comment
    My s4 crashed so Sprint gave me an s5. Within 10 hours of activation, it upgraded to lollipop. There are some really annoying features. Why do I have to choose a password, pattern, or fingerprint to unlock. Choosing "none" is not available.
    Jared Hines Mar 7, 2015 Link to comment
    Got Lollipop on my S5 this morning. Everything crashed afterwards. Phone constantly freezes, screen won't turn on when I press the power button for a second, consistently reboots then freezes. Took it to the Verizon store where they did a hard reboot which fixed the problem for about 10 minutes. Took it back in and they ordered me a new phone. Bad part is I without a phone until Monday. Definitely not a fan of Lollipop.
    Marvin Gumba Feb 24, 2015 Link to comment
    Or you could do what I did and install a ROM by LiquidSmooth that is Lollipop 5.0.2 and runs flawless and so much smoother than the stock ROM that comes with, in my case, the Note 4. So so happy now.
    Andrijana Scepanovic Feb 19, 2015 Link to comment
    I only have one complaint!! When I put my phone on silent, my alarm doest ring. Before, when you have it on silent, alarm will ring. Is there a way to have this fixed?
    Tesia Neilson Feb 18, 2015 Link to comment
    I am hoping the. BAttery saver will work. My phone is not charging correctly, and it won't hold a charge.
    I do not like the update as of right now.
    AnroidLover Feb 16, 2015 Link to comment
    Kelly,
    I had the same experience. My Galaxy S5 went haywire after the lollipop update. It has been lagging, draining my battery like crazy, heating up pretty bad, and overall performance has been just terrible. I am trying the fixes listed above, if they do not work, either I will roll back to Kit Kat or just reset it to the factory settings. Samsung shouldn't have released this update without fixing the bugs, now at least come up with the fixes guys ... for God sake
    Kelly Nay Feb 16, 2015 Link to comment
    This update reaked havok on my phone. Trying the quick fixes but my phone is still over heating and having connection problems. -_- smh Neither my provider or samsung would help. Switching to iphone after I get this paid off.
    WilZ Feb 15, 2015 Link to comment
    I did the update OTA thru Sprint. TG I haven't had any major issues thus so far so good. I like the new notification style. You're able to see messages, emails and other notifications from the lock screen. I think it lagged performance at the beginning, but the after I cleaned up the cache is running better. I would have prefer to keep the way it looked when ur closing apps instead of the window closing down. I think how Kitkat had it disolving in the middle it was a little more innovative. The one thing I dislike is how Lollipop for s5 changed the color scheme. It was a big difference from the old darker colors to the bright blinding white. But I am trying to get used to it. Hopefully in future version update it can give you options.
    It's improving in some areas, but I didn't have any issues with the way Kitkat ran or looked. It's always nice to get new updates though . Glad samsung and android is looking out to keeping up with its devices.
    I do recommend, to whoever is doing the update to check out the difference specs and looks before updating their devices.
    -Wil
  • Lee 16
    Lee Feb 15, 2015 Link to comment
    i've not had any issues or problems with lollipop my end UK Sim Free SM-G900F, it's been a vast improvement over KitKat, smoother, feels faster in performance, better battery life, and i certainly haven't had any WiFi or Bluetooth issues.
    I've found most problems are caused by the owner's not knowing there system or device, my friend also has lollipop and it was full of issues and bugs until I factory reset it for him and installed everything a fresh "no restore from a KitKat backup" in my experience starting fresh is best,
    update to lollipop, do a full wipe factory reset, setup as a new device to avoid having any issues.
    the only thing I hate about lollipop is the iOS style settings being white and bright 😕 but now I'm rooted and booted I haven't got to see the ugly lollipop UI with all it's white and light, bright backgrounds, plus there's no Sammy bloatware 😊
  • Ram * 4
    Ram * Feb 15, 2015 Link to comment
    When get Lollipop update for S5 SM-G900H in
    Indian variant any information please
      Ehan Feb 16, 2015 Link to comment
      Its already available, Go to sammobile and search it
  • 11
    Stuart Male Feb 15, 2015 Link to comment
    Haven't even got the chance to update yet. S5 G900i
    Kishin Feb 15, 2015 Link to comment
    Where do you access the new battery saver?
