Android Marshmallow tips and tricks: over a dozen you should try
Android 6.0 Marshmallow is used by a significant portion of Android smartphone owners. But not everyone knows how to make the most of the operating system. Whether you just upgraded and have a basic understanding of Marshmallow, or you've been using it for months already, we've got tips and tricks in this list that will make you love your phone even more.
Jump to section:
Basic tips and tricks
Uninstall apps from your home screen or app drawer
In Android Marshmallow you can now uninstall an app on your home screen or in your app drawer simply by long-pressing it. At the top of the screen you'll now see options for Remove or Uninstall on the home screen, or App Info and Uninstall in the app drawer. Simply drag the app icon to the one you want.
This is a neat way to save a few seconds over uninstalling apps in older versions of Android.
Grant app permissions individually
Granular app permissions was the holy grail of the Android Marshmallow release. We all hoped it would pan out but no one really believed it would. We had always been told that denying specific app permissions within a third-party app could break it.
Now, however, Android lets you manage app permissions individually, without developers having had to do anything, and everything seems to work swimmingly.
To access app permissions, go to Settings > Apps and tap an individual app to see its permissions. Then simply flip the switch for the permissions you do or don't want to grant it.
You can also view a list of permissions to see which have been granted to which apps. Just go to Settings > Apps, then tap the overflow menu in the top right corner and go to Advanced > App Permissions.
Customize Quick Settings using System UI Tuner
To enable the System UI Tuner, bring down your Quick Settings menu (swipe down from the top of your phone with two fingers) and tap and hold the settings button (cog wheel) for five seconds. When you let go you will be asked if you would like to enable System UI Tuner. Select yes and you'll see System UI Tuner at the bottom of your Settings list.
In System UI Tuner, tap Quick Settings and you'll see a mockup of your Quick Settings shade. You can add tiles (press the + at the bottom), move the toggles around (tap and drag) or delete toggles (tap and drag to the bottom). Your changes will be reflected in the Quick Settings menu.
Disable notification peeking
Heads-up notifications, or 'peeking' as it is now referred to, is the feature that allows notifications to pop up over the top of your display. It was introduced in Android Lollipop, but since app developers now tend to enable peeking by default, Android Marshmallow gives you the power to decide if you want to allow it or not.
If these types of notifications bother you, you can go into Settings > Sound & Notifications > App Notifications, then select the app they're coming from, and switch off Allow peeking.
Activate Google Now from the lock screen
You might have missed this one, but the lock screen shortcut to the dialer has been replaced by Google Now. This is a welcome change; you can use Google Now to call someone just by speaking (along with plenty of other things), so you haven't lost out on functionality by losing the dialer shortcut.
Simply swipe from the bottom left-hand corner of the lock screen to get Google Now ready to receive your voice command.
Enjoy Google Now on Tap
Google Now on Tap is easily my favorite feature in Android Marshmallow. It brings Google Now functionality to every part of your phone or tablet.
There's no need to switch apps or copy and paste phrases anymore – once it's enabled, you can bring up Google Now on Tap from any app, simply by selecting text and long-pressing the Home button.
Check out the Android Marshmallow Easter Egg
The Android Easter Egg is one of the most pointless but fun parts of any new Android version. You simply go to Settings > About Phone and repeatedly tap the Version Number to find it. In Lollipop you'd see a giant lollipop, and if you long-pressed it, you'd be taken to a Flappy Bird clone.
In Marshmallow, tapping the version number, reveals a graphic of the letter M. When you tap it again, you get a marshmallow with android antenna.
Get custom notifications sounds
One of our commenters wanted to know how to get custom notification sounds, apart from what comes on the phone. This is very easy to do with the app Zedge. Set different tones for each app's notifications, or separate ringtones for when certain friends call you.
Intermediate tips and tricks
Activate Developer options
Developer options are nothing new, but there are a few new ones in Android Marshmallow. To access Developer options, go to Settings > About Phone and tap Build Number seven times until a toast pop-up notifies you that you are now a developer.
