Toni
With a few simple tools you can replace your Nexus 5 battery yourself. / © nextpit Image source: NextPit
All you need is a replacement battery for the Nexus 5 and a little plastic tool to help you pry open the rear battery cover. You should be able to pick one of these up at a craft store, or you can simply use a plectrum (guitar pick). You can buy a Nexus 5 battery replacement kit from plenty of online sources, but we picked one up from Amazon for under 20 USD (currently just 6.50 USD).
Note: I’m sure I don’t need to remind you that replacing a non-removable battery yourself is not recommended unless you’re ok with the possible consequences. While the process is very simple, AndroidPIT will not be held accountable if you break something. Please proceed with caution.
Externen Inhalt erlauben
Link to Video
1. First, you need to use the plastic tool to wedge between the rear cover and the edges of your Nexus 5. Make sure your phone is off first of course! Once you’ve levered the rear cover away the whole way around the edges you can pop it off.
IMGS8932
Using a plastic tool, or even a guitar pick, work your way around the edges of your Nexus 5. / © nextpit Image source: NextPit
2. Next, just remove the six tiny screws around the top part of the internal black plastic cover you find underneath. Make sure you don’t lose them.
IMGS8938
Once you’ve removed the six screws, pop the plastic cover off the top part. / © nextpit Image source: NextPit
IMGS8948
Gently lever the long orange ribbon off the component board. / © nextpit Image source: NextPit
IMGL8950
Then the smaller one. / © nextpit Image source: NextPit
5. Now, using the same plastic tool, work your way around the edges of your battery to detach it from the inside of the chassis. Take your time and don’t be too forceful. Eventually the bond will weaken enough and the battery will just pop out.
IMGL8955
Once you’ve levered the old battery out of its well, just replace it with the new one. / © nextpit Image source: NextPit
6. Now, place your replacement Nexus 5 battery in the chassis and gently reconnect the two ribbons to the motherboard (using your fingers here is easier). Replace the little black plastic cover and reinsert the six screws. Pop the rear cover back on and start up. That’s it, 2,300 mAh of fresh-out-of-the-box Nexus 5 battery action!
How’s the battery on your Nexus 5? Have you ever had to replace a non-removable battery before?
