How to install Android Nougat on the Samsung Galaxy S5
It's highly unlikely that Samsung's 2014 flagship - the Samsung Galaxy S5 - will receive an an update to Android 7.0 Nougat or Android O. If you want anything higher than Android Marshmallow 6.0, you're going to have to take matters into your own hands. We'll give you a step by step guide on how to ensure that you'll get those Nougat features and future updates on your Galaxy S5.
Why should I install Android Nougat on my Galaxy S5?
Samsung has officially stopped providing support for the Galaxy S5. The S5 was introduced in early 2014 and already has 2, soon 3 (the long anticipated Samsung Galaxy S8) successors. If you've already received the last Android 6.0 Marshmallow update, this will sadly be your last. You will no longer receive any software updates from Samsung, which in turn also means that any potential security risks that might arise in the future won't be patched. Its up to you if you choose to manually update your phone - but there are no disadvantages and it's surprisingly easy.
Installing Nougat on the Galaxy S5: first steps
The first thing you need to do is create a backup. In most cases, your contacts will already be synced via your Google account. If you are one of the many WhatsApp users, you can easily back them up in Google Drive (here's a tutorial on how to backup your Galaxy S5). You can either backup your photos onto your computer or secure them via the cloud. If you've configured any apps then you'll have to reconfigure them again later, as the majority of app developers don't use Google's backup feature.
In theory, both WhatsApp and your photos should be unaffected, nevertheless it's always better to be on the safe side and do a proper backup.
Connecting your Galaxy S5 with your PC
Unfortunately, you're going to need a computer that runs Windows to use the tools that we need for this. When we tested this method, we used a Virtualbox running Windows 10 - and everything worked seamlessly. You're going to need both the Samsung Driver for Windows PC and Odin in the Virtualbox. After you've downloaded the Samsung Driver, install it, unpack Odin and start the application.
Boot up your Galaxy S5 in Odin mode. To do this, turn it off then press home, power and the lower half of the volume rocker when you switch it back on. Confirm the warning that appears on the screen by pressing volume up. Connect your S5 with your computer and check if they can communicate with each other. To do this, go the Log section in Odin and check if an "Added!!" appears, and check if the device appears in the interface list.
If you do end up having problems with this step, then you might have to switch to the ADB Driver Installer and follow the instructions from there.
Install the recovery
Now you want to replace the recovery software with the custom recovery software from TeamWin. Custom recovery allows you to interact with the partitions of your smartphone. This is essential for the next steps where we change the Android system and install system apps like the Google Apps.
Download the current .tar file of the TeamWin Recovery Project (TWRP Recovery) for the US Version of the Samsung Galaxy S5 (Note: this is currently not available on the AT&T branded S5 (g900a) ). In Odin, click on AP and select exactly this .tar file from the download directory. Click Start to flash the new recovery.
Once the process is complete, you'll have to restart in recovery mode. If you don't do this, the recovery will automatically replace the TWRP recovery that you just flashed on your Galaxy S5. To get into recovery mode, press and hold home and the lower part of the volume rocker. Confirm the initial warning. Go to the Mount section and make sure that you can see the files of the Galaxy S5 on your computer.
Download and install firmware
After installing the custom recovery, we can finally proceed to the main part and install Android Nougat on your Galaxy S5. The appropriate firmware can be found on the download page of Lineage OS (formerly known as CyanogenMod). You'll need to click on the top left hand menu and select the S5 version that applies for you as they differ for each carrier. In the Lineage OS build column, you can get the ZIP files with so-called snapshots of Lineage 13 or Nightly Builds for Lineage 14.1. The former are based on Android 6.0 Marshmallow, so they are less up-to-date and stable. The latter are based on Android 7.1 Nougat and are updated almost daily, though they're not fully developed yet.
For the Play Store and Google services, you'll need another ZIP file with Google Apps. The easiest way to do this is to use Opengapps.org. Download the ARM for your Android version. We recommend the micro package for a nicer looking calendar and Gmail. However, Pico image is also sufficient.
- Copy the ZIP files to your Galaxy S5.
- Now change to TWRP Recovery on Wipe and then on Advanced Wipe.
- Select the Data and System partitions to delete Samsung's Android version of your Galaxy S5.