Back up a step and you'll see Developer options listed right above About Phone. This is where you can enable USB Debugging, OEM unlocking or Show touches, tweak animations or access some of the other tips below.
Get to know RAM Manager
Android Marshmallow is all about giving us even more power over our beloved Androids, and RAM is a huge part of that. Go to Settings > Memory > Memory used by apps, to see a list of all your memory-hogging apps.
Tapping an entry will show you detailed info and give you the option to force stop the app if necessary. Take some time to familiarize yourself with this part of your Android – it's a great tool to help you understand what RAM usage is normal and what's out of the ordinary.
Find your Downloaded, Running, All and Disabled app tabs
The RAM Manager is also effectively the new home for the 'Running' tab that was in previous versions of the Settings > Apps section. Unlike previous Android versions, Android Marshmallow doesn't break your apps list down into tabs for 'Downloaded', 'Running', 'All' and 'Disabled'.
The 'Running' tab now appears as RAM Manager; 'All' and 'Disabled' are now options in a drop-down menu, accessible once you've disabled at least one app. The default view in Settings > Apps is the 'All' apps tab. We'll have to wait and see how devices with SD cards display the information that was previously found in the 'SD Card' tab.
Automatically associate links
Android Marshmallow allows you to automatically associate specific apps with specific types of links. So if someone emails you a Twitter link, for example, you can set Twitter as the default app for opening such links, rather than picking from a list every time.
Although you could set certain apps as default apps before, the system didn't work all that well. Now you can associate specific domain URLs with an app of your choice. For example, all facebook.com links can be set to open either in Facebook, Tinfoil or another third-party Facebook app automatically.
To do this, go to Settings > Apps, then tap the overflow menu at the top right and go to Advanced > App Links, then flip the switch for the apps that you want to set to automatically intercept links from specific domains.
Ignore battery optimizations
Doze is pretty cool: it activates when your phone is left idle for a period of time, while unplugged and with the screen off. It will stop some CPU and network activity operating in the background for some Android apps, thus saving battery.
You might not like it in every scenario though. Doze mode can interrupt the background activity of your apps in order to make these battery savings. So if you don't want this to happen to certain apps, you can disable Doze mode to keep these apps running. Follow the steps below to switch off the battery saving functionality of Doze.
How to disable doze in Android 6.0 Marshmallow
1. Head over to your phone's Settings.
2. Select Battery from the device list and select Battery optimization from the menu icon at the top-right of the screen.
3. Select All apps from the drop-down menu in the center of the display. Now you'll see all the apps that are Doze-enabled.
4. You can now select any apps for which you'd like to disable Doze mode.
5. Select Don't optimize and then Done. Now you're set up.
Now the apps you've selected won't have Doze optimizations, just as you'd prefer. Let us know in the comments section if you see changes to battery life or app activity as a result of Doze, and if you think Doze is a good addition to Marshmallow.
Access the Marshmallow file manager
Did you know Android Marshmallow comes with its own built-in file explorer? Well it does. Go to Settings > Storage & USB > Explore to... er, explore it.
Marshmallow's solution might not be as in-depth and feature packed as something like ES File Explorer, but it's also less intrusive. Check it out for a clean, minimal interface for browsing files.
Navigate better with Bluetooth
GPS isn't a perfect system and it can't always pinpoint your location. On Android Marshmallow, however, you can give your GPS a hand by using Bluetooth.
Go to Settings > Location and tap the hamburger (3 dots) icon. Next tap Scanning and on the following page enable Bluetooth scanning (and Wi-Fi scanning for even greater accuracy).
Once you've done that, tap the return or back button and tap Mode, then select either High-accuracy or Battery saving mode to make use of the new setting.
Advanced tips and tricks
Switch on multi-window mode
This final tip will need you to get your hands dirty with rooting and flashing, but we wanted to include it anyway. Multi-window mode lets you open a separate app in a new 'pop out' window, so you can run two at once.
This feature can already be seen on the Galaxy Note 4 and Note 5, but now you can get it on stock Android.
