OnePlus 3 review: going mainstream
AndroidPIT OnePlus3 soft gold 6531
OnePlus has come a long way since the OnePlus One was released a little more than two years ago. Watching the trajectory of this Chinese startup is like seeing a child celebrity grow up, shaking off the demands of fame and maturing. But it’s not what the OnePlus 3 has that makes it interesting, but what it doesn’t have. With the release of its third flagship, OnePlus has dropped the invite system and gone from guerilla marketing tactics to a sprint for mainstream success. In this OnePlus 3 review, we’ll see how OnePlus has grown up and begun to settle down.
OnePlus 3
  • High performance
  • Premium design
  • Hard-to-beat value
  • Dash Charge is fast
  • Smaller battery than OnePlus 2
  • Underwhelming display
  • No microSD support
OnePlus 3
OnePlus 3
OnePlus 3: All deals
OnePlus 3 release date and price
The OnePlus 3 was launched today (June 14, 2016) via the global ‘Loop VR’ event publicized a couple of weeks ago. It will be sold in the US for $399 and Canada for $519. In the UK it’ll cost £309, while in Europe it will set you back €399. It goes on sale tomorrow, June 15, in India for ₹27,999 and also in China for 2499 RMB. We’ll update this section as more availability details are released.
As mentioned, the big news is that the OnePlus 3 will be available invite-free from launch day. This is the first time OnePlus will sell a phone the ‘regular’ way. This is great news if you’ve been frustrated with the system before.
UPDATE: The OnePlus 3 is one of the best smartphones of 2016, but OnePlus has already decided to raise the bar even higher with the new OnePlus 3T, available from November 22. Check out our review of OnePlus’ latest and greatest to find out if it really beats its predecessor, and what the big changes are.
OnePlus 3 design and build quality
While the OnePlus One was a large, sandstone-textured performance beast, the OnePlus 2 had a more refined design. The OnePlus 3 doesn't leap a great distance from its predecessor, but is another instance of where OnePlus has applied small changes to its formula.
In my opinion, the OnePlus 3 is the best-looking piece of hardware OnePlus has made. At 158g, it’s lighter than either the One or the 2, which are 162g and 175g, respectively. From the back, the anodized aluminum unibody, at 7.35mm in thickness, has an attractive minimal design. It's sparse. The call speaker sits above the display, along with the front-facing camera to its left. To the left of the camera is the notification light.
AndroidPIT oneplus 3 6662
This is the OnePlus 3. / © NextPit
Beneath the display is a fingerprint sensor, which also doubles as the home button. As with every front-facing sensor like this, you’ll need to take hold of the device with two hands to give your thumb an accurate aim. The sensor is fast when you get it right (and you mostly will), unlocking in up to 0.3 seconds, according to OnePlus. The sensor also has bling quality with its glossy ceramic construction.
The OnePlus 3 is the best-looking piece of hardware OnePlus has made
On the left side of the OnePlus 3 is the volume rocker, which sits beneath the notification slider, and on the right side is the sleep/wake button and dual-SIM card tray. All three of these buttons have a pleasingly tactile click. There isn’t much to see on the rear. Beautifully minimal, there is the protruding main camera sensor, flashlight, company logo and the antennas above and below. The combination of hard and soft lines, subtle color variation and even how the anodized aluminum disperses light, give the OnePlus 3 a fine finish.
AndroidPIT oneplus 3 8012
A cleaner, more minimal design. / © NextPit
Then there's the size. With a 5.5-inch display, and as with every other phablet, this phone is a little too large to comfortably fit in trouser pockets. Its thinness helps pocketability, but if the issue of practicality is a major one for you, or if you've never owned a phablet before, then you mightn’t get along with the OnePlus 3.
