How to speed up the Moto X Play
moto x play camera
Motorola’s Moto X Play is quite a snappy device, but upgrading it to Android 6.0 Marshmallow can take a toll on its performance. To list a few issues, the camera begins to lag, the gallery gets stuck and apps start taking longer to load. If your handset is suffering from any of these symptoms, read on for our advice on how to speed up the Moto X Play.
frentetelamotoxplay
A few tips and tricks can make a world of difference to your Moto X Play. / © ANDROIDPIT
Uninstall useless apps and files
First and foremost, you need to get rid of all those unused apps that sit idle in your Moto X Play and hog your CPU's resources. To uninstall unused apps, go into the Settings menu and follow these steps:
  • Go to Play Store and open the hamburger menu by swiping in from the left side of the screen
  • Hit My apps & games, then slide over to the Installed tab
  • Tap on the name of the app you want to remove, and then select Uninstall
  • Repeat for as many apps as desired
androidpit uninstall apps
Uninstalling apps that you don't use anymore can make your phone snappy. / © NextPit
You can also download an app called Unused App Remover, which can uninstall unused apps in bulk.
Clear the cache
Most apps store cached data locally so that you don’t have to download them every time you open the app. But over time, cached data gets piled up and apps begin to misbehave. In order to improve your Moto X Play’s performance, you can clear both the individual app caches and the system cache.
To clear the app cache:
  • Go to Settings > Device > Apps > All
  • Tap on the app’s name and select Storage
  • Tap Clear Cache to clear the cache. Be sure not to tap Clear Data by mistake because that will result in you losing user names, passwords and possibly important files.
androidpit clear cache
Clearing the cache can fix some lags in your Moto X Play. / © Androidpit
To clean the system cache:
  • Go into Settings > Storage > Cache.
  • Tap Clear Cache to clear the system cache.
Turn off the animations
You can also disable or reduce the window animations to speed up your Moto X Play. The whole purpose of window animations is to distract you while the system loads apps, but with a decent processor like the Snapdragon 615, you don’t really need that on the Moto X Play.
To turn off the animations:
  • Go to Settings > Developer Options > Window animation scale > Animation off
  • Go to Settings > Developer Options > Transition animation scale > Animation off
  • Go to Settings > Developer Options > Animation duration scale > Animation off
AndroidPIT animation off
Turning off animations will make your apps load faster. / © NextPit
If you don't want to turn off the animations completely, you can just reduce them to the lowest setting, which is .5x. This should also cut down the loading time of some apps and fix some stutters.
If Developer Options are not enabled on your phone, go to Settings About device and tap Build number seven times.
Factory reset your Moto X Play
If all the aforementioned tips and tricks have failed to speed up your Moto X Play, you can consider a complete factory reset. Before performing a factory reset, we advise you to back up your app data.
  • Go into Settings > Personal > Backup and Reset > Back up my data
There are two ways to perform a factory reset. This first is done through the device's software, as follows:
  • Go into Settings > Personal > Backup and Reset > Factory data reset
  • You will be required enter your pattern, PIN or password and then tap Continue.
  • Once you've done this, select Delete all.
ANDROIDPIT factory reset moto x play
A factory reset is usually the last resort to fix the software issues. / © NextPit
The second method uses your Moto X Play's hardware buttons:
  • Turn off your Moto X Play, then turn it on by pressing the power button
  • Once you see the Motorola logo, press and hold the Volume Down key unit your device vibrates
  • Once inside the Recovery menu, use the volume keys to scroll up and down and power button to select
  • Hold the Volume Up key for five seconds and wait for a new menu to appear
  • Use the Volume Up key to select Wipe Cache Partition
  • Your phone will restart and the same screen will appear
  • Select Factory Reset and then Delete All Data with the Power key
  • Once your Moto X Play formats itself, go to the next screen and hit the Power button to select Reboot System Now.
Untitled
Access the Recovery menu to clear memory partitions. / © NextPit
Has your Moto X Play become slower after the Marshmallow update? Have these tips and tricks boosted the speed of your device? Please let us know in the comments.
Go to comment (6)
6 comments
  • 11
    chayusiro Oct 26, 2016 Link to comment
    Thank you so much for your post. Phone Cleaner app helps us clean up junk files from mobile phones to free up more space on your phone and optimize the performance! http://www.android-data-eraser.com/android-data-cleaner.html
  • Alex 17
    Nice article!Loved to see an Indian Posting here!You rock!
  • 18
    Deactivated Account Feb 14, 2016 Link to comment
    Nice article but these steps are applicable for every Android device not only Moto X Play.
      arivendu Feb 15, 2016 Link to comment
      Yes.. These are generic steps to follow for every android device. Pls don't repeat the posts just by renaming the title... Of late AP articles have become quite repetitive.
  • Geometry Dash 2016 1
    Geometry Dash 2016 Feb 14, 2016 Link to comment
    Get it now In Google Play: Get it now In Google Play: Link--> goo*gl/2BzjJ1
    Geometry dash is the Best platform adventure for your Android. Enjoy the platform Awesome levels that we made for you!
    Geometry Dash this fun and amazing adventure game is better than ever and will surely be what you are looking for.
    Like side scrolling adventure that will rock you through 18 levels of challenging running and jumping.
    This retro-gaming classic will turn your Geometry dash - loving heart on end!
    To play you simple touch the screen to jump and touch quickly twice to double jump.
    You can jump over your enemies to kill them and your goal is to guide Geometry dash to the end.
    Download Geometry dash now! It is a fun game for everyone. Try it out and enjoy!
    • Explore beautiful and magical landscapes, with more coming soon!
    • Retro platformer/side-scroller gameplay
    • Fun Game
    • Addictive Game, Use with Moderation!
    • Lots of Challenging Levels
    • Great Graphics
    • Classic Runner Game Style.
  • Parvind Chahal 21
    Parvind Chahal Feb 14, 2016 Link to comment
    love u chandna pandey.....atlast i propose somebody i my life at valentine day