Prerequisites
- A rooted phone running Android 6.0 Marshmallow
- A root file manager with text editor (like ES File Explorer) or Build Prop Editor
How to enable multi-window mode on Android 6.0 Marshmallow
1. Open Build Prop Editor and scroll down to ro.build.type. Tap it and change the Property Value from user to userdebug.
2. Tap Save and then Yes to reboot your phone (this is necessary to apply the changes).
3. Once you've rebooted, go to Settings > Developer options > Multi-window mode and flip the switch. (If you don't already have Developer options enabled, go to Settings > About phone and tap Build number seven times until you see the notification.)
Using multi-window mode on Android 6.0 Marshmallow
In your multi-tasking view (or recent apps list), you'll now see a square bracket in the upper right of each app card. Tap the target to choose the split-screen view you want: upper half, lower half or full screen. Note that top and bottom switch to left and right in landscape mode.
Once you've chosen your split-screen preference, the app will always appear in that view. So, for example, if you've chosen YouTube in top-half view then tapping YouTube in the multi-tasking list will always bring it up in the top half. If you want to go full screen you'll have to select that by tapping the square bracket in the top right of the app card again.
Multi-window mode on Marshmallow works surprisingly well for a feature that was left out. It's a bit clunky and occasionally you get weird overlaps, like as shown the upper left of the image above, but generally speaking, it works fine.
Unfortunately, you can't re-size the split-screen windows, but that's what you get from an unfinished developer feature. It's not perfect, but it is there and it is working – and that's half the battle.
Bonus: how to get Android Marshmallow features without Marshmallow
If you haven't received a Marshmallowy gift from your manufacturer or carrier, either because they're slow or your phone's too old, do not despair: you can get some Android Marshmallow features on your phone anyway.
1. Manage app permissions
Have you been happily clicking OK to every app’s permissions list and now worry they’re sending your personal information to God knows where? Android Marshmallow enables you to allow or deny permission retrospectively, so you’re not stuck with the decisions you make when you first download the app. It’s very useful but it isn’t part of Android Lollipop. If you have a rooted device, however, the excellent XPrivacy can bring the same features to your mobile or tablet today.
2. Chrome Custom Tabs
Until Android 6.0 Marshmallow, clicking on a link within an application – such as a link you’ve been sent on WhatsApp or in an email – will automatically open the link in your default browser. And that’s fine, but a full browser has a hefty overhead that you don’t always want when you’re just investigating what the link is.
Chrome Custom Tabs in Marshmallow will address that by loading a stripped-back subset of Chrome that uses fewer system resources than the full Chrome browser. You can’t add it to Lollipop, but installing the ultra-light Link Bubble browser and making it the default will do much the same – no rooting required. What Link Bubble does is display a link in a little bubble, loading it in the background while you get on with what you’re doing.
3. Smart Link
Sticking with the subject of navigation, Smart Link is one of those little features in Marshmallow that you’ll soon wonder how you managed without. Instead of opening every kind of link in the web browser, Smart Link opens them in the appropriate app – so, for example, a link to a tweet opens in your Twitter app without opening the browser or asking you what app you want to use. On older versions of Android, you can get much the same functionality by installing the excellent TapPath.
4. Support for fingerprint readers for payments
In Android Marshmallow, the fingerprint sensor is supported throughout the OS, not just for unlocking your phone but for authorizing things such as payments. You can get similar functionality in recent Samsung devices thanks to PayPal and FIDO: go to Settings > Fingerprints > Pay with PayPal to enable the feature.
If you don’t have a fingerprint reader don’t worry: you can use ICE Unlock to turn your camera into a scanner, although it’ll only unlock your phone. That’s because while it works perfectly well as a phone unlocker, the camera can’t process the same level of detail as a dedicated fingerprint scanner, so the security isn’t strong enough to be trusted with your debit or credit card details. Still, it’s enough to keep your pals out without having to bother with long passcodes.