I can’t help but draw a comparison with the HTC 10, as the back of both phones are very similar in appearance. The main difference is that the HTC 10 has chamfered edges, while the OnePlus 3 has rounded ones (see below for a visual comparison). The OnePlus 3 was available in graphite at launch, with 'soft gold’ made available in the US on July 26, 2016. Here are some shots we took at our headquarters on August 9:
AndroidPIT OnePlus3 soft gold 6551
The soft gold variant of the OnePlus 3. / © NextPit
AndroidPIT OnePlus3 soft gold vs gray silver 6643
Soft gold (left) and graphite. / © NextPit
AndroidPIT OnePlus3 soft gold 6557
The front of the soft gold version is white. / © NextPit
AndroidPIT oneplus 3 vs HTC 10 7900
The OnePlus 3 beside the HTC 10. Similar, no? / © NextPit
OnePlus 3 display
The OnePlus 3 display is a 5.5-inch, Full-HD AMOLED panel with dimensions of 1920 x 1080p, giving it a pixel density of 401 ppi (the same pixel density as the previous two generations). The 2.5D screen is made of Gorilla Glass 4, which is reportedly more resistant to shattering than previous iterations but, with that smooth aluminum unibody, I’d still lean towards using a case.
Overall, the display is pleasing to use, with oversaturated colors and deep blacks typical of AMOLED panels. Tolerances are also tight. The panel sits very close to the glass and the bezels, at 0.75 mm each, are also small.
AndroidPIT oneplus 3 6669
The OnePlus 3 display is good, but only good. / © NextPit
We weren’t so impressed with the OnePlus 2’s display, and not much has changed this time around. The panel is adequate, but, in 2016, it’s a little underwhelming. You’ll be satisfied during daily use, but it can’t compete with the richness of the QHD displays you’ll get in a Samsung Galaxy device, or even in a Moto X Pure (now the Moto Z).
While maintaining this resolution has performance benefits, it could be a drawback if you’re interested in pairing it with a VR headset, particularly as OnePlus has now teamed with Ant VR to release the Loop VR headset, which was also sent to me for testing.
OnePlus 3 special features
While in our OnePlus 2 review we discussed the introduction of a fingerprint scanner and the surprise dropping of NFC, you’ll be pleased to know that both of these features are in the OnePlus 3. Aside from OnePlus marketing this device as VR friendly, with a global virtual reality launch adding a level of interactivity to the release, the most interesting new feature this time around is Dash Charge.
AndroidPIT oneplus 3 7934
Dash Charge is a good addition to the OnePlus 3. / © NextPit
This is OnePlus’s first foray into quick charging. Dash can charge the battery to 60 percent in around 30 minutes. It does this by moving the bulk of the phone’s power management to the adapter, meaning that most of the heat generation that charging causes is kept away from the phone itself, just like other quick charging setups.
Dash Charge provides you with two main benefits. The first is that you can charge the OnePlus quickly and, in my testing, it took a little more than one hour to reach 100 percent. The second, OnePlus claims, is that performance isn’t throttled as much as with other fast charging systems. This could be handy if you want to continue gaming while the phone charges but, otherwise, is nice to have but mightn’t be of much benefit to you.
AndroidPIT oneplus 3 7925
The OnePlus 3 has a USB Type-C port for charging. / © NextPit
But also note that, although Dash Charge is a useful new feature, you'll be stuck carrying around the wall adapter that comes with the OnePlus 3. If you try and use another quick charge adapter, it won't work. Something to bear in mind if you use accessories that might conflict with this.
OnePlus 3 software
I’ve previously had some issues with OnePlus's Oxygen OS user interface, namely small bugs and choppy animations, when compared to stock Android. Oxygen has matured since last year and now I’d call it a worthy alternative. The OnePlus 3 comes loaded with Oxygen OS 3.1.1, which this review was based on, and was updated to Oxygen OS 3.1.2 a day before launch. If you haven’t tried it yet, this is a skinned version of Android 6.0.1 Marshmallow.
