How to unlock the bootloader with one-click across different devices
If you don’t tinker around with your smartphone or tablet much, you may not exactly know what the bootloader does. This is the program that fires up as you turn on your device and is used to load the operating system. The majority of smartphone manufacturers lock the bootloader by default allowing only the loading of their own firmware or UI and preventing the installation of custom ROMs, such as CyanogenMod or Paranoid Android. As such, unlocking the bootloader is one of the key components to being able to install these custom ROMs on your device and we’ll show you how you can accomplish this across a few of the more popular smartphone manufacturers.
Background
Each device has unique hardware characteristics including a motherboard that requires its own individual bootloader. As such, there really isn’t any universal method for unlocking bootloaders and requires a different procedure or toolkit  across brands.
Important: All of the listed methods require you to first have root access to your device before being able to unlock the bootloader. There are a few exceptions, such as for HTC and Sony devices, and we’ve highlighted them appropriately.
Samsung
samm2
There's no universal method, but it can still be done. / © Samsung
While there is no universal method for Samsung devices and their Samsung Galaxy S3 was the last real Samsung device to offer a user unlocked bootloader, except on the Verizon version. If you’re still kicking that Verizon Galaxy S3 around, you can use the EZ Unlock tool to get around it.
Note: This app works only for devices made before 2012!
  • EZ Unlock – Download, connect your Verizon Galaxy S3 to your PC, and click Unlock.
Nexus
AndroidPIT Nexus 5 2015 final w782
A universal app gets the job done. / © ANDROIDPIT
Here is a universal app for the Nexus line of devices that will allow you to unlock your bootloader with a click. As well, you can also relock the bootloader from this app if you so choose to.
LG
android lg logo image 01
 There is no universal unlock for LG devices to unlock the bootloader, but there's still a way to do it. / © LG
As with Samsung, there is no universal unlock for LG devices to unlock the bootloader. However,  if you have an Optimus G, Optimis G Pro, or LG G2, FreeGee is an application from the Play Store that will allow you to unlock the bootloader and install custom recovery softare, such as ClockwordMod or TWRP.
If you have an Optimus L5 or L5 Dual, the following applications will work on your device.
HTC
android htc logo image 01
HTC Bootloader Unlock will allow you to lock and unlock your bootloader. / © HTC
For HTC devices, you can use the HTC Bootloader Unlock software. This software uses the official method to unlock the HTC bootloader by downloading the unlock code suitable for your device. You can also lock the bootloader again using this software.
HTC also has the advantage of having a toolkit that will work on unrooted devices. By using the Kingo Android Root program.
Sony
xperia x compact
Sony Bootloader Unlock works for Sony devices. / © Sony Mobile
Kingo also provides some unique software for Sony to unlock the bootloader in the form of the Sony Bootloader Unlock.
As with HTC, you can also just use the Kingo Android Root Program and not need to have root permissions on your device.
Huawei
android huawei logo image 01
Huawei Bootloader Unlocker does all the work for you. / © Huawei
For Huawei, there is an app available on the Google Play Store called the Huawei Bootloader Unlocker that will do all the work for you and works across 7 different Huawei devices.
  • Huawei Bootloader Unlocker
Motorola
Motorola loves developers and has a dedicated Bootloader Unlock program. Depending on your location and device, you can easily (and officially) unlock your Moto device by heading over to the following Motorola page and following the links for your device.
With the bootloader unlocked, you can install a custom recovery on your device and even get going on custom ROMs.
Did you find the bootloader unlocker for your device? Let us know how the process went for you in the comments below.
24 comments
  • Muhammad Hassam Aug 18, 2017 Link to comment
    never use EZ-Unlock in Galaxy S4. :'( very badly hard bricked
  • K.1 Computer Jan 21, 2017 Link to comment
    work it on lark cirrus 4s ?
  • vickysharma Sep 8, 2016 Link to comment
    i m using sony xperia m dual that devices is fails to unlock the boot loader
  • John hunter Apr 26, 2016 Link to comment
    If you don't have the basic knowledge needed to root your android device ID recommend downloading king root apk. Install that and one click to root your device. After you have rebooted you should be successfully rooted. However you can't install SuperSU. Download supersume. Run the app and it will delete all kingroot files and install SuperSU. You will keep root and get rid of that horrible kingroot apps.