5. Memory management
The Task Manager in Android Marshmallow has been significantly improved over previous versions and enables you to see what’s using the most or least RAM on your device. And it’s easy to get that on older Androids too: since Android first appeared, the Play Store has been packed with Task Manager alternatives including rogue app killers and app managers that can analyze what’s doing what on your device. Here are some candidates:
6. Reorder the app drawer
The app drawer, the bit of Android that shows all the apps you’ve got on your device, has been changed for Android Marshmallow to make it more organized. The first four icons are your most-used apps, and after that the apps are organised alphabetically. In this case Google’s actually playing catch up with the Play Store, where you’ll find stacks of very good and very customizable app launchers. You’ll find some of our favorites here:
7. Doze and battery improvements
Battery life remains the Achilles heel of most devices, and in Android 6.0, Google has introduced a raft of energy-saving improvements including Doze and the ability to charge really quickly via USB-C. Sadly you can’t retrofit a USB-C port to your device but you can employ a variety of tricks to improve battery life and charging. We’ve included the best ones here:
8. Clever SD card support
Android Marshmallow can treat SD cards as if they were internal storage, without the limitations that applied to external storage. That means goodbye to storage limits for app installations or data associated with heavy duty apps. If you’ve rooted your device, Link2SD does much the same.
9. The Marshmallow boot animation
Customizing your boot animation will require root access and a ROM-based AOSP such as CyanogenMod or ParanoidAndroid. Once that's set up, here's what you need to do.
- Download the APK provided by XDA Forum here.
- Copy the file using Root Explorer or any similar application.
- Go to System and select the Media folder.
- Change the name of the 'bootanimation.zip' file (hosted in Media) to 'bootanimation.bak'.
- Paste the new file in to 'bootanimation.zip'.
- Access the permissions of the new file and make sure that the options for read and write are set to owner, group and others. The option to run (execute) doesn't need be checked.
The process is totally reversible. If you want to go back to the original animation, just change the file names back (i.e from 'bootanimation.bak' to 'bootanimation.zip').
Found any other hot Android 6.0 Marshmallow tips and tricks you can share? What's your favorite? Let us know in the comments.
I am foggy on exactly how to uninstall preinstalled Google apps
Reboot to Safe Mode, to have the least possible running and Disable from Apps. It's the best we can do, unfortunately.
My tv box Entmate 6 has android 6.0.1. But it is not multitasking. I tried too much but the problem not solved. Please tell me some app which will change all the settings. Thanks
Sayyed hasan
Delhi, India
9891540616
sayyedhasan167@gmail.com
How can I disable the voicemail notification, I have it without having any messages. I can only find tips for previous Android versions and my service provider says they can't disable it in the system, any tips for me?
Settings, Call settings, Calls, Voicemail, Setup, Voicemail number. It's the best I can think of. :)
After Android upgrade to 6.0, K3 Note Phone (Lenovo K50a40) under the Scheduled power OFF/ON, the phone gets power OFF at scheduled time but does not power ON at the scheduled time.
Any solution ?
How can I enable multiwindow feature in my Lenovo A7010a48 k4 note explain it detail. Thank you
Tienes Que TENER SuperSU Y ANDROID 6
Y SIGE LOS PASOS 15. Activar el Modo multi-ventana
You can see the full instructions here: https://www.androidpit.com/android-m-tips-and-tricks#multi-window
que codigos usan los botones virtuales en build.prop
kiero pone el cuarto boton que oculta la barra de botones virtuales
Since downloading marshmallow update I cannot get into messages, cannot open or send or receive any messages. BLU vivo xl
Check out this article for help on how to fix Android Marshmallow-related issues: https://www.androidpit.com/android-marshmallow-problems-and-how-to-fix-them
Btw., for something as crazy as that: Factory data reset
Here's a thought. Tell me what the heck it is before you begin describing why it is so wonderful. I have never heard of Android marshmallow. Couldn't there be a small sentence that says Android marshmallow, what the heck it is, will do blah blah blah?
Hi Diane,
We have an article that explains the Android Marshmallow software update here: https://www.androidpit.com/android-m-release-date-news-features-name
Please let us know if you have any questions, and thank you for your comment.