Update  July 20, 2016: Several OnePlus 3 updates have been released since launch day. The first, Oxygen OS 3.1.4, came after some minor controversy when it was discovered that the OnePlus 3 was throttling RAM at 4 GB to prevent battery drain. That update included an sRGB color mode, optimized RAM management and faster game loading speeds. An update to Oxygen OS 3.2.0 came out in the first week of July and provided minor tweaks to GPS performance, audio playback and custom icon packs.
Oxygen OS 3.2.1, which was released within the past week or so, was actually a replacement update after OnePlus decided to stop rolling out version 3.2.0. It includes the tweaks of its short-lived predecessor, plus some camera quality and photo gallery improvements, among others. Some reported that it caused severe battery drain, but we haven't noticed this issue, as you can see from a quick snapshot in the images below. Continue reading our software review below.
oneplus 3 update battery
Battery usage has been normal for us on Oxygen OS 3.2.1. / © NextPit
Regarding general software features, the OnePlus 3 has the usual customizations that you’d be used to, such as dark mode, along with ‘Shelf’, which you’ll find when swiping right from the home screen. This is OnePlus’s alternative to Google Now on Nexus devices, or Samsung’s inclusion of Flipboard into TouchWiz. You can use it to host a collection of apps, shortcuts and widgets. It’s more or less the same as in previous versions of Oxygen.
AndroidPIT oneplus 3 7923 2
Oxygen OS 3.1.1 is based on Marshmallow. / © NextPit
Features in Oxygen OS 3.1.1 include night mode, support for custom icon packs and the Marshmallow-derived Doze Mode and app permissions. There isn’t much bloatware to speak of, thankfully, although you’ll find the usual suspects already preinstalled – namely SwiftKey and Google apps like Maps and Chrome.
The software experience with Oxygen is smoother and steadier
Overall, the software experience with Oxygen is smoother and steadier than it was last year. Although OnePlus phones have traditionally been popular with the geek set, the OnePlus 3 could be an alternative to the Galaxy S7 Edge, or an iPhone 6s. Its reliability and palpable design give it mainstream potential. But if you’re not satisfied with Oxygen, worry not. Its bootloader is unlocked from the factory, so you can flash ROMs if you’d prefer.
AndroidPIT oneplus 3 8014
Oxygen OS runs better than ever on the OnePlus 3. / © NextPit
OnePlus 3 performance
Now the lion awakens. Hardware performance is where the OnePlus 3 overperforms. If you expect nothing more from this phone than raw power, whether for intensive gaming or simply to know you have it, then now is a good time to sit up in your seat. Here it is: the OnePlus 3 is one of the most powerful phones we’ve ever tested at AndroidPIT.
oneplus 3 benchmark antutu
The OnePlus 3 came out on top. / © NextPit
It has a quad-core Snapdragon 820, with two cores clocked at 2.2 GHz and the other two at 1.6 GHz. This is combined with an Adreno 530 GPU, 6 GB of LPDDR4 RAM and 64 GB of internal storage. The Snapdragon 820 performs very well in the OnePlus 3, without the throttling burdens that the OnePlus 2 experienced with its easily overheated Snapdragon 810.
The OnePlus 3 is one of the most powerful phones we’ve ever tested
oneplus 3 basemark x
The Basemark X benchmark on medium quality. / © NextPit
I ran a series of benchmarks over several days to test OnePlus 3 processor, graphics and battery performance. They included Vellamo Metal and Multicore, AnTuTu Benchmark, AnTuTu Tester (battery), Geekbench 3 and Basemark X, both in medium and high modes. I ran the tests three times and then calculated an average. What was the final result? The OnePlus 3 performed better than the incumbent number one – the Exynos 8890 variant of the Galaxy S7.
oneplus 3 benchmark vellamo metal
The Vellamo Metal benchmark score. / © NextPit
Interestingly, and to be taken with a pinch of salt, the best AnTuTu Benchmark score was 140,573 points. Compare this, also with some skepticism, to the ANTuTu benchmark we ran on the OnePlus 2 last year: around 62,000. This puts the OnePlus 3, at least for now, at the top of the smartphone pile for raw performance. But what does this actually mean?
oneplus 3 benchmark geekbench
Both single- and multi-core results on Geekbench 3. / © NextPit
In everyday life, very little. You won’t be accessing the full processing and graphical capabilities as you view cat pictures in Chrome, or make grey ticks blue in WhatsApp. But if you use power-intensive apps, most probably games, then you can be confident that the OnePlus 3 will run these at high frame rates for at least the next couple of years.