  • DroidBro Apr 8, 2016 Link to comment
    Am I the only one here still rockin' a good ol' LG G2? Oh yeah, it's only $270 on Amazon.ca. Aaaaand it's $130 on Amazon.com. I live in Canada. Now you know where I live.
  • Amaravadi Chiranjeevi Oct 29, 2015 Link to comment
    Is it work for ZenFone 2
    Is it work for ZenFone 2?
  • AExpert Fernando Oct 10, 2015 Link to comment
    What kind of rooting tool do you use guys?? my friend says search4roots. but im still reading reviews on what kind of tool to use on my phone.
  • Jinx Ming Liu Oct 9, 2015 Link to comment
    LATEST DC Unlocker CRACKED!!!
    No more f%$ing support no more credits
    !!WORKING!!
    Tested!!
    FREE no credits READ Bootloader all latest huawei Qualcomm and hisilicon!!
    FREE no credits unlock all latest Huawei Qualcomm and HiSilicon!!!
    Untested:
    unlock modems, but must work too!
    you need any user name with zero credits to use cracked version from link below
    can use available online
    username: lexus
    password: lexus
    username: nagyjofi
    password: jmjcJN5z
    FREE UNLOCKS works on hacked soft only!
    download cracked soft: w w w. mega f i l e u p l o a d . c o m / m 3mr / dc -unlocker1212patched . e x e
  • ANDREW g Sep 30, 2015 Link to comment
    I have a Verizon developer edition note 4 on 5.0.1 and I accidentally locked the bootloader. Is there a tool to reunlock it?
  • KarleeKakes May 3, 2015 Link to comment
    Ok I used this stupid thing literally 4 days ago&&it hard bricked my phone...FINALLY after like 2 hours of searching I found out u can go to google and type in Verizon samsung galaxy s3 i535 4.4.2 kitkat debrick img(of course use ur own phone type lol)and just find one that explains how to do it and ull be amazed!!
  • Drew K Jan 20, 2015 Link to comment
    Never Try EZ-Unlock with SCH-i535 4.4.2 it hard bricks it. Have to use JTAG to unbrick.There should be more updated info on this post.
    • Jayson Rees Mar 31, 2015 Link to comment
      Wish I had seen your comment sooner. EZ-Unlock is basically Satan for that setup.
  • Salomon Jul 7, 2014 Link to comment
    Can someone tell me where is 512 MB partition on the ace s 5830i? After the sd card partition I have still not enough place on the phone when I want to install new apps. After the partition I have only 1.3 GB instead almost 2 GB..where are the 500 GB hidden? Although I have rooted I feel sometimes more like "Superloser" instead superuser! Is it maybe the developers indistinkt guidance?
  • Brian Ressler Jul 1, 2014 Link to comment
    So I don't want to do anything dumb, This article is pretty recent and I notice the galaxy s3 verizon is listed with ez unlocker. It is my understanding that 4.3 ota eliminated this method for the time being. Does anyone have any feedback on this? And if anyone believes as I do that developers may not even be able to find a solution to this matter, then what phone is good on the verizon network that is unlockable for installing a cusom recovery? I was able to achieve this easily on the 4.1.2 build of the galaxy s3 and installed cm, but then my sim card reader failed and as part of diagnosing the problem, I reverted to ota but it was the notorious 4.3 ota, and this really screwed things up.
      How did you downgrade to 4.1.2 I hard bricked mine trying to.
      • Randa Dec 3, 2016 Link to comment
        Why do you assume he downgraded? He didn't state that. He could've had another handset running 4.1.2
  • Reg Joo Jun 29, 2014 Link to comment
    Will any of these work with TCT Alcatel?
  • Bojan M. Jun 29, 2014 Link to comment
    Sony as well provides an easy and official method of bootloader unlocking (which is basically what that kingo app uses as a method). It is available on sony mobile website.
    • My1 Jun 30, 2014 Link to comment
      but the problem is that you will lose the TA partition with lots of DRM Data, therefore some sony apps wont work anymore... and they will see that you have unlocked it.
      • Bojan M. Jun 30, 2014 Link to comment
        Sure, but that's the way it is. Regarding sony apps, I must admit I miss those sometimes, but there are a number of them available for any device (not officially, of course). Regardless, now that I went custom all the way, I won't be going back.
        or you do it the other way. towelroot, backup TA partition, then BL unlock...
    • Bouyabess Messouce Jun 24, 2015 Link to comment
      Did you succeed to do it because I couldn't not do it
