Is Google Maps killing your battery? Here's how to fix it
google maps offline
Google Maps is a must-have app for pretty much every Android smartphone owner. But one of the issues we see rearing its ugly head every now and then is massive battery drain that occasionally gets attributed to Google Maps. In all fairness, some of these issues are not the fault of Maps directly, but rather fstem from functions that Maps uses. So what can you do to make such an essential app a little nicer on your battery?
google maps offline
We love Google Maps, but we like our battery life even more. © ANDROIDPIT
Clear cache/clear data
Sometimes battery drain issues associated with Google Maps follow an update to the app. If this happens, the simplest thing to do is clear the app cache and if that doesn't help, clear the app data as well. The second option will, of course, remove all of your saved Maps data though, so only do it as a last resort or once you've backed up your Maps data.
AndroidPIT Google Maps App Data
Simply clearing the cache in Google Maps can sometimes solve the problem. © ANDROIDPIT
Disable Location Reporting
Google loves knowing where you are. Not just for providing pinpoint accuracy on Google Maps but also for all the other nefarious ends that we like to get paranoid about. If you think providing Google with constant location updates is more hassle than its worth, especially where battery life is concerned, then why not switch it off?
AndroidPIT Google Location Reporting
Location Reporting serves a lot of purposes, but it also drains your battery. © ANDROIDPIT
Simply go to your Settings and Location and then hit the Location Reporting section at the bottom. You'll be brought to a Location Reporting section with settings for each account attached to the device. Of course, this will have effects on location sharing for social media and some Google Now functions.
AndroidPIT Google Location Reporting Settings
Keeping an eye on your Location Reporting settings is a must for better battery life.© ANDROIDPIT
Switch to battery saving mode
You can always turn Location off entirely, but if you need to have it on, make sure you have it set to a battery saving mode. Google loves high precision location data but using GPS, Wi-Fi, cell towers, triangulation, satellite arrays, biometric identifiers and who knows what else (I may have made a couple of those up) to pinpoint your exact location is a bit of overkill. Simply using Wi-Fi and mobile networks to do their job is sufficient for most circumstances.
AndroidPIT Google Location Mode
Set location to battery saving mode unless you really need high accuracy. © ANDROIDPIT
Turn off GPS
If you always have GPS enabled when using maps and you forget to turn it off afterward then you're going to notice severe battery drain. You're better off turning on GPS just before you use Google Maps and then turning it back off as soon as you're done. GPS may be super useful, but it's not nice on your battery.
AndroidPIT Google Maps GPS
Having GPS accuracy is nice, but not always necessary. © ANDROIDPIT
Downgrade Google Maps
If you're convinced that its the latest version of Google Maps that's causing the issue you can always downgrade to the last Maps version you were happy with. Some creative Googling will bring you the version history of Google Maps so you can simply pick the APK for the version you want and install it in place of the newer, problematic version.
INSTALL (com.google.android.apps.maps)
Does Maps drain your battery? How do you manage your Maps and battery life?
  Sponsored Editor's Choice
nextpit Tested
Go to review
Go to review
Go to review
Not yet rated
Not yet rated
Not yet rated
Not yet rated
Not yet rated
Not yet rated
- Windows, macOS, Linux
- FireTV
- Android, iOS
- Android TV, FireTV
- Android, iOS
- Android, iOS
- Android, iOS
- Windows, macOS
- Android TV
- Android, iOS
- Android, iOS
- Android, iOS
- Windows, macOS
- Android, iOS
Go to comment (2)
2 comments
  • CJ Brown 29
    CJ Brown Aug 30, 2014 Link to comment
    I think part of this issue was taken care of with the recent update to Google Maps (available download as of 8/30/14 ) in fact? The following updates are available at Google Play Store :
    Google Maps
    Instagram
    Facebook
    Yahoo Mail
    Adobe Reader
    Google Translate
    • Kris Carlon 35
      Kris Carlon Sep 1, 2014 Link to comment
      Haha, that'd be right! Hopefully there's no need for this article anymore then!
