NextPit
Galaxy S6 Edge vs LG G4 comparison: battle of the flagships
At long last we have our first proper look at the LG G4, after the South Korean manufacturer unveiled it for the world to see at a special press event earlier today (take a look at our hands-on LG G4 review). So how does it stack up against the very best that Samsung has to offer?
lg g4 samsung galaxy s6 edge front display
Has the LG G4 (left) brought enough fire power to take down the Galaxy S6? / © ANDROIDPIT
We put the LG G4 head to head against the Samsung Galaxy S6 Edge to see who comes out on top, comparing the flagship phones in terms of design, display, software, performance, camera and battery life. Scroll down for a full specs list.
Samsung Galaxy S6 Edge vs LG G4: Design
The Galaxy S6 Edge is quite simply the best-looking smartphone that Samsung has ever put together. Glass plates front and back, aluminum around the sides and of course that curved screen, it's a gorgeous-looking device that's a home run in the aesthetics department.
The LG G4 is also a sleek-looking device, though it seems to have a bit of an identity crisis: You can pick up the phone with either a premium leather back or a cheaper plastic shell (though the brushed metal look of the LG G3 has been ditched). It's solidly constructed but doesn't quite have the flair of the Galaxy S6 Edge.
lg g4 samsung galaxy s6 edge back camera 2
The LG G4 (left) is equally as striking as the Galaxy S6 Edge (right) / © ANDROIDPIT
Samsung Galaxy S6 Edge vs LG G4: Display
The Galaxy S6 Edge display is unmissable, with its curved edges and Super AMOLED screen. The 5.1-inch display offers a QHD (1440 x 2560 pixel) resolution with a pixels-per-inch rating of 577 — that means individual pixels are virtually impossible to see.
In LG's corner the G4 brings with it a larger 5.5-inch display but the same QHD 1440 x 2560 pixel resolution. The PPI isn't quite as high, but it's still a super-sharp resolution, and LG is promising some state-of-the-art technology to improve various aspects of the display quality: It says it's 25 percent  brighter than the LG G3 display with a 20 percent wider color range.
samsung galaxy s6 edge mwc 02
The Galaxy S6 introduced a totally revised TouchWiz interface. / © ANDROIDPIT
Samsung Galaxy S6 Edge vs LG G4: Software
The Galaxy S6 Edge comes with Android 5.0.2 Lollipop and Samsung's custom-made TouchWiz skin thrown on top. While there are still some superfluous Samsung-branded apps lying around, the user interface has a fresher look and has been updated to be more responsive and more intuitive.
The LG G4 runs Android 5.1 Lollipop with its new UX 4.0 on top — as the company has previously shown off some of its features, we know it includes a quick shot hardware camera button (that even works when the phone is locked) and a Smart Alert system that makes activity suggestions based on the latest weather forecasts.
lg g4 front display
The LG G4 also brings some new interface action: LG UI 4.0. / © ANDROIDPIT
Samsung Galaxy S6 Edge vs LG G4: Performance
Samsung has gone all out as far as internal components are concerned for the Galaxy S6 Edge, though in our review we found some sluggishness in various parts of Samsung's own software. It includes a 64-bit octa-core Samsung Exynos 7420 clocked at 2.1GHz plus 3GB of RAM, and in terms of graphics processing power it's one of the very best mobiles out there.
Up against it the LG G4 opts for the Snapdragon 808 processor (featuring a mere six cores) and 3GB of RAM. On paper that puts the Samsung phone ahead, but the LG G4 is no slouch either, and it depends on how well LG has done with the G4's software and internal wiring as to how much oomph you're going to get out of this phone.
lg g4 samsung galaxy s6 edge back camera 3
The camera shootout between the LG G4 (left) and Galaxy S6 Edge promises to be a ripper. / © ANDROIDPIT
Samsung Galaxy S6 Edge vs LG G4: Camera
Thanks to Sony's latest IMX240 photo sensor, the Galaxy S6 Edge is capable of producing some stunning shots in a variety of lighting conditions. The rear-facing camera is a 16-megapixel model (photos up to 5312 x 2988 pixels) and there's a 5-megapixel around the front (photos up to 2592 x 1944 pixels). 4K video recording is also possible using the back camera.
The LG G4, meanwhile, also has a 16-megapixel camera at the rear of the device, and like the S6 Edge it features optical image stabilization (OIS) to steady your shaky shots. There's an 8-megapixel camera at the front too. We'll need to put the smartphone through its paces in terms of its photo-taking capabilities before we can declare a winner in this department.
LG opted to keep a removable battery in the G4 (left), whereas the Galaxy S6 now has a non-removable battery. / © ANDROIDPIT
Samsung Galaxy S6 Edge vs LG G4: Battery
Inside the Galaxy S6 Edge there's a 2,600 mAh battery, which in our testing lasts about a day with medium or intensive use. Unlike the S5, you can't remove and replace the battery, so you'll have to resort to a powerpack if you think that's not going to be enough. You can charge phone wirelessly if you want to.
The LG G4 features a bigger 3,000 mAh battery (though battery life isn't just about battery size of course). LG says it's good for 14 hours of talk time and 440 hours of standby, though until we write our official review we don't know for sure. You can, however, remove and replace the battery, giving the LG G4 another slight edge over the Galaxy S6 Edge.