Refer Trick #15....... The problem is that when multi-window is enabled, the black square bracket appears superimposed above the lock icon on app cards in the task manager. So I inadvertently end up locking the app instead of getting it in another window. How to disable the lock icon ? Can someone please help ?
Is there is any way to remove guest user (disable it) and keep restricted account ? i think this problem with Android Marshmallow ?!!!
Definitely, no way to remove or disable Guest.
Whenever i go to recent apps to use multi window it shows a lock icon over the square and after pressing the multi window mode it just lock the recent tab. But it dont go to multi window mode. Any help.
how to change call receiving style change in marshmallow?
I'm facing a problem in Intex Cloud Fame Marshmallow. It doesn't connect with WiFi. When I click on WiFi, it searches all available WiFi connection. After putting password it shows 'Saved'. Again when trying to connect, it comes on 'Off' position. Can anyone help?
I just recd the Marshmallow update on my Lenovo K4 Note. But my app tray still scrolls in the same old way. How do i switch it to the new vertical scroll..? And why is it the same anyway..??
In your homescreen go to preference -> drawer settings. It's pretty cool because we can choose between vertical or paged style, we can also change the background of the drawer.
How do I set a custom notification tone for my messaging? There no longer appears to be a way to add a sound, only the standard list is available. This makes me sadder than it should. #firstworldproblems
Also, thanks for the excellent article. Bookmarking as I navigate this marshmallow world...
Hi Lauren,
We've added a tip to the article which should help you.
Thanks for the comment!
you've completely missed off if you press and hold the marshmallow it takes you to a game?!
Lenovo Vibe C2 PA45 (K10a40) won't even show me the Easter Egg, so no clue! xD
I got the marshmallow update on my LG tablet now my game apps keep closing out for no reason. I moved the app to the SD card and it still closes out I clear the data and forced stop but the app still keeps closing out. Anybody have any ideas?
Lollipop was lot better than this one in usage!!! Now my call recorder is not working.My wifi Hotspot too not working..!! It's really an headache..Need help!!!
You need to factory reset the phone..... take the backup first...... I have face same problem with my Lenovo Note 3...... after update with Android-6.0 ...... phone become toooooo slow... even hangs in call .... and I couldn't take the call .......... but after factory reset ...... amazingly .... only all apps and data gone... now OS is still Android 6.0 and I downloaded all the apps again (it's better coz they are new with new version)...... and now my same phone become a rocket speedy.....
I'm using Note 5. Things I notice after the update.
1- Before update my software I can use my flashlight together with camera, but after update if I turn on the camera, it will automatically switch off my flashlight.
(I need flashlight for my camera... it give a better picture)
2-my message no longer got bubble option (background still available.. hey but I love the bubbles ok)
3-developer option no longer in setting
Please advise.
I will definitely be referring to this article as I navigate my way around Marshmallow iOS 6.0 -- plenty of changes to adjust to, wonder if OS N will continue the same style of menu buttons ( triangle circle square )
I've noticed that once I've moved an app to my sd card if I do an update of that app it moves it back to internal storage and acts as if its been newly installed. Frustrated with this as apps keep updating all the time and I'm continually moving them back to my sd card (I'm on an LG G4) any HELP?
Frustrated! Ever since the 6.0 marshmallow update I can not use my visual voice mail or voicemail all I get is alot of numbers letters and symbols they have been trying to fix it for about 2 weeks now . Also ever since the update my flash light won't work HELP
Customize Quick Settings using System UI Tuner - is it available in Note 5?
My device still runs on lollipop and I have a cyanogen os Phone and I'm very happy about it !!
i'm using the nexus 6p. ya think that the marshmallow 6.0.1 is better or android n preview 3 is better when it releses? i've used the preview 2, the experience was great, except for the stuttering... but i don't think i can get out of the fantastic android n lol:)
Why do you keep pushing AOSP type roms? There are plenty of TouchWiz roms that are better than those. I have a custom boot animation and boot sound on my Samsung S6 edge running CarHDRom v22.
In Messaging, after upgrade I can no longer send pictures, just text, why?
