Samsung Galaxy Note 4 vs Galaxy Note 3 comparison: how much better is the new flagship?
I hope I’m not spoiling anything by telling you that the Galaxy Note 4 is better than the Galaxy Note 3. It’s better. It really is. Good, now that’s out of the way I’m going to try and tell you the lengths to which it is a greater handset, and what you’ll be missing out on if you stick with the previous device in the series. Here’s our Galaxy Note 4 vs Galaxy Note 3 comparison.
note3 note4 comparison teaser
Side-by-side: The Note 3 (left) next to a slightly squarer Note 4. / © ANDROIDPIT
Galaxy Note 4 vs Galaxy Note 3: Design and build quality
The Galaxy Note 4 doesn't differ from its predecessor too much in terms of design. When viewed from the front, it's mostly the same as the Note 3 (albeit a little less rounded) in comparison, but on the reverse things have changed more noticeably, with the Note 4 sporting a slightly different textured, faux-leather back panel, this time without the fake stitching.
androidpit galaxy note 4 vs galaxy note 3 2
Like the front, the back of the Galaxy Note 3 (left) and Galaxy Note 4 are quite similar also. / © ANDROIDPIT
Samsung has often been criticized for the plastic feel of its flagship phones, so this time the Note 4 is supported by a metal frame, following a similar design aesthetic to the Galaxy Alpha. Because of this, the Note 4 feels a little sweeter in the hand, despite it being slightly larger in comparison to the Note 3. There isn’t much between the weight and dimensions otherwise and the Note 4’s better feel is largely down to the materials.
  • Why you should buy a Galaxy Note 4 instead of a Nexus 6
It may or may not be worth noting that the Note 4 has a total of three microphones to assist with noise cancellation on calls and that these can also be used to lower the volume of background noise during voice recording. These multiple microphones help to distinguish sounds which are close to background noise. This also lets you alter audio recordings to give a clearer sound image.
androidpit galaxy note 4 vs galaxy note 3 5
The Note 3 has a speaker and microphone on the bottom of the device, whereas the Note 4 has a dual microphone configuration. Both house their S-Pen stylus on the underside too. / © ANDROIDPIT
Galaxy Note 4 vs Galaxy Note 3 comparison: Display
Both devices have a 5.7-inch, Super AMOLED display. The screen is really quite impressive on either device, but the Note 4’s is slightly higher quality in comparison. With QHD (2560 x 1440) resolution, the Note 4’s display is one of the best currently on Android, but with the number of pixels being its only advantage over its Full-HD (1,920 x 1,080 pixels) cousin, it’s not going to be immediately apparent to most users. In most applications, the displays are going to look pretty similar: vibrant and crisp.
androidpit galaxy note 4 vs galaxy note 3 1
The Note series is known for having excellent displays. / © ANDROIDPIT
Galaxy Note 4 vs Galaxy Note 3: Software
Here is where we glimpse one of the most noticeable differences between these handsets. While the Note 4 and Note 3 both run Samsung’s TouchWiz version of Android (the Note 4 arriving with Android 4.4.4 KitKat, and the Note 3 being upgradable to 4.4.3 or 4.4.4 depending on the region), the Air Command software has seen some changes.
S-Finder was one of the lesser-used Air Command functions and is now accessible via the notifications shade, whereas Pen Window and Scrapbooker are sort of there but in a different guise. Action Memo and Screen Write make a welcome return, while the Note 4 adds two new functions to Air Command: Image Clip and Smart Select.
androidpit galaxy note 4 vs galaxy note 3 13
The Air Command features have been streamlined on the Note 4 (left). / © ANDROIDPIT
  • Why you should buy a Nexus 6 instead of the Galaxy Note 4
Image Clip is a slightly more advanced version of Scrapbooker, letting you select parts of images on screen for editing. It can recognize different shapes within the image you use, sort of like a limited magic wand tool, letting you extract particular items. It’s pretty cool and sure to please more serious photo editing fans. While Image Clip is a new option in the Air Command menu, it’s not actually a new feature - the same option was available on the Note 3 by pressing the S Pen’s button and selecting an area on the screen. On the Note 4 it functions the same in comparison, but has a slightly updated user interface. What this means is that holding down the button can now be used to highlight text and multiple items, like dragging over a number of images to send or delete them etc. This is extremely useful, and it was smart of Samsung to reorganize things in this way.