I think that for many potential customers of this phone, owning this power at a significantly lower price than the current stable of flagships is reason enough to buy it. Leaving a Ferrari in the garage doesn’t hurt anyone, after all.
OnePlus 3 audio
In its speaker grille design, the OnePlus 3 departs slightly from the OnePlus 2. It has only one bottom-facing grille, which makes sense for its mono-speaker setup. The OnePlus 2 had a second grille to maintain design symmetry rather than channel actual sound, which makes little sense.
Switching to one grille has another benefit, namely that the 3.5 mm headphone jack and one of the microphones have been relocated from the top of the phone to where one of the grilles used to be. This gives the phone a cleaner and more functional design.
Sound quality from the bottom-facing speaker is good, with rich mid-range tones and crisp treble. Don’t go throwing out your Bluetooth speakers just yet, but this is a decent driver that’ll get the job done. Audio call quality is also satisfactory, with the call speaker producing warm tones even at higher volumes, working in tandem with noise-cancelling dual microphones.
AndroidPIT oneplus 3 6672
Speaker grille design is cleaner than in previous generations.  / © NextPit
OnePlus 3 camera
I found the OnePlus 3 camera to be one of the weaker components in the overall package. On the rear is a 16 MP Sony IMX 298 sensor with an aperture of f/2.0. It features both optical and electronic image stabilization, along with phase-detection autofocus, RAW image support and 4K video capabilities.
The manual controls, such as for aperture and ISO, might suit your needs if you’re a more serious photographer. I’d even recommend increasing the shutter speed if you’re shooting moving objects, as indoor subjects often blurred when I was using automatic mode. Image quality is good overall, but low-light performance wasn’t as good as I’d hoped. Quite a lot of noise appeared on my subjects’ skin.
AndroidPIT oneplus 3 8030
Manual mode in action. / © NextPit
Sony’s IMX 298 can shoot at very wide-angles. I found this useful indoors, but it led to image distortion when I tried capturing too much information in the frame. Getting consistently sharp details was also tricky, and optical image stabilization was part of the problem.
Getting consistently sharp details was tricky...optical image stabilization was part of the problem
If you're not used to it, or if you shoot quickly like I do, be aware that a stabilized lens might need a short moment to steady itself after your hands stop moving. Not a problem specific to the OnePlus 3, but there can be slight warping if you press the shutter release too quickly.
AndroidPIT oneplus 3 7993
This is certainly a good camera, but there is better. / © NextPit
The front-facing camera uses an 8 MP Sony IMX179 sensor with an aperture of f/2.0. It’s a decent selfie cam, with ‘Smile Capture’ mode setting off a three-second timer when you smile. I found image and video quality was more than enough for daily needs.
AndroidPIT oneplus 3 8036
The front-facing camera is very decent. / © NextPit
OnePlus 3 battery
The OnePlus series has always had decently-sized batteries. The OnePlus One has a 3,100 mAh unit, while the OnePlus 2 had 3,300 mAh of capacity. But there is a slight regression with the OnePlus 3, which has only 3,000 mAh. This is a normal size if you go by this year’s flagship cohort, but it’s strange that OnePlus decided to cut here.