On the new update why will the notification sound not stop!!! I want one notification not a constant effing drone? There is nothing in the settings which let's the notifications repeat?? Or not!
Which Phone do you have?
I have tried on my Note 5. The Path is Setting-Accessibility-Notification reminder. Keep it OFF.
Check may it helps you.
I need an update now!!
which device you have ?
After update my phone is extremwly slow, reboots CONSTANTLY without warning. Resets timers I set & after every reboot ( which is 6 to 12 times a day) it starts telling me to transfer my media to my sd card (which it is all already in!!!!) Or that it does not recognize that I have sd card in. Oh did I mention I have had to uninstall & reinstall apps I have never had any issues with before apps that I pay money to be able to use & cant! This update is JUNK! I am highly dissatisfied. I take care of every device I have ever owned and somehow it self mutilates itself with its crappy programming and updates with nothing but bugs.
Since the new update, my Note 5 text bubble option in settings is gone. I can still change the background but have no option to change the look of the bubbles. Any thoughts android lovers?
After Update Marshmallow i am not satisfied bcz i can't able to install my normal games at all hope soon new bug fix update release.
Help, after upgrading editing photos is completely different. How do I edit photos so they show up immediately in my gallery?
Hi, i like community issue resolve way so now today i am facing in my Lenovo A70000 Marshmallow i can't able to enable Customize Quick Settings using System UI Tuner, so can anyone tell me the problem?
Since installing Mushmallow, I have had one Particularly Annoying bug repeatedly show its ugly face.
Whenever I am streaming an I Heart Radio program via Bluetooth to my OTAdapt Bluetooth receiver, my phone will periodically reboot/restart itself for no particular reason & without any initiating input from me. VERY Annoying, as it usually happens just when the person to whom I am listening is about to reveal something of particular relevance to the topic of discussion. And while the phone will complete the restart cycle within a minute or so and resume the program, the subsequent notification states the process completed in 10 mins & xx secs, just as it does/did after installing the update (sorry, I Refuse to call it an UpGrade).
Any suggestions?
Hey is there anyway to stop the apps from setting to default. I actually find it handy to be able to select which app I use everytime since I use different apps @ different times.
Thanks in advance.
Why is there no longer a microphone icon on the keyboard? I am not able talk to text/email without it unless I am missing something.
I am also looking for an answer..
check to see if you are using swype . Your keyboard is probably set to standard
press and hold the button next to the sym key..it will give you the choice for microphone
I've got an Android tip you can try...throw it in the trash and go buy an IPhone...#garbage.
Replace the middle "e" in your first name with an "n", and you get your real name...
Never !!
Hey.. Sorry if you already know this but I found a way to remove Google Now from Lock Screen and put the Phone caller app back to the Lock screen!
Setting>Apps>Click the 'Settings icon' next to the Options button>Default Apps>Assist & Voice input>Assist App>Select 'None'!
That's it.. You're good to go!
Thanks Guys..
Thanks AndroidPIT! ?✋
Upgraded my Lenovo k3 note to marshmello, now everytime I select something from the gallery to forward it gives me auto suggest of ppl I chat with the most I whatsapp. How do I stop that
I was looking at #5. Get to know RAM Manager and I don't see Manager in the settings. Trying to figure out how to delete RAM on my phone instead of getting a task killer app
So far i dont like the update. Why did the clock fon change? Before it had a shadow behind it that made it easier to see against the a photo background. Also what happen to the swife affect when unlocking the screen? It seems to have taken my s6 backwards.
If you do number 12 from this page. After the marshmallow appears wait a few seconds and move your finger around on it and it opens a little mini game where you're a little android man working your way through marshmallows.
To add, if you press up by the "0" you can add more little men.
Hi dudes I have upgraded my lenovo k3 note to Android 6.0 marshmallow but I can't disabling some of Google apps it's taking lots of RAM is there any solution for disabling in built google apps ???
