10 ways to speed up the Galaxy Note 4
The Galaxy Note 4 is the undisputed king of stylus-equipped smartphones, but as time wears on it can gradually slow down a little compared to the blistering speeds it came out of the box with. So here are a few tips to speed up the Galaxy Note 4.
1. Ditch TouchWiz
If you caught our recent article on how to transform your Galaxy Note 4 into a Nexus 6, you’ll know that we rate using the Google Now launcher on the Note 4 in place of TouchWiz. Not only is it faster and leaner, it still lets you make use of those awesome S Pen features. Just install the Google Now launcher and press the Home button. Select Google Now from the list and tap Always.
AndroidPIT Galaxy Note 4 default launcher Google Now
Using the Google Now launcher (or any other launcher) is faster than TouchWiz. / © ANDROIDPIT
2. Use Download Booster
If your downloads always seem to take forever, the Galaxy Note 4 has you covered. Just make use of the Download Booster, which lets you simultaneously use both Wi-Fi and a data connection to download files at hyper speeds. Just make sure you’ve got the data plan to support it, and go to Settings > More Networks (in Connections) and turn on Download Booster.
AndroidPIT Note 4 download booster
Download Booster is a blessing for speed but a curse for your data plan. / © ANDROIDPIT
3. Clear up some space
Part of the reason your phone slows down over time is because you clog it up with so much junk. It won’t do your performance any damage to do the occasional purge. Move your music files to an SD card, delete apps you never even use, backup photos to the cloud to free up space and empty your downloads folder. Keeping your Note 4 lean and clean will also keep it fast.
AndroidPIT Galaxy Note 4 move apps images to sd card
Move apps to the SD card (left) or clear out your photos to speed things up. / © ANDROIDPIT
4. Ditch S Voice shortcut
You how it seems to take the Note 4 a while to actually return to the home screen when you press the Home button? That’s because the Note 4 has a shortcut to S Voice built into the Home button. One press for home, two presses for S Voice.
Turning this shortcut off makes navigating back to the home screen much faster because the Note 4 no longer hesitates to respond while it waits for that second press. Just go to the S Voice app and tap the overflow menu button in the top right. Select Settings and un-check the box for Open Via the Home Key.
AndroidPIT Galaxy Note 4 S Voice disable shortcut
S Voice has its uses, but not as a Home button shortcut. / © ANDROIDPIT
5. Update your apps
There’s a reason app developers frequently update their apps, especially when new versions of Android come out. Keeping your apps up to date gives you the best chance of having them perform at their best. So go to the Play Store app and select My Apps from the left hand menu. Update All is the button you want to press.
AndroidPIT Galaxy Note 4 Play Store update all my apps
You'll always have a few apps that could do with updating for a speed boost. / © ANDROIDPIT
6. Disable animations
Animations are those transitions between one screen and another. Like when a dialog box pops up or you unlock your phone and the last screen you were on appears. They look nice but they add to a sense of sluggishness too. While not a real speed boost, turning animations off gives a more snappy feeling.
Enable Developer Options by going to Settings > About Phone and tapping Build number seven times. Now, go to Settings > Developer Options and turn the settings for Window Animation Scale and Transition Animation Scale to Off. Set them to 10 first to see what they do before you turn them off.
AndroidPIT Galaxy Note 4 Developer Options disable animation scale
Turning off animations make everything seem faster too. / © ANDROIDPIT
7. Use Greenify
Even when you’re not using particular apps, many of them are running processes in the background. Sometimes this is useful, like syncing email or refreshing RSS feeds, but sometimes it’s just sucking up resources. Use an app like Greenify to freeze certain apps and hibernate processes until you actually need them.
AndroidPIT Galaxy Note 4 Greenify hibernate apps
Use Greenify to hibernate over-enthusiastic app processes. / © ANDROIDPIT
8. Identify the slowdown
Sometimes you simply don’t know what your phone feels so slow. In that case, and especially if your Note 4 has a Snapdragon processor, you can use Qualcomm’s Trepn Profiler to check real-time CPU and GPU loads, identify resource hogging apps and generally keep an eye on system performance. For even more cool apps, check out our list of useful apps for monitoring Android system performance.