- confirm the changes.
As mentioned earlier, your app settings will be lost but your data and photos will be unaffected as they are located in the internal storage.
- Go to the home screen of TWRP Recovery and tap Install.
- Tap Select ZIP, you'll enter in the LineageOS Directory and then select the downloaded file.
- By selecting Add more ZIPs, you can and should install the Google Apps. Do not do this later as it will cause conflicts with the authorization management.
- Though it is not required, set a check mark for Reboot after installation is complete.
- Swipe where prompted to start flashing.
The contents of the ZIP file will now be unpacked in the emptied partition.
Setting up your device
As you've lost all your app and phone settings, you'll have to repeat the initial setup of your device. You'll be required to log back in with your Google account and re-install the apps that you had previously. On the plus side, you'll be able to enjoy all the updates for your Galaxy S5 long after Samsung has stop delivering them. Future updates will arrive automatically on your phone and don't need this complicated process to install them.
Benefits and features of LineageOS 14.1* on the Galaxy S5
*Disclaimer: When we tested the 14.1 version, it was still known under the name CyanogenMod. Three months have passed since and CyanogenMod has rebranded to LineageOS. Both the version that we tested (CM 14.1) and LineageOS 14.1 are virtually identical.
We didn't encounter any major issues when we tested CyanogenMod 14.1 on the Galaxy S5. Even NFC and the fingerprint sensor worked flawlessly. The only real problem we found was that the camera lost its HDR ability, yet it continued to deliver satisfying results. Check out the gallery of our test shots.
I was surprised that CM 14.1 managed to support all the relevant features of the Galaxy S5. Issues that often came up with camera quality could not be reproduced. I actually like the camera of the S5 more now thanks to the added optimization features and exposure control.
Overall the S5 feels a lot snappier thanks to the new firmware and if you buy a new battery for $15, your phone should last at least another year.
And when I connect to the PC the window opens showing the phone model but it can no longer read the files in the phone or on the sd mini drive
Samsung smart switch no longer works - is this right
I followed this guide and ran into an issue... the first issue was that I didn't select lineage zip first when installing, causing the phone to be bricked. However once I resolved that issue it worked well and is operating normally. However, now I don't have access to the google play store or any google apps, even though I made to select the largest package for the google apps zip file. I'm not quite sure what exactly I did incorrectly or how to fix this..
Any help would be much appreciated, thank you.
Hello, I have the Verizon Galaxy S5, and the TWRP install with Odin fails on the first step. Is there a cause and solution to this? My phone ios not rooted, but from the TWRP website, it claims I do not need a root for the download.
Some notes for anyone else about to attempt this on a Verizon SM-G900V (could apply to other models as well). Sorry in advance for not being able to post direct links:
This walkthrough was really great, but I hit a couple of road blocks along the way. My phone was already rooted, but was running an old custom rom (KitKat or Jellybean).
Per the instructions here, Odin kept failing. I also could not use ADB. It really seemed hopeless, so I decided to go back to stock and upgrade as much as possible. So I used CF-Auto-Root to get to 6.0.1. There's a helpful video and tutorial here. Look for "Root for Galaxy S5 on Marshmallow" by Ironass on Android Central.
Odin passed using the method above, but I still wanted to go to 7.1 unlocked and rooted. I followed the steps here to do so (my CID was 15): Look for "[GUIDE] Root, Bootloader Unlocks, and More!" by AptLogic in the S5 General Forum at XDA Developers.
Note 1: It mentions using "EMMC_15_SafeStrap_QA1_6_0_1_MM_Bootloader_Unlock_A IO.zip", QA1 does not exist in the download, but I successfully used QB2 in its place.
Note 2: tr_v2.apk did not appear the first time I downloaded and unpacked it. I redownloaded it and unpacked it later and it was there. I may have downloaded it from a different post than the one linked above.
Note 3: The first time I tried this, I followed the instructions fairly closely but the biggest mistake I made was to not uncheck Samsung's reactivation lock. Because of this, after step 14, my phone did not go into TWRP recovery, but instead locked everything down. If this happens to you, just go reinstall 6.0.1 as mentioned above, and go through all of these steps again.
