Problem with Samsung Tab 3 screen
gustavo woltmann
Nov 12, 2016, 3:23:13 AM via Website
Hi I am Gustavo Woltmann from Panama, been having problem with my Samsung tab 3 that whenever I adjust the screen's brightness, the tab restarts. What can I do to solve it?
Adam LaPrade
Adam LaPrade
  • Forum posts: 27
Nov 12, 2016, 4:25:54 AM via Website
Have you tried Factory resetting? You could have a virus or some type of bug. My tab 3 never did this.
James Watson
  • Forum posts: 1,607
Nov 12, 2016, 6:08:14 AM via Website
Is it maybe some hardware problem? :(
Try to get contact with customer service of your device supplier, please.
SamiJulie
  • Forum posts: 21
Nov 15, 2016, 8:44:44 AM via Website
Maybe you can try to enter recover mode to solve your problem. If it still can't work, you may flash your device or carry it to the repair shop to get it fixed. Here is a guide you can boot Android phone into recovery mode.
— modified on Feb 14, 2017, 7:37:11 AM
Achint J
  • Forum posts: 10
Nov 15, 2016, 2:57:07 PM via Website
Hi Gustavo,
Did your problem resolved ?
(thinking)
Sundarsun 2527
  • Forum posts: 39
Nov 17, 2016, 2:58:57 PM via Website
Well i also has a problem with my Samsung galaxy s3, after that i contacted customer supportfor the particular reason. They resolve my problem.
Then i asked the reason for it, they told some technical problem in the mobile
Max George
Sep 13, 2017, 6:53:56 AM via Website
Did you try a factory reset?
You can do this from the Android Recovery Menu (this will erase all your personal data!!!)
Press and hold both the "Volume Up" and "Power On" keys until you see the Android logo.
Use the "Volume Up" and "Volume Down" keys to navigate through the menu, and use "Power On" for OK.
Choose "wipe data / factory reset", then "yes erase all data," and finally - reset.
Teppy Tomy
  • Forum posts: 9
Sep 13, 2017, 7:34:51 AM via Website
I take away the warranty.