AndroidPIT Trepn Profiler performance graph app profiler
Trepn Profiler will help identify why your Galaxy Note 4 is running slowly. / © ANDROIDPIT
9. Clear the cache
Every now and then it’s a good idea to clear the cache of your device, whether it’s the app cache or the system cache. App caches can be cleared individually in Settings > Application Manager by selecting the particular app and tapping Clear Cache.
All app caches can be cleared at once by going to Settings > Storage and clearing Cached Data. The system cache can be reset by rebooting into the recovery and wiping the cache partition from there. For the steps, follow our guide on how to clear the cache on the Galaxy Note 4.
If you think you've set some apps up that are acting badly but don't know which ones they were, you can go to Application Manager and tap the overflow menu in the top right and select Reset App Preferences.
AndroidPIT Galaxy Note 4 clear app cache reset app preferences
Clearing an individual apps' cache (left) and resetting all app preferences to go back to square one (right). / © ANDROIDPIT
10. Factory reset
You should use a factory reset as a last resort for serious performance problems, but also as part of general Android system maintenance, especially following a system update. Ensure you have all your apps and data backed up first, then go to Settings > Backup and Reset.
You can select your Google backup options at the top, then tap Factory Data Reset and then Reset Device on the next screen. Once wiped you can restore your apps and data and enjoy a smooth Note 4 once again. If you want the process that uses hardware buttons rather than the Settings menu, read our guide on how to factory reset the Galaxy Note 4.
AndroidPIT Galaxy Note 4 factory data reset Google backup
A factory reset is not just a last resort, but part of good phone maintenance. / © ANDROIDPIT
Any other tips to share for speeding up the Galaxy Note 4?
11 comments
  • Brian Howard Mar 21, 2019 Link to comment
    Trepn Profiler from Qualcomm is not to be found anywhere - NOT on PlayStore at all. Actually I could find NOTHING from Qualcomm on Playstore. Anyone know what's happened to this seemingly great app? I have searched far and high but now download facility or even mention of the app after 2016. Please help if you can - my Note4 needs you, it would be much appreciated. - Brian.
  • Rajdeep S. Feb 14, 2016 Link to comment
    Read it somewhere : Instead of restartng your phone occasionally [ if you do so ], enter safe mode and then restart the phone. Noticed some effect on battery backup.
  • Vikas Sharma Oct 22, 2015 Link to comment
    One of the best ways to speed up and improve the battery life of your Note 4 is to remove the SD card if any. Backup your pics and other stuff else where. Having pics or any media files on the phone or the SD card makes the phone continuously index these using up both the CPU time as well as the battery juice. Try it, you will be amazed at the improvement in the speed and juice. Also turn off all online backups, whether Google backup or Samsung backup. It uses up a lot of resources. Thanks
  • Lien Joren Jun 5, 2015 Link to comment
    I want install a game to my notebook laptop, and pleases give me all the free game
  • Maurice Jun 2, 2015 Link to comment
    I gave the Google now launcher a try, I find really disappointing compared to TouchWiz.
    I can't seem to understand why there should be something wrong with this samsung launcher, it just works perfectly well on my stock exynos note 4 and I did not notice any performance improvement when switching to the Google launcher.
  • StevetotheH Jun 1, 2015 Link to comment
    "Sometimes you don't know what your phone feels slow"? Are you using Google Translate to write articles Kris? I can't even....
    The 4th way to speed up..... answered the question I posted in my last comment. It appears that there is no such thing as proof reading articles before publishing. I hope you didn't get paid to write this Kris, spelled wrong.
    What does, "you’ll know that we rate using the Google Now launcher on the Note 4 in place of TouchWiz." mean? You rate using it? How do you "rate" using something?
  • Ruturaj Hagawane May 31, 2015 Link to comment
    And bext time buy exynos version.
  • Jaques Connard May 31, 2015 Link to comment
    Switching to the Google Now launcher loses quite a few widgets that I actively use... and, some widgets no longer work.