I benchmarked the OnePlus 3 battery using AnTuTu’s battery tester, and it performed slightly worse than the Galaxy S7, but better than the HTC 10, both of which have 3,000 mAh batteries. But the OnePlus 3 does have a large display to power, so sticking with Full HD resolution might be one of its saving graces during a time when QHD displays are becoming more common.
oneplus 3 battery benchmark
OnePlus 3 battery life is satisfactory. / © NextPit
Above you can see the benchmark score of 5891. I found battery life to be relatively good, but I was charging it once a day with regular use. This phone is powerful and does chew power when you push it during gaming and YouTube sessions.
Marshmallow’s battery management capabilities, ported into OxygenOS 3.1.1, do help during idle, and Dash Charge makes the recharging process less annoying. As I mentioned in the Special Features section, you can juice up the OnePlus 3 to 50 percent capacity in less than 30 minutes.
OnePlus 3 technical specifications
OnePlus has iterated on a compelling formula for three years now. The OnePlus 3 doesn’t differ from what made its predecessors great; there are upgrades to the hardware each year, upgrades that all manufacturers employ, and sooner or later we buy in. However, this is the first time OnePlus has made a phone with enough design restraint, a smooth enough build of Oxygen OS, so as to be palatable to both tech and non tech-savvy consumers.
This is, for the moment, an unbeatably powerful smartphone. But it’s also well-built enough that this doesn’t even matter. Battery life isn’t outstanding but, then again, not many phones can do much better than daily charging. The camera is good, but it’s not fantastic. If you want to best photos, this is the wrong phone. This is also the wrong price.
But for $399, you’re getting a lot. The OnePlus 3 offers performance, design and value that few manufacturers can beat. Whether or not it’s upgrade time for you, it’s clear that OnePlus is beginning to settle down as it aims for a more mainstream customer segment. And while it has flaws, the OnePlus 3 is a reliable, refined handset offering a feature-set that’s hard to match.
UPDATE: Since the release of the OnePlus 3T in November, we've amended our overall score of the OnePlus 3, changing it from 4 stars to 3.5. The OnePlus 3 is still a good phone, but the hardware improvements of the OnePlus 3T make it the better phone for only $39 more. See our full review of the 3T for more details.
OnePlus 3 - where to buy?
Go to comment (42)
42 comments
  • C. K. 1
    C. K. Oct 23, 2016 Link to comment
    I currently own the OPO3 , I like it but there is a part of me willing to give up some of the latest specs to just test out the Nexus 6p, for one reason, the larger screen alone, that's about it. I believe cameras between the 2 are pretty much equal. I have been happy w the opo3 camera so far and I really like the phone. Just not sure the Nexus 6p can last me 2 years as I need current phone to do. With the OPO3 I think it will easily as my OPO lasted 27 mths before selling but no need for 2 handsets. Tuff decision as my 3 is just a month old but the 6p looks nice but is a generation behind in gpu, and snap 810.
  • Mel ARY 2
    Mel ARY Aug 15, 2016 Link to comment
    HAI there, need your opinion on zenfone 3 (4G) VS ONE plue 3, which 1 is better in gaming, battery, processor, speed , durability , and price.. because im using S3 now.. i need phone for long term use.. thanks!!!
  • Sherzod Abdujabborov 14
    Sherzod Abdujabborov Aug 10, 2016 Link to comment
    Tech specs aside, OnePlus team deserves a lot of kudos for building up a solid reputation and demand for their phone. Their marketing and product teams did a great job.
    storm Jul 23, 2016 Link to comment
    And yet another USB C port that doesn't meet USB 3.1 standards. Is it another junky cable too?
    Luis Salvatore Jul 21, 2016 Link to comment
    This phone is starting to grow on me... I kind of want it, but then again, as others have pointed out: no damn SD card slot.
