Hello guys on androidpit! I'm new here and i already like the community so i hope you can help me out. I already asked the same thing on another forum but then i seen that the forum where i previously asked is dead so i thought let's not waste any time and go to a better forum so here i am!
I hope you can help me with my problem.
My problem is the following thing:
I was having some problems with my play store so i wanted to reinstall it.
So uninstalled Google Play Store with root but the problem is that i couldn't install it again.
(And i only make backups of my boot partition because i don't have so much space to backup data in twrp.)
When i try to install play store again with the latest apk of it then it just crashes. I also tried installing it as system by moving it to /system/app with the correct permissions but still not working. And i also tried it on /system/priv-app but it just disappears there.
I found out that if i use a old version of the play store (9.8.07) then it doesn't crash right away. But i still cannot use it properly. It crashes when trying to install something.
I also found out that if i try to uninstall something with this old version then it doesn't crash right away but it says "uninstalling" forever.
So i think it may be that play store didn't get the permissions that it needs?
I tried so many things but i just don't know how i can fix it. I don't want to do a factory reset or something like that.
Please help me. I just want my good old play store back.
I can't even use YouTube. It doesn't allow me to use it without play store. This is much worse than I thought it would be.
And please a solution where i don't need to factory reset my phone.
(SM-N920C, Samsung Galaxy Note 5, Nougat 7.0 Stock Rom, Rooted with Magisk, Xposed is installed, TWRP is installed)
— modified on Dec 22, 2018, 12:11:15 PM
