How to turn off the camera shutter sound on Android
Hero Melhores Cameras
Most smartphones produce a fake shutter sound when you take a picture. It can be loud and annoying, especially when you’re trying to discreetly snap a candid picture of a friend or a bunch of selfies. Getting rid of the shutter sound can be as easy as turning down the volume on some devices, whilst for others, a little more effort may be involved. Find out how to turn off the camera shutter sound on your phone below.
Before you turn off the shutter sounds on your phone, here's a word of caution. In some territories, privacy laws make it illegal for anyone to turn off the camera shutter sound. Make sure that it is legal in your location before following any of the instructions below.
Jump to
How to turn off the camera shutter sound on stock Android
Devices like the Google Pixel 3 run a stock version of Android which until recently did not have a camera setting for disabling the camera shutter sound. That isn't the case anymore. On the Google Pixel 3 running Android 11, I was able to turn off the camera shutter sound by going into the camera settings. Here's how you can do it too.
  • Open the Camera app
  • Tap the small arrow symbol at the top
  • Tap the small gear icon on the menu that appears
  • Make sure the Camera sounds option is turned off
Camera Shutter Stock Android
This is how you turn off camera shutter sound on stock Android / © NextPit
In some countries, this option may not be available on the local firmware. In such circumstances, you will have to turn your notifications/alerts profile to silent, do not disturb, or vibrate. This can be done using the volume keys on the side of your device that act as master volume controls, or in the Sound section of the Settings menu. Newer devices that run near-stock Android tend to use the same intuitive method.
pixel 2 xl shutter sound
Use the volume button or the Settings menu to turn the sound off on newer smartphones or those running stock Android. / © NextPit
How to turn off the camera shutter sound on a Samsung
On newer Samsung devices, there usually is an option to turn off the camera shutter sound. Once again, this is highly dependent on the localized firmware your phone is on. In case the feature is enabled on your Samsung device, you can access it in the following manner.
Navigate to and open the Camera app, and then tap the Settings icon. Swipe to and tap the switch next to Shutter sound to disable it.
  • Tap the Settings icon
  • Swipe to Shutter sound
  • Disable it
On devices that do not have this option, all you need to do is change the master volume settings and the shutter sound will turn off when the phone is set to vibrate, do not disturb, or silent mode.
samsung galaxy s9 plus shutter sound
On Samsung smartphones like the S9+, you just have to silence the phone.  / © NextPit
On some older Samsung devices, you have to hit the cogwheel in the camera app and you will find the Shutter sound option on the following page. Switch it to Off for some peace and quiet.
androidpit camera shutter 4
This is how to disable the camera shutter sound on older Samsung smartphones. / © NextPit
How to turn off the camera shutter sound on an LG
Like stock Android, LG’s camera app doesn’t have a camera shutter sound option in the settings. Instead, it is tied to your smartphone's master volume setting. Set this to silent, do not disturb or vibrate and you won’t hear a sound when you take a photo.
lg g6 shutter sound
You can mute the shutter sound by silencing the master volume of the smartphone. You can also snap a photo by saying "cheese". / © NextPit
How to turn off the camera shutter sound on an HTC
If you're still using an HTC smartphone, the process for turning off the shutter sound is the same as for stock Android devices. Just change your master volume settings to vibrate, silent or do not disturb, and the shutter sound will be silenced.
htc u11 shutter sound
Silence HTC phones using the master volume keys or settings menu to turn off the shutter sound. / © NextPit
On some older HTC models, disabling the camera shutter sound can be a convoluted process, but it is still effective. From your camera app, drag down the two lines in the top middle. You will a variety of photo options. Scroll to the left until you see the Settings icon. Tap on it and untick the Shutter sound.
androidpit camera shutter 5
This is how to disable the camera shutter sound on older HTC smartphones. / © NextPit
How to turn off the camera shutter sound on a Motorola
For newer Motorola phones, you can perform these steps to turn off the camera shutter sound.
  • Tap the gear icon to open Camera settings
  • Look for the Shutter sound option and toggle the button to off
In case this option is not available,  use the master volume controls to set the camera shutter sound. Simply set your phone to silent, do not disturb or vibrate to ditch the camera shutter noise.
motorola moto g6 plus shutter sound
On the Moto G6+, just silence the phone to ditch the shutter sound. / © NextPit
Some older Motorola phones have a little dial that slides in from the left-hand side of the screen. The loudspeaker icon represents the shutter sound. Just tap it to enable or disable it.
androidpit camera shutter 1
This is how to disable the camera shutter sound on Motorola. / © NextPit
How to turn off the camera shutter sound on a OnePlus
Follow these steps to turn of camera shutter sound on new OnePlus devices like the OnePlus 9 Pro and the OnePlus 9.