Hi
Last week I have updated my phone Samsung s6 to marshmallow but which is completely slowdown my mobile ... now it's getting completely slow even i can't open contacts and call history so pls resolve the issue or else suggest me to degradation the updated version
Hi,
When the phone Lenovo K3 note came on after a Marsh mellows software upgrade , there was a pop asking whether I wanted to internalize the SD card. I clicked the no option as it said the SD card won't work on other devices as it will be formatted to integrate it into the phone. I wish to go with integrating the SD into phone. If it is possible please guide me how to do it. And also do tell me if the formatting in this case will wipe out existing content on SD.
Anyone else lose Miracast after the update to 6.0? It is now gone and I can't find anywhere in the settings. I'm on an LG G Stylo.
I thought it updated, but when it reset it came up with a "cannot be updated at the time, try again later" comment. Why won't it update?
U should have high speed WiFi internet
Go to settings about phone then tap the android version till the m comes up. tap until marshmellow comes up tap a couple more times then hold down and the game will start. I have the note 5 Game is Floppy Marshmallow. but don't take my word on the name.
How do I move apps from the internal storage to SD card??? It's really frustrating when there's a pop up of storage being full..plz help
I would like to do it too, buth I also dont now haw...
My audio went out on my Nexus 5 recently. I checked all my apps in Safe mode that didn't solve it. I factory reset it and that didn't solve it either.
I don't understand number 14: how does bluetooth helps the GPS? Why would I have a better localization with bluetooth on?
Everyone who is having problems with the update should try a factory reset. This tends to clear the system and forces you to re download apps to the latest (optimum) version.
If your still having problems I'd try uninstall your apps and see then factory reset (or boot into safe mode) and see if this helps. You can then try adding apps gradually if the problem returns you know which app is responsible.
Peace ✌
Fantastic work-from-home opportunity for anyone... Start working for three to eight hr a day and get from $3000-$5000 each month... Hy Regular weekly payments... You Try Must.........
------------> Alpha-Careers.COM
I was aware of a few tricks,but the System UI... Does it work on ALL phones? My LG G3 would not bring it up..
i had no problems on my g3
Can you uninstall 6.0 update on HTC m9...hate hate hate it
No once an update to the system has been updated you can go back, unless you want to get into rooting, but I don't think you want to get into that. Just give it some time, and you might like it, or if you are having issues then you might just need to factory rest * make sure all your stuff is backed up though!*
I updated my phone today and all the info attached to my music has vanished. It still has the song titles but now nothing has an artist name or album name.
I was unfortunate enough to update to crappy marshmallow since doing it half my apps no longer work. I keep getting message saying turn on permissons. When I try I get another poxy message saying there's another App blocking my actions. Help I want my phone back I HATE CRAP UPDATES THAT BUGGER YOUR PHONE UP.
Go to settings, on promisions ; ypu'll find a promisions for uploade apps which are not on google play. click and allow updating for these apps to.
Since i updated my HTC One M8 - I am having following issue
1 . Pull down Menu is not working
2. Unable to close the Recent Apps - X button to close all the opened APPS as the top region on the HTC One M8 is not recognizing the touch
3. Uninstall apps from your home screen or app drawer - This is not working on HTC One M8
4. Find your Downloaded, Running, All and Disabled app tabs - This is not working on HTC One M8
5. Auto Rotate Screen works only when we open any APP. this wasnt the case earlier.
I am now struggle a lot on the Issue 1&2 - Pls advise if this is related to Device issue (or) Software update as i have the problem since update;
Have you tried to factory reset your device? Usually this will fix any little bugs after a update. It's recommended that you factory reset after the update has installed.
Peace ✌
I am using Moto G3 and was having 5.1 lollipop. At that time i could watch a movie of 2.5 hr using headphone and the battery drained only 30%. Today i upgraded to 6.0 marshmallow and now the battery is draining by 20% on keeping the phone idle for 1 hr. I have not used my phone for this time not even a call or any app. What an optimization is this? I dont know what to do.