Smart Select, however, is by far the most impressive new addition to Air Command. This is used for saving or sharing certain on-screen items - just draw a box around that which you wish to interact with and it will pop out of the screen. From here you can save or share it, and with online items the meta data will even be analysed, extracting the URL or website information for you. Check the picture below.
androidpit galaxy note 4 smart select
A section of the AndroidPIT website was selected (left) and this was the meta data that was received (right). / © ANDROIDPIT
I didn’t even need to copy the whole "Nexus 5 Android Update" box from on our website, but the Note 4 has attached the website link and the title. It’s super clever technology and quick and easy to use.
The fantastic Action Memo has stayed across both handsets, though it’s arguably performing better on the Note 4, with its improved S Pen handling (said to be twice as responsive than on the Note 3), and Screen Write is also present again with the same set of features.
androidpit note 4 vs note 3 s pen
The Screen Write S Pen feature is unchanged from the Note 3 to the Note 4. / © ANDROIDPIT
Multi-window on the Galaxy Note 4 has been improved, with several new options available. It’s like the Pen window option from the Note 3, except you no longer access it from Air Command. You can get to it from your recent apps menu (just look for the Multi-window icon in the top right hand corner of compatible apps), to let you combine several windows together. Alternatively, just dragging from the top left corner of compatible apps will resize them, so ultimately the Pen window option was no longer necessary.
The Note 4 also features a new Flipboard-powered “Briefing” section on the left side of the home screen which acts a news reader. It’s not really something I find particularly interesting but thankfully it can be easily disabled from the home screen settings.
Galaxy Note 4 vs Galaxy Note 3: Camera
The Note 3 camera has 13 MP resolution while the Note 4 houses a 16 MP camera with optical image stabilization and single-LED flash. The Note 4’s camera, like its screen, is improved over the previous device in terms of the resolution. The Note 4’s camera is also a little quicker to take snaps, and they have less chance of going awry with the added OIS, but once again, last year's Note 3 is still an impressive performer, and the camera quality between the handsets isn't all that dissimilar.
androidpit galaxy note 4 vs galaxy note 3 10
The Note 4 camera is superior to the Note 3 in terms of resolution, and now features optical image stabilization. / © ANDROIDPIT
Galaxy Note 4 vs Galaxy Note 3: Battery
There hasn’t been a big change in terms of battery capacity, the Note 4 has received a minute upgrade from 3,200 mAh to 3,220 mAh capacity. This isn’t even a 1% increase in size, but overall battery life on the Note 4 is improved thanks to its new battery saving settings. Additionally, the Note 4 can take advantage of Samsung’s turbo-charging functionality giving it an estimated 50% battery life increase in just 30 minutes.
Galaxy Note 4 vs Galaxy Note 3: Specs
  Galaxy Note 4 Galaxy Note 3
Display 5.7-inch (2560x1440), 515ppi 5.7-inch (1920x1080), 386ppi
OS Android 4.4.4 Android 4.3 (updated to 4.4.2)
CPU Qualcomm Snapdragon 805 (N910S), Exynos 5433 (N910C) Qualcomm Snapdragon 800 (N9005), Exynos 5 Octa (N9000)
RAM 3 GB 3 GB
Internal Memory 32 GB + microSD 32 / 64 GB + microSD
Camera 16 MP (rear), 3.7 MP (front) with optical image stabilization 13 MP (rear), 2 MP (front)
Battery 3220 mAh, turbo-charging 3200 mAh
Extras Fingerprint scanner, heart rate-monitor, stylus Stylus
Dimensions / Weight 153.5 x 78.6 x 8.5 mm / 176g 151.2 x 79.2 x 8.3 mm / 168g
Price 749 USD Currently 599 USD for 32 GB variant
The Galaxy Note 4 technically doesn't make any big leaps, but it improves upon most of what consumers have asked for: upgraded hardware, better S Pen functionality and premium feel. The added sensitivity of the S Pen, faster performance and the better display of the Note 4 aren’t going to be noticeable to most users (though side by side the display quality can be seen), but the S Pen has been tangibly improved, and you may just find the best Android camera currently available on the Note 4 too.
What do you think? Is the Note 4 a far superior device than the Note 3?
Latest articles at NextPit
Recommended by NextPit
37 comments
  • i want to buy a note . which one is better for me ? note 3 or note 4? my budget is perfect for note 3 . but if i want note 4 then i need take extra risk. should i take this risk ? i am confused.
    give me a suggestion
    • I would get the note 3. You said it's more in your budget and I updated mine to android lollipop and I received the majority of the new features. For example my air comand with the s pen is identical to the note 4. Considering they both have 3 gigabytes of ram and the extra 20 mah of battery isn't a big improvement. And if your interested on the finger print scanner I had an s5 and the fingerprint scanner worked about 30 percent of the time and I used the heart rate monitor once to try it out. I love my note 3 and with the lollipop update it might as well be a note 4. Hope this helped
  • Purchasing a new device, is it worth an addition $350 for the note 4?
