need help wid adobe flash player
irfan ali
  • Forum posts: 8
Mar 15, 2011, 7:01:28 PM via Website
hi,i install few apps to watch live tv n films.but this apps asking me to install flash player.so how cn i download flash player thnx
Douglas Carter
  • Forum posts: 1,891
Mar 15, 2011, 7:06:07 PM via Website
You need a phone that has Android 2.2 installed on your phone to use adobe flash player.
— modified on Mar 15, 2011, 7:08:41 PM
Recommended reading for new AndroidPIT members! Important to all community members: the AndroidPIT Forum rules
irfan ali
  • Forum posts: 8
Mar 15, 2011, 7:08:56 PM via Website
so how can i check that i got Android 2.2 installed on my phone.
Douglas Carter
Mar 15, 2011, 7:13:50 PM via Website
Go to settings, phone info, and scroll down to where is says "Android version"
irfan ali
  • Forum posts: 8
Mar 15, 2011, 7:42:27 PM via Website
mine is android version 2.2.1
Douglas Carter
Mar 15, 2011, 8:37:13 PM via Website
Good. Go to the android market and search for "Flash Player" and install "Flash Player 10.1" from the developer called Adobe Systems
irfan ali
  • Forum posts: 8
Mar 16, 2011, 6:12:51 PM via Website
hi, i did type flash player on search and its not come Flash Player 10.1.only came is adobe flash showcase
Douglas Carter
Mar 17, 2011, 12:51:57 PM via Website
Okay, I just researched this topic a little more and apparently the HTC Wildfire will not support Adobe Flash or Live Wallpapers, even though it has Android 2.2. This is likely because of the phone's weak processor and possibly the small display resolution. The app is specifically made to be unfindable for Wildfire users. If you can return and exchange your phone still, I'd recommend it.
Eva Ingram
Mar 19, 2011, 2:36:36 AM via Website
I have a colby kyros 70154G phone system 1.6 with one build update to 2.1 version you dont need to have a 2.2 version. Just intall firefox browser first,
the install Opera mini 5/Opera soft flash 10.1 player and your set to go this is a google verson comperable to adobe flash. both apps are free.
sneha
  • Forum posts: 3
Mar 20, 2011, 11:59:17 AM via Website
hi
im trying to install adobe flashplayer 10.1 . but im unable to install . could u please guide me how to do...
Thanks in advance.
ireneL
  • Forum posts: 114
Mar 20, 2011, 3:00:26 PM via Website
sneha
hi
Thanks in advance.
Hi there sneha, heres a thread that justjay have on how to install flash.
https://www.nextpit.com/en/android/forum/thread/401277/How-To-Install-Flash-10-1-On-Android-2-1-Eclair-Devices
If that don't work, try what eva did, see if that route is for you...
"RE: need help wid adobe flash player
created on Mar 18, 2011 8:36:36 PM
the install Opera mini 5/Opera soft flash 10.1 player and your set to go this is a google verson comperable to adobe flash. both apps are free."
Goodluck.:grin:
English is my second Language :-)
Eva Ingram
Mar 20, 2011, 4:24:51 PM via Website
depending on the OS system your running you can if you have 2.1 you can install Opera Mobile which is the equivlent of Adope Flash 10.1 if it tells you you cant
if it doesnt load let me know you may have to install an additional browser and alternate between internet explorer and the additional browser.
sneha
  • Forum posts: 3
Mar 25, 2011, 7:49:47 AM via Website
Hi,
Could you please help me .. Im unable to see live streaming due to adobe flash is not there.
Douglas Carter
Mar 25, 2011, 6:38:27 PM via Website
Have you tried installing Opera Mobile like another community member suggested? If that didn't work, then I believe you are out of options besides figuring out how to root and ROM the device.
vikram bhatia
Feb 28, 2012, 8:14:21 AM via Website
how can run movie
Aaron Tilton
  • Forum posts: 834
Feb 28, 2012, 10:44:33 AM via Website
What do you mean? How can you play media files? You should be able to download them or load them onto your handset and then just open them. What are you trying to view?
Android News I Android Apps I > App Center
jakson Robert
  • Forum posts: 64
Mar 16, 2012, 11:53:25 AM via Website
thanks for sharing