Bhai settings me jake battery status check kariye waha par dikhai dega ki kis app ne apki battery ko tabiyat se piya hai. Bas us app ko band kar dijijiye. Possibly Android core app jyada battery use karti hai
Hello Kris! Thanks for the article. Android marshmallow 6.0 popped up on my phone, downloaded already. And it wasn't on wireless but used my cellular data. Now my questions please: how do I prevent it from upgrading next time? Some of my pictures are missing and other files like app, even in the file manager. Your help is greatly needed. Thanks.
here are some videos from tricks as welll youtu.be/9qunHEVgaRQ
There is a Marshmallow Flappy Bird game as well
Thought battery life was supposed to be better. It's worse. Have to charge 3 times a day now instead of once. I have made no other changes or use differently since installed this Marshmallow. Battery life is important to me so I despise this "upgrade"
Yes I even did factory data reset. Have not seen any better battery life? Don't understand why?
I guess there is no way to uninstall this is there?
Yes u can go back to whatever Android you prefer. Just go to Google factory images. It's the Shamu build. And you can see the 4.4 or 5.0 or 5.1 or 6.0. Then u have to flash the image to your Nexus 6 which takes work but its not hard. Check videos on how to on YouTube.
Try to use Doze, take a look on Android Pit; there you'll find tackle tips to improve battery life.
Please go to the quick setting menu then press and hold the setting icon for few seconds then lift the touch then you will get the system UI icon in the main setting menu.
There is no system UI switch in developers options?
Can't find #4 ?
Do not see any System UI in developers options? Where do you turn it on ? Can't find it?
Update pull down notifications, then tap and hold the gear icon until it says Sytem UI enabled.
I hold it down but it doesn't do anything. And if I let go after 5 sec it sends me to the settings app
"Android Marshmallow gives you complete control over which apps handle certain domains."
You can only turn on and off, you can't modify the domain list. So not actually complete control.
thnx
my friend's step-aunt makes $70 an hour on the computer . She has been without a job for 5 months but last month her pay was $18819 just working on the computer for a few hours. look at here
➨➨➨➨➨➨ www.buzznews99.com
The new nexus phones aren't out yet and I'm checking daily to update my n6 to marshmallow...
Yet you're saying top things of it????
How about actually waiting until you've got a phone with the official release before claiming things.
All I'm hoping for is a more stable release
It seems Android Marshmallows has many good features and functions. But what users are more interested to know if their smartphone is included the units that can be upgraded to this newest Android OS.
Did you bother to check that features are all there before posting? Dark theme is not an option in the official release, good job on copying and pasting what you found elsewhere!!
Did you just reprint this article from one of the Marshmallow previews? There is no dark theme in the final release and the RAM manager is under Memory in the Settings menu.
Dark theme is gone for right now, but maybe not for good:
It was based on the original article for the M previews. Most things stayed, but yeah thanks for the Memory settings tip too!!
Just got the official OTA on my N5. But I had a bit of a doubt. Do I actually get to choose the app links? Or does Android do its own thing? Because I don't see flip switches on that pane. Anyone?
Can't find that switch to change the theme in developer options...
I'm stell on lolipop. Here you go to settings, find a people with sabiloties and you'll fin a opcion for dark teme
Its not available
Hi there.. I think there was a unfinished flappy bird clone on Android L preview.. just enter those squares and do (now I dont remenber very well) tap; tap; long tap.. and you will be presented with the easter egg.. you maybe need to do it more than once before it happens.. If this doesn't work please try different combinations..
I'm confused about the ram issue. I've read in many other articles that Android does a fine job managing ram on its own and that we actually do more harm than good when we "Mess" with it..?? Please clarify. Thanks.
Yeah, my PERSONAL view on this is that you don't NEED to mess with it or change anything there, but it CAN be used as an indicator of malfunctioning / poorly performing apps
I've got an LG Nexus 5. Will the new android M give me mirror link? Loads of other phones have it.
Thanks.
When my device OppoR8006 to update?
when android one get this update.
When would LG G3 get this update?
What version of the G3 do you have? I live in the USA. I have a international version (D855) from Singapore and I haven't received the Marshmallow update. I don't get it, because even carrier branded phones have received the update. I wonder what's going on?
Does YU yureka will get this update soon
