How black wallpaper can save your Android battery
Samsung Galaxy S10 03
Most people know the display is one of the most battery-hungry elements of any smartphone, but what they don't know is that the wallpaper they choose – yes, wallpaper – can make a significant difference to battery life. A pure black or generally dark-colored wallpaper or background can actually save power over a lighter one. It just depends on the type of screen you have.
First off, we need to share a bit of display technology information. In the smartphone market, the majority of displays are either AMOLED or LCD. I won't go into too much detail, but if you want to know more (and which one is better for what), you can check out our Smartphone screens explained article. If you just want the black wallpaper, skip ahead to the bottom of the article.
Jump to:
Display tech explained: LCD
LCD stands for Liquid Crystal Display and it's the same kind of technology you'll find in your televisions, monitors and so on. As the name suggests, Liquid Crystal Displays are actually crystals, and as such, they don't emit light of their own but rather transmit light from a light source behind them.
This means that even if you're looking at black on your smartphone or tablet screen, it is actually black lit up from behind. Therefore, LCDs don't really display 'true' black. The LG G7 THinQ has an LCD display, as does the HTC U11 Plus, Huawei Mate 10, and Sony Xperia XZ2.
AndroidPIT HTC U11 Plus vs Huawei Mate 10 1946
Older phones like the U11 Plus and Mate 10 often use LCD displays. / © NextPit
LCDs are also quite power hungry, because every pixel needs to be illuminated whenever the screen is in use.
Display tech explained: AMOLED and OLED
AMOLED stands for Active-Matrix Organic Light-Emitting Diode and it is also used for televisions screens but more notably, for smartphones. OLED displays are similar, but do not use an Active Matrix.
Samsung displays, for example, are usually AMOLED: the Galaxy S10Galaxy Note9Galaxy S9 for example, all use an AMOLED display, as does the Google Pixel 3.
The screen is made up of organic material that actually produces light when a current is passed through it – electroluminescence. AMOLED displays are easier on your battery because every pixel is not always lit up. They also show 'true' blacks because there is no back-lighting.
Battery life: AMOLED vs LCD
AMOLED
You can probably see where this is going: if you have an AMOLED display then you can save some battery life by using black wallpapers, or generally darker wallpapers and themes.
Our friends at XDA Developers did a little experiment and figured out that you can save about 6 percent battery life per hour at 20 percent brightness by using a black wallpaper on an AMOLED display, and about 8 percent per hour at full brightness.
These results are based on an always-on screen, but the basic theory holds up even if the figures are not exactly set in stone. Another tester using a different method came up with a general 18 percent saving over the course of a day.
LCD
What about LCD battery saving wallpaper, I hear you ask? Sorry, LCDs rely on back-lighting, so there's nothing you can do to save battery there.
The only thing you can do is set your device to Battery Saver mode and try not to turn your screen on all the time. Keep your display brightness as low as possible and your screen timeout nice and short.
The good news is you can have the brightest colored wallpaper and themes imaginable and it won't make a difference to your battery. Just think about that when you look at the gloomy screens of AMOLED owners clinging to their extended battery life (just don't stray too far from a charger while you gloat).
androidpit samsung galaxy s5 black wallpaper screenshot
It's not exciting, but it'll save battery power. And it doesn't have to be pure black, just dark. / © NextPit
Other battery life tips for AMOLED screens
There are other things AMOLED owners can do to maximize their battery life, such as setting as many app themes to be as dark as possible.
If you can change the appearance of a bunch of apps you use frequently, you can save even more battery life. After all, we spend more time in apps than on our home screens. You can also set your text and email preferences to have a black background and use white text, depending on your device and chosen apps.
The easiest way to figure it out for yourself is to fully charge your device as is and wait until it's almost totally dead and look at how much of your battery was used by the display. Just go into Settings and look for Battery, usually in the Device Settings/Device Maintenance section.
Make a note of the percentage your display has used up, then while recharging your phone, switch to a black wallpaper and repeat the cycle to see the difference.
Give me black wallpaper now!
