Android for Beginners: Galaxy S3 Camera – Beyond Auto Mode
ResolutionISO
Everybody loves snapping pictures with their Samsung Galaxy S3, but how many of us use any of the camera settings other than Auto Mode? While the S3 camera's automatic settings are pretty good, there's a whole bunch of other cool stuff you can do photographically with your S3 if only you know how. And I don't just mean all the other pre-set modes the device offers! Using Best Face or Beauty Mode doesn't make you a great photographer! So we've put together a basic introduction to the S3's camera settings to get you shooting better photos pronto.
Android for Beginners EN
This time we'll look at digital photography terms and Galaxy S3 manual settings. / © NextPit
Manual setting options and what they mean
The vocabulary of digital photography may be incredibly daunting if you're unfamiliar with it, but the good news is, it's actually not that hard to get a handle on. Mastering it is a different story, however! The terminology is, however, common to all digital photography, and there's only a few things you really need to concern yourself with if we're just talking about smartphones. I've used the S3 here for settings demonstration purposes and because it's such a popular device, but the definitions and general rules of thumb are common to all cameras.
Resolution
Resolution is the first thing we need to clear up. The higher the number on your camera, the more megapixels it can capture. The megapixel count relates to the camera's sensor, where all the image capturing happens (like film in traditional photography). A pixel is a single point of color, multiply this by a million and you have a megapixel. Multiply this by the number on your camera and you're talking a whole lot of pixels on the sensor. A higher number does not necessarily mean the camera is better, just able to capture more information. But this power is almost never necessary for the average photographer. It's like having a Ferrari engine in your lawnmower – there's not much point unless you're going to use it to its full potential. The S3 comes with a very capable 8 MP snapper that doesn't get to the point of pointless overkill.
ResolutionISO
Resolution tells you how many pixels are on the sensor, and ISO how sensitive it is to light. / © NextPit
Keep in mind that what we call Full HD (1920 x 1080 pixels) equates to roughly a 2 MP camera! And a 2 MP photo (1800 x 1200 pixels) can be printed at magazine quality (the equivalent of about 300 pixels per inch on your screen) at 4 x 6 inches – the size of your average printed photograph. Depending on the size of the display, the resolution may be wasted: if you're looking at a 13 MP photo on a tiny phone screen with poor resolution you'll never notice the difference. Likewise, unless you're cropping your photos a lot, taking 13 MP photos you'll never print in large format or broadcast on your huge TV is a waste of data storage space. The 8 MP S3 cam can comfortably produce excellent quality printed photos at 8 x 10 inches or even 8 x 12 inches (A4-size).
CameraAperture
Aperture simply means how big the hole in the lens is that lets light onto the sensor. / © Enchanting Kerala
Aperture
Aperture is a fancy word that means hole. The aperture of the camera simply means the size of the hole in the lens that allows the light to pass through it and onto the sensor. It's pretty easy to wrap your head around: the bigger the hole the more light gets through, the smaller the hole the less light gets through. Aperture is measured in a number preceded by the letter 'f.' Just to be a little confusing though, the number and what it means is inverted: the higher the number means the smaller the hole, and vice versa. Fortunately for S3 owners, the S3 camera has a fixed aperture of f2.6 (which is quite large) so you don't need to worry about changing it, but at least now you know what it means!
ISOcomparison
You can clearly see how much more grain, or 'noise', enters the image at higher ISO settings. / © CNET
ISO
ISO is pretty straight-forward too: basically, when you have low-light scenarios, like indoors with the lights out, at night or in dimly-lit places like restaurants or bars, you generally need to get more light going into your camera's sensor to be actually able to record an image. The problem with this is that the more sensitive to available light the sensor is, the more 'noise' you are likely to get too. Noise is the grainy quality you would more than likely already be familiar with when taking these kinds of photos. The lower the ISO number (eg daylight shooting) the less sensitive the sensor is to light (and thus 'noise'), the higher the number, the more sensitive. The S3 has a manual ISO range from 100 - 800, but from 80 – 1600 in Auto Mode (DSLR cameras can go to 6400 or so).
