Google Nexus 5 — LG Nexus 5 - Overheating, Battery drain.
minun
  • Forum posts: 3
Feb 14, 2018, 9:09:21 AM via Website
Starting a month and half ago my LG Nexus 5 would get hot near the camera (Where the CPU is) and drain the battery unusually fast, even without an active app opened, now I can not keep it on outside because of the drain and even if it stays connected to a charger, it slowly builds a charge because of the drain.
I recently changed the battery and the problem continues to persist.
This started happening around when I went over all the settings in the phone and apps, I fear I might of turned on something that is causing it in the background but I can not figure out the exact problem.
Please help.
Bastian Siewers
  • Forum posts: 9,729
Feb 14, 2018, 9:35:40 AM via Website
Hi minun,
welcome to AndroidPIT! :)
Have you tried a reset? A reset regularly helps with issues like this one.
Liebe Grüße, Bastian
Die Regeln | Die Moderatoren und Admins | Screenshots richtig posten
Helpful?
minun
  • Forum posts: 3
Feb 14, 2018, 9:40:42 AM via Website
Do you mean factory reset? That is my last resort so I haven't yet.
Helpful?
Honor UAE
  • Forum posts: 16
May 21, 2019, 9:35:59 AM via Website
Google nexus 5 is an amazing smartphone from google and many people like to use this smartphone. I will recommend you to get some more options from market for this battery drain problem.
Helpful?
lasarka3
  • Forum posts: 11
Nov 17, 2020, 10:27:47 AM via Website
I had the same phone, and with time, the same problems appeared. The battery used to die in 2 hours, and the phone was very hot even in winter. I love Nexus, but I had to buy Samsung Galaxy. This Android does not have problems like Nexus.
Helpful?
