Shortcut to problem:
- Won’t turn on
- Poor battery life
- Touchscreen doesn’t work
- Phone calls sound bad
- Device freezing
- Not detected through USB
- No network coverage
Sony Xperia Z5 won’t turn on
Trying to turn on the Sony Xperia Z5 and instead being left staring at a blank screen is mighty annoying, but thankfully Sony suggests some fixes for this particular Z5 problem.
One potential solution is to try a forced shutdown. Open up the cover for the nano-SIM card and memory card slot, and using the tip of a pen or a similarly-sized object, press and hold the OFF button for a couple of seconds. The Sony Xperia Z5 will vibrate three times, after which you can release the OFF button. Try turning the device on to see if the problem is solved.
If you’re still hitting a brick wall, it’s worth trying a two-minute restart, which is done by pressing and holding the OFF button for around 120 seconds. Ignore any vibrations you feel during this two-minute window – only release the OFF button when the time is up. Plug the Xperia Z5 into a charger and, when you spot a charging icon on the screen, try powering it on.
Sony Xperia Z5 has poor battery life
Trying to survive with a smartphone with poor battery life is a nightmare, but thankfully there are plenty of third-party apps around that might just save the day.
Greenify is one of the most reliable performance-boosting apps, and it’s free to download, which makes grabbing it a no-brainer. The app puts programs into a state of hibernation to reduce the strain they put on the Sony Xperia Z5 when they’re not in use.
It’s worth noting that Greenify requires a rooted device to work at its very best, but there are plenty of features tucked into the app for non-rooted users.
If you’re not convinced by Greenify, there’s a whole host of alternative solutions that are worth taking a closer look at. It’s possible to squeeze more out of the Sony Xperia Z5 if you activate STAMINA mode, for example, which disables Wi-Fi and mobile data while the screen is turned off.
Ultra STAMINA mode takes things a step further by limiting everything except ‘core tasks’ such as the ability to send and receive calls and texts. Reducing screen brightness or removing live wallpapers also makes an impact.
Sony Xperia Z5 touchscreen isn’t working
The touchscreen on the Sony Xperia Z5 may be affected by custom screen protectors, so if you have one, it’s worth removing it to see if it’s the cause of the problem. If not, Sony says that excessive heat can also affect the Sony Xperia Z5’s display.
As we mentioned above, manually resetting the Sony Xperia Z5 using the button near the memory card slot can work wonders. As an added bonus, you won’t lose any settings or personal data by trying this out.
Using Sony’s own Xperia Diagnostics application, it’s possible to carry out a test to see if the phone identifies a problem itself. From the Sony Xperia Z5’s home screen, head to Settings > About phone > Diagnostics > Test. Follow the on-screen instructions and await results with crossed fingers.
The free-to-download PC Companion app is a great resource for resetting the Sony Xperia Z5, so we recommend you grab the tool yourself and browse through its Repair menu. Sony notes that content stored on an external SD card, such as photos, videos and music, is not deleted when using the software.
Sony Xperia Z5 phone calls sound bad
Some Sony Xperia Z5 owners have noted a drop in audio quality during phone calls, which can sometimes be resolved by adjusting sound enhancement features.
Before you adjust the audio settings, though, try restarting the Sony Xperia Z5 and to see if that solves the problem. On top of that, check your network signal strength and ensure your hand (or screen protector) isn’t accidentally covering the microphone or speaker.
To set the call audio equalizer to normal, head to Settings > Call > Equalizer. From there, tap Normal and then see if you notice any changes in quality. To turn off slow talk, head to Settings > Call. Drag the on-screen slider to the left.
If you’re still having trouble, try swapping out your SIM card to see if doing so fixes the issue. It might be that your existing SIM is damaged and is therefore affecting your calls.
Sony Xperia Z5 keeps freezing or lagging
If your Sony Xperia Z5 is freezing or lagging, trying out Safe Mode might help you to identify the problem. The thinking here is that an application you recently downloaded may be having an impact on performance.
To enable safe mode, turn off the Sony Xperia Z5 and then press and hold down on the power key until you feel a vibration. When you see the Sony and Xperia logos, press and hold the volume down key until Safe mode appears on the screen.
When you activate safe mode, only applications that shipped with the device load up. If you notice an instant improvement in performance, it’s likely something you downloaded is doing the damage. If that’s the case, get rid of some recently-downloaded apps or run Sony’s PC Companion tool.
Sony Xperia Z5 not detected by computer through USB
If you’re trying to connect the Sony Xperia Z5 to your computer and things aren’t going your way, the first thing to do is check the cable itself for damage. Even the slightest damage to the cable can cause syncing issues, so try another cord if you can.
It’s possible to manually check if the Sony Xperia Z5 is set to recognize a USB connection. Head to Settings > Xperia Connectivity > USB Connectivity > Detect USB device.
Another potential solution to this irritating problem is to restart your computer and update your USB drivers. To update the drivers, access Sony’s PC Companion tool and check for updates from there.
Sony Xperia Z5 has no network coverage
If you’re experiencing issues with network coverage on the Sony Xperia Z5, your first mission should be to reselect a network mode by heading to Settings > More Mobile networks. From there, tap Preferred network type, then select a network mode. Experimenting with these settings and then restarting the phone can do some good.
It sounds obvious, but having Airplane mode activated will prevent the Sony Xperia Z5 from receiving network information. Ensure this mode is turned off and make sure the same can be said for STAMINA mode. When activated, STAMINA mode pauses mobile data and Wi-Fi connections.
Contacting your network provider is the next step if you have further questions.