Lastly, flashing Lineage OS will likely break SuperSU. So if you want to keep root after doing all of this work, then you have to also flash the SU Addon (for me it was su (arm) 14.1). Just go into TWRP, install, and select it from your internal memory. Then when you boot up, go into developer options, select Root Access and check either Apps Only or Apps and ADB. It's that easy to stay rooted. Check the Extra Downloads on Lineage OS's website.
Hey, would you mind writing up step-by-step instructions on how you got TWRP installed after being on the latest 6.0.x update on the SM-G900V? It continuously fails on Odin for me.
Thanks,
Lagz
So, is this upgrade possible for the AT&T S5 900a ?
Thanks for the post. You mention that there is no .tar for the AT&T version. What is the alternative of TWRP to use for the recovery file?
Afternoon. Before a do this, I may have a unique issue. My phone is a Verizon phone that is actually using Cricket as it's carrier. Is this something that I should be concerned about? Are there additional steps I should take? Will I have to have Cricket reconnected to my device via the carrier or have them tell me I can't because the device has been rooted?
ahhhh help! I used twrp to wipe my data and system. But then when i went to install the new os i realised i only had the OS on my pc, not on my phone. What should I do now? How can i get the OS file on to my phone. I dont see my phone in windows explorer so i can't just drag the file there (i've tried unplugging usb cable and replugging it. any help really appreciated.
edit - i've sorted it. Got the OS on a micro sd card, card in phone....voila, twrp flashed OS from card to phone, phew!! Phone is working quicker than i've seen it work for a year. Thank you.
If you reading this before doing procedure...make sure you have OS and open.gapps file on your phone before the wipe!
i update my phone to android 7.1 but because of the battery usage more than android 6, i want to downgrade it to the last orginal rom. i have nandroid backup about 5gig . but when i want to restore it with TWRP , it just stock at the first page and nothing change i waited about 40min but nothing happen. what should i do?
Hey guys! I would like to make a correction in this blog. In the section "INSTALLING THE RECOVERY", to go into recovery mode after installing the custom recovery by using ODIN mode, you have to Press and Hold the VOLUME UP key + HOME key and the POWER key.
Holding the VOLUME DOWN key instead of VOLUME UP key will take you back into the ODIN MODE.
You are totally right I had to search on the web what was happening since my phone never entered into recovery mode.
Thanks mate!
Hello sir, I use a verizon Samsung galaxy S5 G900V and the twrp.tar for both American and European is not installing in odin. I'm not an expert at this and I tried doing with Abd driver, but I don't know where I should add the twrp.tar. I'd really appreciate it if you guys could reply to me with either a link to twrp.tar for verizon S5 G900V or some tutorial for Abd driver. Ps, USB debugging is on, running on Android 6.0.1 with security patch level July 2017. Thank you, my email is dr.ramshadabdul@gmail.com, hope I'll hear from you guys soon
Hi. This is a Verizon problem. Verizon locks the bootloader tighter than fort Knox. Thanks to many people rooting and unlocking their phones and bricking them and going to Verizon store for Warranty and trouble shooting. And people getting mad when Verizon told them that a bricked phone from rooting and custom rooms was not covered under warranty but actually voided the warranty. Verizon starting locking bootloader's to avoid the non tech savvy people blaming Verizon for broken phones. At&t followed suit both with the Galaxy S4
will this root the divece? and blow the root fuse? so my internet banking apps will stop working?
It should trip the knox warranty sensor since your putting a custom recovery on the device. It'd also be tripped trying to put install an unsigned rom onto the device. I believe this will make some of your samsung apps not work, such as samsung pay.
So if you wipe without enabling usb debugging mode you get stuck so now im trying to restore my os using odin so i can enable debugging mode. still stuck on the Samsung loading screen so any advice what I should do? maybe I put the wrong os file.
i did have the wrong tar file. oops and the sd card messed it up. I finally did get it to work. but i didn't like the nougat that much to hard to get used too. I might try it another time.
another thing is it dosen't support Samsung gear manager.
Yeah.... I followed every step carefully and the first time I boote it took like 10 minutes to finish booting, after that, when I was setting everything up, it suddenly restarted and it's stuck in the boot screen :(
Same problem here. Was really happy that the system was running so fast but after like 40 minutes configuring it suddenly hang and went into the android 7.1 boot screen. When it happened i created a couple finger scanner to unlock my device. Smartphone is running as long as i dont go into the security option. If i do it crashes the phone :/ maybe finger scanner related ?
