I know this is probably a stupid question, but here goes it. Will disabling some apps help with my memory? Thank you to anyone for their help.
Apr 21, 2017, 9:32:31 AM via Website
Apr 21, 2017 9:32:31 AM via Website
Yes but they do not affect the RAM. By disabling the apk it will be restored to default . Disabling apps doesn't mean deleting them it is just hidden from the apps.
Ready To Help You.
Apr 21, 2017, 12:33:32 PM via Website
Apr 21, 2017 12:33:32 PM via Website
Thank you very much.
For Android phone , the Android Assistant, and Android Manager that you can install
I don'e know what trouble that you meet ? if you just misssing phone data , you can check your backup files , if the lost data has stored in the backup files , you can enter it to get back them
Sometimes you can clean your phone and delete the useless files. Download a manager or some program like that will be helpful.