  • The Galaxy Note 4 hit the 4.5 million sales mark in a month after its September 26 launch, but that is 500,000 short of what its predecessor managed for the same period.So theoretically Note 3 wins. But Note 4 has slight updates and a bit overpriced.The GUI of Note 3 is also a bit sexier than Note 4(Just Personal Observation).
  • I upgraded from a 2 year old Note 2 to the Note 4 so it was worth it for me. Note 4 is TONS better than my Note 2. If I had a Note 3 I would not upgrade to the Note 4 because it would be a minor performance improvement. My Next upgrade will be a Note 6. ;-)
    • The odd Note numbersgoare better as they contain more innovations. Note 4 will be perfected in 5th gen just like Note 2 was improved with next gen. Right now only those who are on Note 2 or mindlessly spend the money will benefit from purchasing Note 4. There are virtually no functional custom ROMs for Note 4, which is a big no-no for me. All those who had spent 900 greens on the newly released Note will naturally try to convince the rest to do the same......lol....good luck!
  • So I have a note 3 which is my 1st full time android device. I love the note 3 and the level of customization available HOWEVER I cannot stand the camera on this phone. It's incredibly slow and sits processing so a lot of the time I lose the shot I was going for.
    Is the note 4 camera snappier in comparison?
    I am on AT&T so I'm not running stock note 3 android and can't due to warranty (knox)
  • Howard Nov 18, 2014 Link to comment
    I could see upgrading to a Note4. If you have a Note2 or older. But if your a Note3 owner. Why bother? It's more costly and not worth the minimal upgrades. Even the reviews say it's only slightly improved. But not notably better. The tech savvy among us already know to hold out for the Note5!!! Those of us who are experienced Note series owners already know the most bang for your buck is in the Note5!!! I'm one of those people who like to get my money's worth and spend it wisely! My Note3 is only slightly less phone then the Note4. Very very slight! So if keeping up with the Jone's is important to you. By all means get the Note4 and spend more money for little. But if your a tech savvy experienced Note user, then wait for the Note5!!! It's right around the corner, and worth the wait!!!
    Note3!
  • May move from a iPhone 5s to Samsung. Don't have the money for a Note4 ($299). Should I wait and save for the Note4 or buy the Note3 $.97?
  • Minor upgrades not enough to change to the next model. maybe the Note 5 may have a better chance of wowing the masses.
  • Galaxy Note 4, upgrade maravilhoso..
  • Zed Nov 4, 2014 Link to comment
    I am sick and tired Samsung, I been the owner of a Note 3 since its release and had been pondering upgrading to the Note 4 before the official N6 announcement.
    Hear are the reasons I'm buying the N6:
    1. Signal signal signal......it still has to be a reliable phone. Motorola radios are just beast compared to Samsung having to toggle airplane mode to get it to pick up the LTE tower......screw that noise.... nuff said there.
    2. Front facing stereo speakers......ever since the wife got her HTC One M8 I had decided no more mono speakers on the back and the Note 4 keeping the speaker in back of the phone is a major FAIL.
    3. Charging....more specifically the charging port on my Note 3 has been horrible. Original lasted maybe 8 months, replaced and it lasted a month maybe......I don't do anything weird with it, I just plug it in a lot....I am replacing it again when the new replacement arrives and hopefully this one lasts until the Nexus 6 arrives......
    4. Note 4 reverted back to USB 2.0 from 3.0, although it's a faster USB 2.0 than the older handsets, USB 3.0 functionality was FAST.....another Note 4 FAIL.
    5. Qi wireless charging is built into the Nexus 6. This will be very useful in combination with the Turbo Charge technology (15 minutes for 6 hours runtime), wireless overnight charging, get a quick hit with the cable at work before leaving......no more worries on charge.
    Note 4 FAIL.
    Final thoughts
    I will miss the S Pen on the Note....but oh well....I don't use it excessively, I will give that up for a better radio, more solid hardware and front facing stereo speakers - bye bye Samsung.
  • I have a note 3 but don't see anything here that would make me upgrade a perfectly working device (not on a contract so purchase my phones) I am intrigued by the new edge and may well take a look at that unless the price is silly
  • Another no go is the micro usb port, why going backward to 2.0?
    •   16
      Deactivated Account Nov 4, 2014 Link to comment
      my Note 4 charges 0 to 50% in 30mins, 50 to 100% in another 40mins. full 100% 0 to 100 in 60mins. USB 3.0 didn't mean nothing on my Note 3. USB 2.0 wins easilyeasily since fast charging is a great feature.