  • Open the Camera app.
  • Tap the three dots on the top right corner.
  • Tap on Settings.
  • Scroll down and look for the Shutter sound option.
  • Turn it off.
 On older OnePlus devices you will need to swipe in from the left side of your screen and then tap the cog wheel, which will be on the right (either at the top or bottom). You will see the shutter sound option in the window that then opens. Set this option to Off.
oneplus 5t shutter sound
This is how to disable the camera shutter sound on a OnePlus phone. / © NextPit
How to turn off the camera shutter sound on Oppo/ Realme smartphones
  • Tap the three lines at the top right corner
  • Tap on Settings
  • Make sure the toggle on the Shutter sound option is set to off
Camera Shutter Sound Oppo Realme
These are the steps to turn off the camera shutter sound on Oppo and Realme smartphones/ © Nextpit
How to turn off the camera shutter sound on Xiaomi smartphones
On Xiaomi smartphones, the steps to turn off the camera shutter sound are as follows
  • Tap the three lines on the top right corner
  • Tap on Settings
  • Scroll down and locate the Shutter sound option
  • Toggle the position to off
Camera Shutter Sound Xiaomi
Here are the steps to turn off the camera shutter sound on smartphones running Xiaomi's MIUI / © NextPit
How to turn off the camera shutter sound on a Huawei
On newer Huawei devices, open the camera app and swipe to the left to open the Settings menu. Then turn on the Mute setting to turn off the camera shutter sound.
huawei mate 10 pro shutter sound
Mute the shutter sound on a Huawei in the camera settings menu. / © NextPit
Disabling the camera shutter sound on certain older Huawei devices takes a few steps. Go to the camera app, then hit the menu icon (three lines), and then the settings button (cogwheel). Next, go to Mute and enable it. This is will disable the camera sound.
androidpit camera shutter 6
This is how to disable the camera shutter sound on an older Huawei. / © NextPit
How to turn off the camera shutter sound on a Honor smartphone
On newer Honor devices, you can change the settings within the camera app by tapping the gear icon, then turning the Mute option on. Alternatively, you can just use the master volume keys to silence the smartphone entirely, including the shutter sound.
honor 10 shutter sound
Mute the camera shutter noise in the camera app settings of the Honor device. / © NextPit
How to turn off the camera shutter sound on a Sony
Some new Sony smartphones have a dedicated camera shutter sound button within the camera settings. Here's how you can access it.
  • Tap on the Settings cogwheel icon on the top right corner
  • Scroll down to see the Sound option
  • Make sure the toggle is set to off
Some Sony devices use the master volume controls to turn off the camera shutter sound. Simply set the device to silent, vibrate, or do not disturb.
sony xperia xz2 shutter sound
Just silence the master volume on the Sony Xperia XZ2. / © NextPit
On some older Sony Xperia devices, go to your camera app, tap the three dots (hamburger) icon menu, then the cogwheel, and set the Sound slider to Off to disable the shutter sound.
androidpit camera shutter 2
This is how to disable the camera shutter sound on older Sony smartphones. / © NextPit
Are you having issues turning off the camera shutter sound on your smartphone? Let us know in the comments if you have any problems!
This article was last updated in May 2021. Older comments have been retained.
Go to comment (19)
Brittany McGhee
Brittany McGhee
Editor androidpit.com
19 comments
    DAS01 Jan 12, 2020 Link to comment
    The fundamental problem is that on Samsung phones and, it seems, on other Androids, you cannot actually turn off the shutter sound, but have to resort to manually adjusting the master volume. Apparently this is because in some countries you are not supposed to be able to turn off the shutter sound.
    There was no such problem on my old MS Lumia, from which I have just 'emigrated'.
    My workaround is an app I found. Just leave it running all the time, and it simply turns off (all) the sound when the camera app is activated. As soon as the camera is 'closed', all sounds come back on.
    This app (Camera Mute) does not 'take over' the camera app and/or add features like some of the other 'silent camera' apps do.
    Although it does not deal only with the shutter sound, it is an acceptable workaround. Haven't worked out, however, why the app switches itself off, seemingly at random...