To download a straight black wallpaper for your smartphone background, hit the link here, and don't forget to change your app themes to be as dark as possible to enhance the battery-saving effects.
You can also set a darker system-wide theme for your device, change your screen timeout setting to be as short as possible, enable power saving mode, turn off auto-brightness and see how great the battery savings are.
Of course, your battery is used by more than just display, so results will be dependent on your phone usage habits, processor and other variables, but the savings will still be worthwhile.
Did these black wallpaper tips save you some battery life? Do you have any other tips for conserving battery life? Share them with us in the comments!
Go to comment (38)
38 comments
    Doug May 14, 2018 Link to comment
    Your link to black wallpaper works just fine! I click and the screen goes black! Minimum battery use! Minimum phone usefulness!
    Anyway, my phone has a gray wallpaper which suits me fine.
  • Albin Foro 30
    Albin Foro May 12, 2018 Link to comment
    The poet below has it right: homescreen's aren't even on for very long and app screens often are. Skype just came out with a dark theme, so maybe some developers are reading poetry. (Personally, set my LCD homescreen with a 15 second time-out, Greenify background drains, and use browser sites instead of installing resource-hungry apps that do the same thing.)
    Sorin
    christina May 12, 2018 Link to comment
    what app do I use on a s6 edge to use black background and white txt on email and text messages?
  • Ajay Malik 1
    Ajay Malik Nov 12, 2016 Link to comment
    sir my phone display is IPS display can i have use black wallpaer so my phone battry save or no
    • INFOTECH 1
      INFOTECH Jul 13, 2017 Link to comment
      NO, THAT WHAT THEY EXPLAINED ABOVE, YOU CAN SET ANY WALLPAPER ON LCD DISPLAY, It's ALL WORKS SAME.... SO U CAN START PUTTING BRIGHT AND COLOURFULL WALLPAPERS, IN ANYWAY BATTERY CONSUMPTION, IT WILL BE SAME CONSUMPTION.
  • Todor Tashev 4
    Todor Tashev Mar 15, 2016 Link to comment
    Hello, it's me, I was wondering
    If after all these years you'd like to hear about my painful suffering
    They say that time's supposed to heal, yeah
    But my battery's gettin' even worse.
    Hello, can you hear me?
    I'm in Europe dreaming about a darker theme for my Super AMOLED screen
    When we were younger and TFT
    I've forgotten how it felt when the phone lasted for a week
    There's such a difference between those
    And a million amps
    Hello from the gmail app
    I must've text a thousand times
    To tell you I'm angy, for everything that you've done
    But when I text you never seem to be F’CKIN’ TAKIN’ ITSERIOUSLY!!!
    Hello from the white (web)-site
    At least I can say that I've tried
    To tell you we all need a dark theme on our Samsung phones
    But it don't matter, it clearly doesn't tear you apart anymore
    Hello, how are you?
    It's so typical of me to talk about my phone, I'm sorry
    I hope that you're well
    Did you ever last a whole day on a white screen like in gmail?
    It's no secret
    That the both of us are running out of battery life
    So hello from the gmail app
    Ooh, anymore
    Ooh, anymore
    Ooh, anymore
    Anymore...
    SorinAlbin ForoMichelle LunaBastian SiewersOrion JokaLia Martos
  • Chaytes 1
    Chaytes Mar 13, 2016 Link to comment
    Im using a black wallpaper but never occurred to me that the colour icons would still be an issue. I'll try hide all the unused apps or find a black theme. The email white on black is a great idea too. Only thing I need colour for real is browsing Facebook and tinder ?
    Yoma Ma Dec 21, 2015 Link to comment
    The solution to the black or dark wallpaper is SO simple.
    If you want a pitch-black wallpaper, turn the camera on, turn the flash off, find a soft, black surface like a pillow or black jeans/pants, press the camera lens onto it--not too hard but enough so no light filters in around the edge of the camera, and take a picture.
    If you want a dark wallpaper (90-95% dark is good enough), whether a solid color or mostly dark with very little bright colors or outlines, just take a picture of something that you like that fits the description... or spend who knows how much time perusing through pics on the net.
