- Forum posts: 32
Aug 14, 2018, 12:11:09 PM via Website
Aug 14, 2018 12:11:09 PM via Website
LG Flash tool is specially designed for flash stock ROMs and custom ROMs on LG smartphones. The latest edition is supported KDZ files larger than 1 GB. Try this simple step guide on your beloved LG smart device.
- Download and install LG USB Drivers and Download LG Flash Tool 2018
- Then boot your LG smart device to download mode
- Then build a connection between Windows Computer
- Copy the KDZ files to Downloaded
- flash tool folder commence the program and fill all the fields
asked by the program - It will manually start the flashing process wait until it displays 100%
Congrats you made it. Hope this step guide will help you to flash your LG device perfectly.