      • I'm sorry to break it to you, but my note 3 with quickcharge 2.0 charger and proper USB 3.0 cable does a record time of 25 min to get to 50%. I also have installed one of the most stables ported ROMS from Note 4, so essentially I have the same software as well, except of course the note 3 is crippled in some hardware related capabilities. The two major things that keep making me contemplate doing an upgrade are the screen and camera. I think the note 3 colors are really off, and the note 4 has an absolutely stunning display. Furthermore, the camera is indeed the second best android phone camera out there right now (LG G4 is the new winner).
  • I didn't see on the comparison that the Note 4 will allow additional storage via microsd. Did I miss something or will this not be possible?
    • Thanks for pointing this out, Zach! The Note 4 does have an SD card slot, I have updated the specs table to include it :)
    •   16
      My Note 4 has 128gb sdxc class 10 Ultra Plus SanDisk card. It works extremely well.
  • Who cares about the back really? Most users will put a case on it anyway and I use an S View case, which I love, so it replaces the back. I do like the square corners but that's not enough to upgrade. My Note 3 is awesome, fast and does everything I want. I think the Note 4 will be a good upgrade for older Note model owners though. With the position of the new fingerprint scanner I guess all hope is lost of them getting rid of that ugly home button. I do like the direction they are heading now but how much bloat did they cram into it? That's the big change I want to see, more user control over pre-installed apps, please and thank you!
    •   16
      On T-Mobile my Galaxy Note 4 gets 40up and 20 down. it's so much faster than my Galaxy Note 3 it's comical. I feel sorry for anyone who thinks the Galaxy Note 4 isn't worth the upgrade. For those of us who already have the Galaxy Note 4 we know the truth Note 4 tops Note 3 easily.
  • Loving my Note 3 with Dymanic 5.0 rom. Not enough mega changes to make me upgrade. Especially if Knox is gonna be more of an issue to root that bad boy!!
  • Disappointing not much upgrade from note 3. At least not worth for > $800 if rumours are true. Fail. Still waiting for nexus 6.
    •   24
      Deactivated Account Sep 3, 2014 Link to comment
      the release price is about the same as with the Note 3, but id expect that to drop a bit fairly soon (as happens with almost every single flagship)
    • Totally agree with ur post. Waiting for Nexus 6!!!
    •   16
      You have failed truthfully. The Galaxy Note 4 16megapixel camera, and front facing camera as well as optical image stabilization is excellent. Battery life on the Note 4 is far better than the Note 3 easily and that's without power saving mode or ultra power saving mode. Spen is world renowned, multi window is dope, and pop up multitasking feature where chat heads can remain on the screen is top notch features. Stop selling yourself short I own the Galaxy Note 3 also and NO NEXUS will ever touch or compare to any Galaxy Note product.
      • I disagree. The upgrade isn't worth the money. If you would have known more about the way CPU operates you would have noticed that the upgrade from FHD to QHD along with a meager increase in CPU power makes no sense. Note 3 is actually faster than Note 4, using the deodexed stock ROM that is. The only thing that has been truly upgraded is the camera. The rests are just useless bells-n-whistles that add value to neither productivity, nor to gaming capabilities. GPU performance will be heavily effected by the QHD resolution, so heavy 3D games will have poorer performance in comparison with FHD screen. If the CPU clock were raised by X2 than you could have argued with me, otherwise you just change from a good screen to something that is in theory should better but on practice hardy fullfils one's expectations.
  • I think that Note 4 is design wise the best looking one in the phablet Note series. I prefer phones with sharper edges.
  • I have a Note 3 and its back may not look good for some, but it has been very well placed, because it is SUPER grippy, this makes the phone more confortable in the hand because it is big, it wont ever fall of our hands easily...and that's Functionality.
    • Exactly. This is one of the reasons I'm loving the S5 so much (and getting it) :)
      • So what do you think of the new back panel design on the Note 4?
      • Ron Aug 21, 2014 Link to comment
        I think the back is fine. I generally will have a case on it. My question is whether it's a big enough upgrade to move from the Note 3.
      • The Note 3's one looked like it's made from the foreskin of a circumcised rhino. The new foreskin back must've been sourced from an elephant, as the device is a bit heavier.
      • It certainly looks more premium than the Note 3. But I'm not sure if it is as grippy as on the Note 3.
        Otherwise yes, the Note 4 is the best looking phone Samsung has released up to date :)
      •   16
        Moving to the Galaxy Note 4 is a must.
