Easy way to control Android phone on PC
DROIDLILP
  • Forum posts: 16
Dec 29, 2016, 8:47:56 AM via Website
34341
Sometimes you may be bothered by messages from your phone when using the computer, especially when need to reply the message by typing words back. As the phone and PC are meant to make life easier, is there any way to integrate those tools and enable us to control every details of phone on PC? It’s time to introduce our reliable assistant: ApowerMirror.
5555
When connect phone and PC via USB wire or Wi-Fi, the tool can mirror phone screen to PC and enable you to click on the casted phone screen to manipulate the Android phone directly. The steps to use this tool is simple, just follow the tutorials below:
  1. Download and install it on PC, then open and preset display quality
    http://download.apowersoft.com/down.php?softid=apowermirror
  2. Connect with USB wire, then allow “USB debugging” on your phone, then the program will be installed on the phone automatically. If it fails, please download from Google Play.
    https://play.google.com/store/apps/details?id=com.apowersoft.mirror
  3. While the phone screen is mirroring on your PC, you can fully control the device by PC.
There could be more circumstances to use it than you can imagine, take the following usages as example:
1. Type message on the phone by keyboard
When finished the steps to enable control from PC, you can input message by keyboard. Just open the app from PC, then click on the message area, choose input method and start typing. You may click the emoji bar to select and press “Enter” to send out.
You can also press "Ctrl" plus "C" to copy words from computer and then paste to the message box to send out the message.
coolbackground
2. Play Android games by PC
Let’s take Clash Royale as example, when finished those steps to connect, then you may click on the screen to play the game. To cast system sound of the phone to PC, you can use cast function or download Google Home to connect Android phone with computer. You can also record video and take screenshot of the phone screen in order to save wonderful moments.
452
— modified on Dec 29, 2016, 8:56:45 AM
Bobby IncGloridaPakRayonDeactivated Account