Shutter Speed
This one's a bit of a no-brainer: shutter speed simply refers to how long the sensor is open to the light that floods in. Of course, in an S3 there is no control over shutter speed, the shutter action is controlled by the processor activating the sensor. The faster the shutter speed the quicker the image is taken, meaning the shorter the amount of time the light has to get itself on the sensor. This is great for bright sunny days when you have more light than you know what to do with, but terrible when it's dark. You also need fast shutter speeds if you want to capture something moving very fast though, like animals, sports action or moving objects. The S3 handles these sitautions quite well.
camera shake1
Slow shutter speed (center) and not quite fast enough (right) show camera shake. / © Shutter Stoppers
Slower shutter speeds, inversely, are great for when there's less action or light in front of the camera, and they mean that the sensor is exposed for longer, capturing much more light and detail. As you can probably guess, the longer the sensor is open the more noise, camera shake and other assorted bogeymen can get into your photos. The S3 tends to prefer slow shutter speeds over higher ISO in low-light situations (in Auto Mode), meaning you'll get more camera blur but less noise – this is important to know if you want to get better shots in low-light. To get the highest ISO setting of 1600, you can not set the shutter speed, however, as you'll need to be in Auto Mode. You can get really nice effects with a stable camera and slow shutter speeds, like light tracing, if you know how to set it up. There's plenty of photo tool apps available that will let you do this.
exposure modes
You can set your metering mode to scan the whole frame or just a part of it. / © All Ears Blog
Metering Mode
Metering Mode is kind of like the auto focus point – it tells the camera which part of the frame you want to be exposed optimally. If your S3 is giving you grief on this front (either constantly over or underexposing your shots) this could be the problem, but you can change the metering mode manually. Like most digital cameras, the S3 has three metering modes: matrix, center-weighted or spot. Matrix metering, besides sounding cool, lets the camera know that you want to give equal importance to everything in the frame, so it will assess light from all sources and try to expose the shot to the best of its abilities. This is great for beginners as it handles complex lighting arrangements quite well. Centre-weighted metering will give priority to the area in the centre of the frame and take a little from both extremes of light, giving you as balanced a result as possible, although prioritizing the central area. Spot metering takes the exposure information from a very small area, which you can place anywhere you like to take the light metering reading from, kind of like focusing on an object and then reframing the shot.
WhiteBalance
Color casts in an image can clearly be seen by changing white balance. / © Vassia Atanassova - Spiritia
White Balance
Again, pretty self-explanatory, white balance is simply the way in which the white in your photos is balanced with the white objects you're photographing. Times of day and light sources affect the white balance. For example, early morning or evening photos and artificial light sources like fluorescent tubes or Tungsten lighting can drastically change the color tint of your images. While our eyes manage to handle this kind of change easily, smartphone cameras struggle. So if you always seem to end up with blueish, pinkish or orange tinted photos, now you know why. Fortunately, smartphones come with plenty of preset white balance modes than can solve most problems if Auto White Balance isn't producing the result you want to see. If you familiarize yourself with these common settings and what situations they are suited to, your photos will start looking much better much quicker.
Screenshot 2013 08 09 16 29 03
Get your photo whites matching reality under different light sources. / © NextPit
Relationship Advice
So what does this all mean? Ok, so if I haven't lost you yet, all you really need to know are two things: first, that almost all of these options operate in relationship to one another, so once you've learned the relationships you're well on your way. Daylight: low ISO/fast shutter speeds. Night time: higher ISO/slower shutter speeds. And the second is that you shouldn't be afraid! Instead of burning endless hours surfing the web in your downtime, try to get to know your device better, scroll around the camera options and try out a few shots and see what results you get. There's also a lot of apps available with other pre-set shooting modes and you can also set up your own preferred settings as user-defined modes for things you shoot frequently.
overexposed and underexposed
Underexposure: not enough light. Overexposure: too much light, burning out the image. / © Exposure Guide
The best news for smartphone photographers learning these features is that your S3 has a fixed aperture and doesn't give you any control over shutter speeds. So two parts of the relationship already taken care of! An aperture of f2.6 allows a lot of light in all the time. This means your shutter speeds are generally going to be very fast as there's so much light hitting the sensor you don't need it activated for long, this also limits the effects of camera shake or motion blur. Likewise, your ISO can stay low because you don't need the sensor to be extra-sensitive if there's lots of available light. So, the larger the aperture (or the higher the ISO setting), the faster the shutter speed you can use to get the same amount of light.
Low-Light Settings
When it comes to low-light situations, however, things need to change, and this is where most smartphone photographers experience problems. Because the aperture of the S3 is fixed, if you're having issues with low-light photos, you need to change your ISO setting (because you can't control shutter speed). The higher the ISO the faster the shutter speed will be to stop too much noise entering your sensor, but because there's not much light available, you run the risk of camera shake, especially if you're holding the camera vertically (as it will move when you hit the shutter button). Because you only have limited controls over what the S3 can do, this is one of the main areas the S3 camera is limited, despite its Low-Light Mode. But you can do a few things to try to better your photos: use spot lighting to light the focus area before taking the photo, so the S3 knows where to set the focal length (you'll have to be quick though as the S3 refocuses quickly!), or you can make the camera as stable s possible to avoid shake. Just find a stable surface and put your phoen on it to snap.