    Bottom line, you choose what you want for wallpaper; if you are battery power conscious, dark wallpaper with minimal icons on your home screen is for you--mine just has the clock... and less glare is also much easier on the eyes. However, if what you like is a bright, busy home screen, the sky is the limit... literally.
    Don't forget to make a copy of the pic to an SD card and/or your PC, so you can use it on other phones or if you have to reset your current phone.
    Merry Christmas and Happy New Year! ... CHEERS!!
    Sorin
      Deactivated Account Jan 13, 2017 Link to comment
      No, the resolution is just too big even if it's a black image.
      The only good method is get a 2x2 and crop even more out of that with a image editing app and then set it as wallpaper. It saves me about 13% of battery per hour.
      I browse facebook for 1 hour and it drains my battery for about 4-7% only .
      SorinDoug
      Nice, Cristian.
      Sorin
    Mel Fox May 12, 2015 Link to comment
    Best improvement a REMOVABLE battery
    Orion JokaDeactivated AccountPaul Warner
  • Frank Neulichedl 16
    Frank Neulichedl May 12, 2015 Link to comment
    Interesting article - would have thought that by now the wallpaper doesn't help improve battery life anymore.
    JesperLR Apr 9, 2015 Link to comment
    Great article - my worst battery consumer is always the display on time, so anything to reduce that makes a difference! :)
    If anyone wants an app for setting a solid color as wallpaper (e.g. black) I just helped develop a brand new beautiful app for that purpose with Lollipop material colors (it's called "Material Colors Wallpaper HD" and can be found on Google Play)
    jeff Jan 28, 2015 Link to comment
    it would be cool if you guys done a black theme for this app
    Moni MihailovStuart Male
  • 11
    Stuart Male Jan 28, 2015 Link to comment
    Sorry I know this goes against everything here but the s5 has a great looking screen with great graphics. Why would I want to waste that on a black background and dark themed apps? I know it will save battery but if I didn't want to see the great graphics etc I may as well have gotten an s1 or an iphoney. Just my thoughts sorry. Great article though.
    Paul Warner
      Alex Atkin Jan 24, 2016 Link to comment
      Think of it this way, you get more time to use the screen for looking at photos or watching video, rather than wasting the power on having a pretty UI that is completely unimportant.
      I generally have the brightness on my Note 4 down really low. It still looks great (AMOLED screen have excellent contrast ratios regardless of the brightness setting) and it preserves the battery for when I will most appreciate it.
  • GT Ohh 14
    GT Ohh Jan 27, 2015 Link to comment
    And why did Lolly Poop change all the screens from nice battery saving black to a power hungry white theme again?
    Moni Mihailov
      They are probably trying to burn out the AMOLED screen so you have to upgrade your phone more often.
      Tage .T
    durga syn Jan 26, 2015 Link to comment
    yeah, and the worst is that they are the creators/most ardent believers in the amoled technologie.
    i mean it's like they just forgot what they designed works O_o
    Moni Mihailov
  • Lee 16
    Lee Jan 25, 2015 Link to comment
    Yep and Samsung have added the WHITE lollipop background to settings and in other places throughout there phones ? well done Samsung well done ??? Samsung need to read this and take notes ??
    Moni MihailovFrank NeulichedlGT Ohh
    A.F.Kmail Sep 13, 2013 Link to comment
    I have downloaded a 3rd party app which let me stop some applications to start up at boot time .. that saved me a lot of memory and battery life on my note 2 in addition when its night time and have dimmed room , just start an application which decreases the light from phone screen .. which helped a lot
      Amanoop Jac Jan 30, 2015 Link to comment
      I was really searching for such app... Can u name that app pls
  • Kris Carlon 35
    Kris Carlon Sep 10, 2013 Link to comment
    Agreed, the number of times I've had my phone turn on by accident on planes is disturbing (I'm a stickler for aviation safety), now I just take the battery out.
    Sorin
      Jaques Connard Mar 5, 2015 Link to comment
      Mobile phones have no effect on airplanes. This is an airline falsehood.