Samsung Galaxy S6 Edge vs LG G4: Conclusion
In terms of specifications, the Galaxy S6 Edge lives up to its name by edging out the LG G4, but if you're not concerned about the G4's slower processor then the larger screen and clean UI might be a bigger draw. Both bring unique features to the table — a curved screen with the S6 Edge and a leather back with the LG G4 — but neither is likely to let you down. We'll have to wait to see how the display, performance and battery hold up in real life before delivering a comprehensive verdict.
Which phone would you prefer? Who made the biggest improvements?
Join the discussion
14 comments
  • Geoffrey Aberle May 4, 2016 Link to comment
    I am looking for a replacement for my Galaxy S3, with a 720p screen and ugly design. I will by no means switch to iPhone, as battery is crap and iOS is too hard to learn. Although I am looking at phones released in 2016, like the successors to the two in this look, I think the S6 would win.
  • Sivashankar Jul 24, 2015 Link to comment
    S6 edge won forever
  • Tom ML Jul 6, 2015 Link to comment
    Apparently the performance is relatively similar in real life usage. TBH performance feels similar with most flagship phones of the last 2 years, we're talking microseconds of difference - My M8 for example is only SLIGHTLY slower than my G4. As such I'd possibly concentrate on other things with this - the battery reports form the S6 have been VERY inconsistent, some saying its great, some saying it's terrible. Most say it's not as good as the S5. The majority of people on the XDA thread suggest it gets you about 3.5 hours SoT MAX, and standby time is OK at best. The G4 is pretty reliable - and the reviews are more consistent. Not to mention average users seem to report about 4-5 hours SoT as a minimum average.
    -Then there's the camera, which is better on the G4.
    -Then there's the SDcard slot, which the S6 doesn't have.
    -Then there's the FM radio, which everyone uses.... oh wait never mind.
    I also think the G4 wins over TouchWix. Yes it's a bit verbose, but it's cleaner, closer to stock android and seems to have less bloat - which makes that performance even closer. In the store I honestly couldn't tell the difference between the G4, M8 and S6 in terms of performance (sod the benchmarks!)
  • sacocheio May 11, 2015 Link to comment
    The S6 is beautiful, powerful... Oh, it does not have a SD slot?
    So long, Samsung. LG, here's my money.
    • Sam Wright Dec 11, 2015 Link to comment
      Yeah hows that mistake going?
  • Sam Brown May 8, 2015 Link to comment
    you failed to mention the f1.8 aperture on the camera, currently the best in any smartphone to date.
  • Xochitl Shatt May 3, 2015 Link to comment
    Samsung S6 is the best.
  • Joshua Mony Apr 30, 2015 Link to comment
    I moved from the G3 to S6 recently - the only thing I missed was the larger screen. As much as I liked the G3 it was handicapped by a screen that had poor contrast and color. The phone would heat up and began to throttle down. Compared to my Son's Z2 the G3 felt laggy and battery life was just OK - the screen was a battery killer
    So moving to S6 - no removeable battery - no SD card... I dont see the problem. Mind you I am a heavy user. I cannot remember I carrying a spare battery. Problem with a spare battery is that you need to also have a battery charger to keep the 2nd battery spiced up. I carry a fast charging battery pack that charges by Nexus 9 and my S6.
    I stream music alot from my phone to my bluetooth speakers. Problem with saving the music on the SD card on the G3 was that there was always a lag in between songs. SD cards are slow. S6 storage is really fast and I have a 64Gb with me so plenty enough
    And the one thing i have begun to appreciate is the physical home button - so convenient.
    Only issue I have with S6 is battery life. It is not too bad - good thing I have quick charging - really sweet. I used to hate Touchwiz but I actually like it now even more than stock Lollipop....(I hear screaming ...)
    G4 is a good attempt to distinguish itself from the pack. But its no S6 beater. And although LG did well by using the 808 processor mainly because of the overheating and subsequent throttling issues on the 810. Good camera, improved screen some refinement in software and probably improved battery life but its screen could still be a battery hogger compared to AMOLED screens
  • Moni Mihailov Apr 29, 2015 Link to comment
    Samsung really screwed up the S6. It should have been like the G4 in terms of features and options. G4 has Micro SD card slot, removable battery and FM Radio. If the Note 5 or S7 don't get these things back, I'm moving away from Sammy. Not to mention that S6 is practically featureless compared to the S5 which i currently own and love!
  • cherry Apr 29, 2015 Link to comment
    Samsung always works well with CleanWiz.
  • Reg Joo Apr 28, 2015 Link to comment
    What I don't get is why are the bezels bigger? same screen size, as last year. But, in any case, the samsung has that ufs storage, which starts a new generation in speed. The exynos, has been the faster, less power hungry processor, than qualcomm's offerings. Not saying the LG is inferior, hardware wise, but samsung came up with something special.
  • Bojan M. Apr 28, 2015 Link to comment
    I would rather you have it against the regular S6, but still, Samsung wins.
  •   16
    Deactivated Account Apr 28, 2015 Link to comment
    Performance wise S6 and S6Edge wins hands down no comparison.