Update: Disabling the finger scanner worked, so far no crashes :)
II'm stating with Marshmallow 6.0.1 wanting to Install 7.1.2 in a SM-900A can I use Windows 8.1 PC ; any specific procedures?
May have found the issue. Developer Options. "In some Samsung phones like: Galaxy Note 5 and Galaxy S6 edge+ you need to enable OEM Unlock option in Developer Options. By default the Developer Options is hidden and you need to enable the Developer Options first." "To enable Developer Options on an Android phone or Tablet, do the following:
Go to Settings, Click on About phone and then Tap Seven times (it may vary) on the Build number." I now have it enabled
on my Sprint GS5 and will retry root tonight.
hi guys.....thanks a lot for that article but i'm confused here since i have s5 LTE-A G900L Korean and not sure which rom I should install
s5 Korea kltekor or s5 LTE-A lentislte????????
I'm unable to install the recovery via Odin3 v3.12. I get the update failed error. My Sprint G5 has the lastest. Does the lastest update have a new or different lock that's affecting this or a different version of recovery needed? My phone is up to G900PVPS3CQD1
It worked flawlessly, thanks!
It has?
If I download this will I get the new emojis too
Hey all, I have a question. I have an AT&T Galaxy s5 Active SM-G870A unlocked, I would like to upgrade it to Android 7.1 for T-Mobile.... Does the Active make a difference or am I too S.O.L. Any help would be greatly appreciated.
SO SINCE THE AUTHOR OF THIS ARTICLE MISSED A HUGE KEY TO SAYING WHICH GALAXY S5'S THIS IS COMPATIBLE WITH OR NOT I HAVE THAT QUESTION. SO CAN A GALAXY S5 AT&T VERISON BE UPGRADED TO ANDROID 7.0 OR NOT? SINCE THE ARTICLE WRITER (ERIC HERRMANN) LIKES TO WASTE PEOPLES TIME AND NOT SAY I'D LIKE TO KNOW. I WANT TO UPDATE MY ATT GALAXY S5 G900A TO 7.0 FROM 6.0.
Hi Robby,
first of all, it would be nice to not use all caps, you don't really want to scream at us right? ;)
As for your criticism: It says that the recovery is not available for the AT&T version, same goes for Lineage (simply look at the linked website and you will see that there is not AT&T S5 listed). I just had a look at xda-developers.com and really couldn't find a suitable 7.0 ROM for the AT&T Galaxy S5.
thank you for your response. before a article like this is written up it would be nice of you guys to list compatible phone models that it will and wont work on. dont make people read the whole article then at the bottom (after the person has downloaded all files to do the mod) put in parenthesis, dont have file for this phone. I mean what is that? It should say this WILL NOT WORK ON AT&T G930A model. How hard is that? As you can see I wasn't the only one confused that owns the at&t model.
This did not work. I installed the files correctly, but it said error for some reason and wont boot fully.
Hi. I have an AT&T Samsung S5 and you mentioned that the "the current .tar file of the TeamWin Recovery Project (TWRP Recovery)" isn't available for yet for my device. Could direct me to where I could possibly obtain this or perhaps a work-around? Thanks.
OBVIOUSLY THE ARTICLE WRITER (ERIC HERMANN) HAS NO CLUE
Hi, and why exactly does he not have a clue when it clearly states that it is not available?
As far as I know there is no suitable 7.0 ROM for the AT&T S5 available at the moment.
Is it just me or is that bootloader animation just the worst in human history?
To enter recovery mode you use the "Up" button on the volume rocker, not "Down"
Will this method work with a straight talk branded Verizon galaxy s5? The model number in the phone is SM-S902L. But under the battery it says SM-G900V. I just don't want to brick my phone. Thank you.
the WIPE is done after TWRP is flashed
ill direct you to this comment -> https://www.androidpit.com/samsung-galaxy-s5-android-manual-installation?c=2374004#comment2374004
The S5 comes in many flavors...
WARNING !!!