Many other Sony Xperia Z5 problems can be resolved by using Sony’s PC Companion tool, which we’ve mentioned several times above. We recommend you run the software yourself before you contacting Sony over the phone.
Are there any other Sony Xperia Z5 problems that we haven’t covered? Do you know the solutions? Let us know in the comments section below and help each other out while you’re at it.
Hi, I’m from Argentina I want to tell my story, travel to Spain and buy the Z5 6653, after a few days of use I saw the device too hot even being in the pocket of my pants, the battery did not last even 10 hours and hurt me a micro SD card. I went to "mediamark" and I changed the Z5 in the act. Today I am in Argentina again, but I have new problems with my new Sony Z5, the camera button does not work, if I get to use the flashlight it starts flashing to the point that appears to be damaged and dark brown the LED and finally I have many problems to detect OTG flash drives, disconnect them alone.
I want to comment further that I had a Z3 and soak it in the sink you income water display, so sony recognized me guarantee, that is why in waiting warranty I bought the Z5 and look for everything that happens.
Beyond all I want to say that the Z3 and Z5 devices had were some amazing terminals, I guess sony should have lowered production costs. the result, many guarantees.
my current Z5 can not send it to Spain by warranty for costs in Argentina sony I do not recognize anything.
hi i just got z5 when charging it keeps turning off and showing a filling up battery is there any way to stop this
This is by far the worst phone I’ve ever had. Not buying a Sony’s phone again in my life. After using Samsung Nexus family for many years, a LG G4 and a couple of Galaxy phones, this is by far a scam. Unconfortable, dark screen, touch-screen way too sensitive, NOT IP68 complaince as Sony claims, battery takes forever to charge to 100%. It’s a rip-off.
after latest update my phone wont turn on at all, tried all tricks above with power off button etc wha to do
Thank You!!! The "Open up the cover for the nano-SIM card and memory card slot, and using the tip of a pen or a similarly-sized object, press and hold the OFF button for a couple of seconds" worked like a charm, Nowhere else had any info and the next option was sending in for repair… you made my day Charlie M. from 8 months ago <3
it collapses and freezes and get black screen then it starts again from the beginning with Android Welcome screen,
this is normal,
Sony does not want to help me
my shop does not want to help me
please help me
nice try
Also, the front facing camera was damaged, and shows frantic white lines that race across my screen, it overheats, and becomes extremely uncomfortable, And has a low battery life, although i keep it on stamina mode, and don’t overcharge it.
i have the same problem. do u guys found any solution??
I m facing problem with since last software update…
Ringer is not audible and i face sam problem with music and vedio too…
Dear all,
I am facing very serious issues with my Xperia z5 premium, 5 month back my mobile fell down and I get replacement of lcd. After that I am facing mention below issues :
1-Heatup: after 4 to 5 minutes running of YouTube, mobile generate too much heat and close the application. Same using of camera my mobile get too much heat and shut the application.
2- My network drop the data signals ? and I need to switch on/off the data every time.
Please help me to sort out these issues.
Thanks
I doubt there is very much that we can do about that. Where did you get the screen replaced? Was it by an official retailer or just a normal shop? To me it sound like something else was damaged when you dropped your phone. You can either a) go back to the shop where you got your screen replaced and tell them about your issues or b) get in touch with sony and tell them about your software issues
Dear Georg, thanks for your message, this is my major mistake that I go to the normal repairing shop and get repair, I will go to the main Sony repair center in Dubai area.
how
Hi,
My Xperia Z5 has just started ( The morning of Tues 11th Feb 2020 ) randomly turning it’s self off every so often and then it will stay on, but have no signal on phone. Checked setting’s and all seemed fine, could find other networks other than mine, so thought it was a sim fault. So I popped it in my old phone & sim worked fine. Done a bit of playing about with it turning it’s self off randomly through out morning and then it turned itself on & it was working fine after about 3hrs. It worked fine for the rest of the day and all the way up to about 11:30 at night the following day and it starts it’s crap again, of & on randomly & no signal again. Still doing it now ( 12:50pm Thur 13th Feb 2020 ).
I have no idea what the hell is going on with it. So if you can help, please do.
Thanks
Hi,
my Z5 goes to a blank screen after I make a call. This means I can’t:
– press any numbers if so directed by an automated operator,
– hang up at the end (or part way through a call).
It doesn’t come back to the home screen (or any screen) for quite some time (at least 20 seconds) after the call has ended.
Looking forward to a solution!
my sony xperial z5 premium is not displaying but is working perfect, and the screen touch lcd is displayed on another, what happened to my own phone?
My Sony Xperia Z5 E6653 keeps re-booting on its own, I have used the Sony companion to save my documents & photos, software updates used, re-installed my documents & photos but problem persists, battery has been changed three times due to power dropping excessively when re-booting so it cannot be the battery. I have tried all the previous fixes with the power button & up & down volume, also in safe mode but still re-boots. I have seen lots of other people with this same problem, do you know about a fix for this.
Hi I have My Sony Xperia Z5 E6653 Awesome phone in till it started with A re-Booting problem then I did what Support said I must do(safe mode boot, Factory Reset & soft ware update) then i had a problem with the charging & suddenly my phone will run flat at 72 % battery capacity! Then as soon as i got it to final get fully charged to 100% 2 nights ago take note that the whole day it didn’t want to go on! I took it off Charge and finally got it to turn On and got to the Home screen and it turned off and hasn’t turned on yet! Have tried the Off button Move by sim holder like this page says still no luck what must i do Please help?
Ya, it happen to me too