      Paul Warner
        Eldren Lorence Ongco Feb 13, 2016 Link to comment
        Yes, no effect on planes But it has effects on transmission. Its not falsehood but aviation is already innovating technologies like picocells which will allow passengers to use mobile phone while on board.
  • Northernbaygirl 10
    Northernbaygirl Sep 9, 2013 Link to comment
    The potential for replacing a battery (also being able to flip the battery out if your device freezes) is why I dislike the idea of phones with a non removable battery.
    Deactivated AccountGayle GriffinJaques Connard
  • Kris Carlon 35
    Kris Carlon Sep 9, 2013 Link to comment
    There was an interesting comment in an article we recently did about extending the battery life of the Note 2 - the suggestion was to buy this massive new battery, but one of the commentators noted that the new battery gives 50% more power at double the thickness of the original, so why not just buy another original battery and have 100% more power at the same thickness (and just switch batteries). Good point for battery makers to listen to!
    SorinDeactivated AccountJaques Connard
      Well its darned inconvenient for one, as you lose whatever you were doing to switch the battery out.
      You also risk shorting the spare battery unless you keep it in a carry case, and nobody wants a explosion in their pocket. (although arguably that's a greater risk using a third-party battery too as you do not know if it meets safety standards)
    Northernbaygirl Sep 2, 2013 Link to comment
    A bigger battery is what every smartphone owner wants Kris :) I've just brought a power pack for boosting my phone battery while out and about, In the mean-time I've found a very nice black background with a tigers head depicted in white at one side.
  • Kris Carlon 35
    Kris Carlon Sep 2, 2013 Link to comment
    Unfortunately there is very little owners can do to control the internal light emissions of their devices, that's why this article focuses on what you CAN do (ie. limit how many pixels are actually lit up). While a smartphone-in-mourning look may not be all that exciting, you can get some pretty significant battery improvement by following these tips. But if you care more about shiny wallpaper etc then maybe an LCD display is the right fit. Or a bigger battery of course!
    Sorin
    Nik Technaudio Aug 29, 2013 Link to comment
    Nope, screen filter won't work, as it doesn't actually reduce the light being given out by the pixels, it just, as the name suggests, filters it. Phones have settings deep within /system that controls the min/max brightness of the screen.
    A better alternative, is don't buy Samsung.
      How do you figure that seeing as these improvements are all about AMOLED and its primarily Samsung who use those screens?
      So even with them being silly and switching to a lighter UI, you can still get benefits compared to manufacturers on LCD where you get very little improvement. (although its not zero like this article suggests, displaying white actually saves power on LCD just not to the same extent)
    Northernbaygirl Aug 24, 2013 Link to comment
    Hi Maldives. As far as I am aware screen filter is a good app to help reduce battery drain from your screen being brightly lit. It allows you to reduce the brightness level further than the phones native controls
    maldives Aug 24, 2013 Link to comment
    how about using screeen filter? does it save battery ?
    Northernbaygirl Aug 23, 2013 Link to comment
    I have my screen brightness set to 20% unless my device is connected to a power source (also helps with viewing in bright conditions). It has just occurred to me that I don't know what type of screen my tablet has (ooops! LCD I think though) I must try the thing with the apps as I have all mine set to their light themes.
    Also is it possible to put a picture into one of these posts?
  • Kris Carlon 35
    Kris Carlon Aug 23, 2013 Link to comment
    Hi pamMJschaar, any black is better than none! And red is the next best color to have in terms of energy savings - so your black and red flower plan sounds great. Check out the forum link too - there's some more tips in there.
    SorinFrank Neulichedl
  • PamelaMichel 7
    PamelaMichel Aug 23, 2013 Link to comment
    If I choose a wallpaper that is mostly all black with, say, a partial dark red flower on half the screen, will that still help in saving battery or does the red just cancel out completely?
    Thnx so very much for this article! I just bought a brand new battery, hoping to save more, but didn't work. Guess I need to defiantly change to power saving settings. I hate Auto Brightness, due to the AMOLED being so dark in sunlight. THNX AGAIN!
    Balkrishna AmbatiBill