    Vinicius. G. Romero
    • C. K. 1
      I have owned 2 OPO devices the original and now the 3, both times the 64gb storage is more than adequate. Not once have I run into issue of space. I find the more space the more junk you load and store , apps upon apps that are useless. Figure what you need and when done w movies you may have brought for a trip or music delete it and reload new stuff. 64gb is plenty but that's my opinion.
    peter Jul 21, 2016 Link to comment
    It is very powerfull machine ,but I miss micro card to extend the memory
    Vinicius. G. Romero
    • Omar Hamwi 17
      Omar Hamwi Jul 21, 2016 Link to comment
      I agree and wish it had microSD support. But after living without it, I also realized that 64 GB is plenty of storage. Any more and I'd never bother backing up my data and probably forget what was in there...
      Luis Salvatore
      • Vinicius. G. Romero 15
        Vinicius. G. Romero Jul 24, 2016 Link to comment
        To be fair, your statement is incorrect. Especially for us that still download music as mp3 and mp4 files, also while stocking up on other things.
        But I believe that more modern people, like yourself, will be fine without an SD card since nowadays we live in this "Cloud Storage" world.
  • slitherioworld 1
    slitherioworld Jul 21, 2016 Link to comment
    well well, oneplus is good but S7 E is better
    • Stephen Sawyer 1
      Stephen Sawyer Jul 21, 2016 Link to comment
      And hundreds of dollars more, but you are actually incorrect, the OP3 is faster in every speed test
    alexis gurrola Jul 21, 2016 Link to comment
    I differ on the "need two hand to use the finger print sensor" I configure mine the same way I would hold my phone with one hand (with my fat thumb) and it's super fast and super reliable. I don't need to hold it with two hands to unlock my oneplus 3.
    I agree that battery life is really disappointing... I barely made it to sunset with a 5-15% charge on a regular to light usage of my phone...
  • justin bergmans 1
    justin bergmans Jul 17, 2016 Link to comment
    I'm not certain where your unit went wrong with the camera. It's a great performer, even in tricky lighting. Focusing is faster than the Nexus 6P and image quality is on par with either the 6p or S7.
      Luis Miguel Méndez González Aug 24, 2016 Link to comment
      What about battery life?
    Adam-Tom Jul 6, 2016 Link to comment
    I got news that the Oneplus 3 will feature Android N. I am curious about when will the phone be available. I just bought an affordable Android 6.0 smartphone, Bluboo Maya and then will use this Android M OS first.
    mohammed ali Jun 24, 2016 Link to comment
    How do we use multiwindow options in one plus three...
    Thomas Roscoe Jun 22, 2016 Link to comment
    Well, I definitely agree that OnePlus may have been really studying the HTC 10's design for their 3rd phone. Personally, I don't like the design unfortunately, add to that the bulky camera module at the back. Hardware-wise though versus.com/en/oneplus-3-vs-htc-10 , they're very similar for the most part, but the OP3 is still better with a higher resolution QHD as opposed to the FHD of OP3. an external memory slot is present as well, and some other minor advantages. Though with the price of 400USD, the OP3 is hard to resist.
    Zohaib Shaikh Jun 19, 2016 Link to comment
    It’s about time for a smartphone without compromises. A smartphone conceived and built by tech enthusiasts, hand-in-hand with users.
    A smartphone born from amazing technology, design, and innovation.
    It’s about time for the OnePlus 3.
    *Moderator's note: comment edited due to violation of community terms.
  • Lars Sjöberg 1
    Lars Sjöberg Jun 17, 2016 Link to comment
    What about sound quality and volyme in the headphone output? Obviosly that also depends on the quality of the headphones themselves, but I want the volume to be as loud as possible when training in the gym since my hearing is a little impaired....today I use a LG G3 with sennheiser headphones.
      Stephen E Jun 21, 2016 Link to comment
      Lars, I listen to music at work between taking calls on my sennhisser earphones, volume is poor compared to my old nexus 5, I also use when up against noise from construction sites and london traffic while walk ing and volume isn't up to standard. Plus my touch screen doesn't work consistently , one area is particularly poor , so it's going back for refund. Such a shame
Show all comments