LowLight
High contrast and low-light situations can cause camera shake, noise and exposure issues. / © NextPit
This is a very basic introduction to digital photography beyond Auto Mode on your S3 and should not be taken as authoritative. I am certainly no expert. There's also heaps of other pre-set modes that can handle a wide range of situations, if only you bother to use them! It was the intention of this article to let you see that it's not all so complicated once you know the terms and what they mean and how they relate to one another. You simply need to play around and fine-tune your settings to get the results you want. But once you can do this, you'll see your S3 in a whole new light and may be ready to tackle a real DSLR. By the way, did you know your S3 can enter camera mode simply by touching the lock screen and holding your finger down as you rotate the phone to landscape orientation ? Neat, huh? So get snapping!
Do you want to know more about your phone's camera options? HDR? Dynamic range/contrast ratios? Low-light portraits without flash? Let us know what photos you want to take!
Go to comment (11)
Kris Carlon
Kris Carlon
11 comments
  • Kris Carlon 35
    Kris Carlon Sep 2, 2013 Link to comment
    Just reading about the upcoming Acer Liquid S2 which will have 4K video recording capability. It will also have 5 customizable camera modes, called ''Favorites'' so you can save your preferred settings for various situations. This feature will undoubtedly appear for other handsets as soon as the code is available.
  • Kris Carlon 35
    Kris Carlon Aug 14, 2013 Link to comment
    Sorry to hear it Barb, but don't give up on the S3 camera too quickly because it's a pretty great camera! And generally speaking the S3 will opt for slower shutter speeds and lower ISO in low-light (to avoid grain) and in daylight there shouldn't be any problems with ISO settings, as the S3 would automatically choose something very low like 80 or 100. So hopefully you won't have to manually set ISO all that often.
    Barb Kline-Dols Aug 13, 2013 Link to comment
    Mine doesn't stay running. I don't like the camera with this phone. I'll just use my own Olympus camera. thanks for trying to help.
  • Kris Carlon 35
    Kris Carlon Aug 13, 2013 Link to comment
    HI Barb, when you exit an app, say by hitting the home button, the app is almost always still running (and in the quick test I did on the S3 the ISO setting stayed as I left it). You can check if an app is still 'on' in the 'Running' tab of your apps list, or in any Task Manager app you may have installed. When you hit the S3's menu key (bottom left next to Home) you'll see the tile cascade of all the apps you currently have running. You can either swipe these off the screen to stop them running, or you can use app-killers as I mentioned.
    In the ISO setting, I click 100 then go ahead and use camera and shut 'off' when done. When I come back to camera & settings the ISO must automatically go back to Auto, You mentioned 'exiting the app' what's the difference between that and 'shutting down the camera app'?
  • Kris Carlon 35
    What mode are you in Barb? In Auto Mode, if you set the ISO yourself and then exit the camera app, the ISO setting will remain when you return. The only time ISO resets back to default is if you completely shut down the camera app, which is what will happen if you use the app killer or another task manager (to free up RAM for example). You can always download an app that lets you set your own preferences as default too.
    Barb Kline-Dols Aug 12, 2013 Link to comment
    S3. why can't I keep the ISO at 100? or which ever. Is there a way?
    after leaving camera, then returning you have to go back and reset the ISO. :-(
  • Kris Carlon 35
    Kris Carlon Aug 12, 2013 Link to comment
    Hi ljhaye, I just used the S3 for demonstration purposes here (for settings ranges etc), but the terminology and basic relationships are standard for all digital cameras, so hopefully the article is still of some value to non-S3 owners!
  • 22
    ljhaye Aug 11, 2013 Link to comment
    Don't you think this series should focus on android software? What if you don't have a galaxy s3? I for example don't, I'm so sick and tired of Android being identified and defined by samsung galaxy products.
    • James Strickland 2
      James Strickland Sep 9, 2014 Link to comment
      who cares? then do a specific search for your phone...I do have a samsung galaxy s3 and did a specific search to find this information and it took me here! So quit the bitching...instead of complaining find a guide for youre own phone! And why would they do a generic story on android? Each phone has different settings and camera resolution and capabilities...just doing Android wouldnt help anybody!
      aklashlee Apr 30, 2019 Link to comment
      Not sure how you got here but I did a search and came right here. The title " Android for Beginners: Galaxy S3 Camera – Beyond Auto Mode" should have been the hint. Try searching for your own phone!