THE DESCRIBED ARTICLE IS *NOT* FOR THE S5 PLUS
( SM-G901F KCCAT6) _ MODEL.
YOU WILL BRICK YOUR PHONE !!
And I can't believe the superior version (S5 Plus) still doesn't have LineageOS. There's an unofficial version, but it's still unfinished.
True but some say it's already working as daily driver. I mean the ressurectionremix on XDA_FORUM from senior member CVXDA. It's in development but my guess is it will work now and improvements are almost on daily basis.
official now
//wiki.lineageos.org/devices/kccat6/install
that should be clear from the title though - and no where in the article is the S5 plus mentioned
Would it not need rooted phone
yes it would
The whole idea of installing a custom ROM just for getting a corresponding updated Android version is not logical. If you want a custom ROM for the sake of using a custom ROM, instal one. But if you need to just update your Android version, do it via the official mode if it's supported for your phone, otherwise get a new phone.
What is not logic for you is logical for many upgrades to the next level Android if the manufacturers decide not to bring out any version update so they expect you to buy a newer phone.
That's logic.
Logic is also the fact some pple might refuse to enter that race by force.
Many so called old models are perfectly capable to run the next Android version so that would be a logical money' saving consideration to install Lineage.
In xda forums talk, the WIPE is done after TWRP is flashed, but before new rom and Gapps is flashed. Your instructions will lead to a few bricked phones. Lineage 14.1 on S3 (2 of them)
Hi, thanks for your comment.
The article has been written while doing the described procedure and we didn't encounter a bricked phone.
I strived through xda to see, if there are similar reports on TWRP installations on the Galaxy S5, but i couldn't find any reports concerning a necessary wipe after TWRP installation. Maybe these reports are specific to the Galaxy S3?
Can you share a link to a relevant discussion? Your help is greatly appreciated.
It is common knowledge when coming from stock_or any other Rom a full wipe is needed to avoid clutter and other problems. The new Rom is like an O.S. and is written to work as is, so any leftovers from previous O.S. (old Rom) must be cleared to be sure the new Rom is and can work as the writer intended it to work.
I'm actually about to go through the guide, but just confirming, should I go ahead and wipe after the TWRP? I just want to make sure before I go and brick my phone....
I don't know why you ask this
If you EVER flashed a Rom before on ANY phone you would know that going from one rom to a completely different one NEEDS a wipe from System , DATA , and CACHE
If You do not do so you get bricked phone or bootloops
"In xda forums talk, the WIPE is done after TWRP is flashed, but before new rom and Gapps is flashed. Your instructions will lead to a few bricked phones. Lineage 14.1 on S3 (2 of them)" -- that's exactly as above instructions state.
Let me quote stuff in chronological order...
"Once the process is complete, you'll have to restart in recovery mode"
"Select the Data and System partitions to delete Samsung's Android version of your Galaxy S5"
"Swipe where prompted to start flashing. The contents of the ZIP file will now be unpacked in the emptied partition."
It is clear to me you are stubbed person.
Go ahead. Flash without wipe. But do not cry when your phone bootloops or bricks or gets unwanted reboots or not working in the right way.
You should do more investigation before writing such nonsense as you are doing now.
The S5 has MarchMallow 6.x as OS. The Lineage is Nougat 7.x based and is completely different. Therefor a wipe is needed.
If you read a thread on XDA you should read all postings in the thread, even if there are like 400 or more postings
here we go
Read and learn.
You really should have added this is NOT available on the att branded s5 (g900a) simply saying "us version" is extremely misleading considering there was several variants realeasd in the us the att variant being the only one still on a locked bootloader and recovery ....after 3 years it finally does have root but no teamwin ....
youre right, thanks for bringing that up - its been added to the article
Need to include non-dev Verizon S5 with this. Adding to the confusion is the subset of this cohort manufactured with a specific emmc that can be exploited to unlock and root, all others will relock if upgraded beyond 5.1.
I installed Lineage on to my S5 and it was indeed very snappy, very stable OS. Only big issue I encountered was that the camera quality and focus speed was nowhere near as fast as Samsung stock 6.0.1 even with an app like Snap Camera HDR. That deterioration in camera quality made me switch back to stock as its a key reason why I love the S5.
Or.... download Google Camera.