    Sahana Sri Apr 24, 2019 Link to comment
    In some mobile we have disable and in some mobiles we can't do disable
    Neha Reddy
  • 27
    Sorin Dec 21, 2018 Link to comment
    There are situations when the shutter sound has to be disabled, so as not to be disturbing. Otherwise, it's useful because you know when you took the picture and by mistake you did not press the button correctly.
  • Mark Richey 1
    Mark Richey Sep 26, 2018 Link to comment
    in one of those countries that does not allow disabling the sound. However, on my new Nokia 7 plus, the sound chirps every time the shot is taken on the panorama setting. My god. Dozens. A roar. Can't something be done?
  • BruinGuy 20
    BruinGuy Jun 4, 2018 Link to comment
    Samsung Galaxy Note 8: Go into settings and turn off "shutter sound"
  • Rusty H. 33
    Rusty H. Jun 4, 2018 Link to comment
    I just turn the volume down. Reminds me of the old days, when the government/NASA whoever developed the ink pen with the pressurized ink cartridge, that would write upside down in zero gravity. When showing it off to the Russians about the accomplishment, the Russians said, we just use pencil.
    Sorin
    Michael D'Angelo Aug 22, 2017 Link to comment
    Stock Android Nexus 6P running 7.1.1 has a toggle to turn the shutter sound off.
  • Juan Carlos 1
    Juan Carlos Dec 4, 2016 Link to comment
    I own a CAT S60 with Android 6.0.1, none of the options helped me silence the camera shutter sounds. Can you help? Thanks
      Rahul Thakur Aug 21, 2017 Link to comment
      just throw your phone in fire and thats it😂
    Ywc Nov 28, 2016 Link to comment
    Hi, my device is LG G5, recently got updated to Android 7. I tried muting my phone to 'Do Not Disturb' but I can still hear the annoying shutter sound :(
    Also tried those apps where it helps u disable the shutter sound, but didn't work.
    Any ideas? Anything is appreciated :)
    • Cosmo 1
      Cosmo Dec 3, 2016 Link to comment
      Exactly the same, Updated to Android 7.0 completely muted phone but still hear the shutter sound at highest level, really annoying ..
  • Kaz M 1
    Kaz M Nov 23, 2016 Link to comment
    I figured out this much so far. While I was on vacation in Japan, I insert SIM for Japanese network service provider,
    the ON/OFF switch in Camera application disappears (means it is always ON, regardless Data Only SIM or Talk SIM).
    I thought Android figures out where I am from GPS, then it disables the ON/OFF switch, but that's not the case.
    When I came back to Canada, it stayed the same way (makes shutter sound) but as soon as I removed Japanese SIM, the ON/OFF function becomes be available. Canadian or US SIM doesn't do this.
    From this, I think somehow Android looks into the some data for origin of SIM where service available.
    It is required to make shutter sound on cell phone Camera in Japan. This occurs in all of my SONY Xperia (Tipo, Go, M, Z Ultra, Z3 Tablet). Just for your information, Windows Phone doesn't care about SIM.
  • Rúben Martins 1
    Rúben Martins Jul 4, 2016 Link to comment
    I cant disable de Camera sound on huawei ascend g6 HELP ME?
    thenext Mar 7, 2016 Link to comment
    i have translate this article in persian in
    thenext.ir/software/os/android/%D8%BA%DB%8C%D8%B1-%D9%81%D8%B9%D8%A7%D9%84-%DA%A9%D8%B1%D8%AF%D9%86-%D8%B5%D8%AF%D8%A7%DB%8C-%D8%B4%D8%A7%D8%AA%D8%B1/
    gautam mangal Jan 3, 2016 Link to comment
    Hi.
    My device is spice dream uno 498 .and i am using android 6.0.1
    Your apk does not work for me.
    Plz help me to silent the shutter sound.
    Thank you
    Manish Sharma Dec 4, 2015 Link to comment
    In my samsung galaxy s6 there is no setting for turning off shutter sound.
    • 32
      Deactivated Account Jan 18, 2016 Link to comment
      You can disable shutter sound in VIBRATE MODE or use silent camera
      Sorin
    Noy Valencia Sep 3, 2014 Link to comment
    http://youtu.be/_eTcqQDLI7c
    Disable Android Camera Shutter sound
    - no need to root
    - any android version
    - any android devices
    - any camera apps
