- Forum posts: 2
Nov 14, 2014, 8:15:13 AM via Website
Nov 14, 2014 8:15:13 AM via Website
Here is a typical daily usage shot of my phone. Whenever my screen is on, my battery goes bye bye. Please help me fix this
Nov 14, 2014, 2:22:01 PM via Website
Nov 14, 2014 2:22:01 PM via Website
Brandon McCann
Here is a typical daily usage shot of my phone. Whenever my screen is on, my battery goes bye bye. Please help me fix this ![image][1]![image][2]
[1]: https://fscl01.fonpit.de/userfiles/6884526/image/Screenshot_2014-11-14-02-12-48.png
[2]: https://fscl01.fonpit.de/userfiles/6884526/image/Screenshot_2014-11-14-02-12-41.png
15 hours of battery backup is good...
you can clear cache from recovery to clear junks
— modified on Nov 14, 2014, 2:22:17 PM
Ready To Help You.
Well, @Brandon McCann I must agree with @Sanjai over here you are getting good backup out of your device. I can't think of keep myself switched on for more than 10 hours ! any as far as the poeer decreasing fast with the screen on is just okay becuase with every smart device the most battery consuming piece is display and this is what's happening with your device when you keep it switched on continously it decreases at a faster rate any way I would say in order to reduce this fall, you can dim the brightness of your device to lower levels or better option would be setting it to auto mode, trust me it will help you in saving more juice out of your battery !
— modified on Nov 15, 2014, 8:06:24 PM
Nov 16, 2014, 7:10:26 AM via Website
Nov 16, 2014 7:10:26 AM via Website
Yeah 15 hours may look good, But screen on time isn't reaching 2 hours at all. Your screen has to be on in order for you to use your phone! My brightness is set pretty low it's below half brightness. I have greenify to help close all of my apps after I use them, just seems to me that my battery should be doing better than this with a huge battery that's in the note 3. And did you notice how my battery went up without charging it at all? Can anyone explain that? Haha thanks for the help people
