Help to fix errors of Audio music player !
José António Melo Moreira
  • Forum posts: 4
Feb 28, 2021, 11:31:18 AM via Website
Hello good morning for everyone I´m a beginner on the Android Studio, and i need a help for you to place well the app, that means working perfectly. It´s a good app, and it could serve me as a example to understand its funcionality.
I´m building an audio music player app., but on my MainActivity.java file ,
In the code i faced with some mistakes, see below the images that i sent you. How could you fix them?
MainActivity.java
package com.example.musicaudioplayer;
import androidx.annotation.NonNull;
import androidx.annotation.Nullable;
import androidx.appcompat.app.AppCompatActivity;
import androidx.core.app.ActivityCompat;
import androidx.core.content.ContextCompat;
import androidx.fragment.app.Fragment;
import androidx.fragment.app.FragmentManager;
import androidx.fragment.app.FragmentPagerAdapter;
import androidx.viewpager.widget.ViewPager;
import android.content.Context;
import android.content.pm.PackageManager;
import android.net.Uri;
import android.os.Bundle;
import android.provider.MediaStore;
import android.widget.Toast;
import com.google.android.material.tabs.TabLayout;
import java.util.ArrayList;
import java.util.jar.Manifest;
public class MainActivity extends AppCompatActivity {
public static final int REQUEST_CODE=1;
ArrayList<MusicFiles>musicFiles;
@Override
protected void onCreate(Bundle savedInstanceState) {
    super.onCreate(savedInstanceState);
    setContentView(R.layout.activity_main);
    permission();
    initViewpager();
private void permission() {
    if(ContextCompat.checkSelfPermission(getApplicationContext(), Manifest.permission.WRITE_EXTERNAL_STORAGE)
    != PackageManager.PERMISSION_GRANTED) {
        ActivityCompat.requestPermissions(MainActivity.this, new String[]{
                        Manifest.permission.WRITE_EXTERNAL_STORAGE}
                , REQUEST_CODE);
            else
        Toast.makeText(this, "Permission Granted!", Toast.LENGTH_SHORT).show();
        musicFiles = getAllAudio(this);
@Override
    public void onRequestPermissionsResult (int requestCode,@NonNull String[]permissions,
                                            @NonNull int[] grantResults){
    super.onRequestPermissionsResult(requestCode,permissions,grantResults);
    if (requestCode==REQUEST_CODE)
        if(grantResults[0] == PackageManager.PERMISSION_GRANTED){
              //Do whatever you want permission related
                Toast.makeText(this, "Permission Granted !", Toast.LENGTH_SHORT).show();
                musicFiles =getAllAudio(this);
            else
                ActivityCompat.requestPermissions(MainActivity.this, new String []{Manifest.permission.WRITE_EXTERNAL_STORAGE,
                        REQUEST_CODE);
private void initViewpager(){
    ViewPager viewPager =findViewById(R.id.viewpager);
    TabLayout tabLayout = findViewById(R.id.tab_layout);
    ViewpagerAdapter viewPagerAdapter = new ViewpagerAdapter(getSupportFragmentManager());
    viewPagerAdapter.addFragments(new SongsFragment(), "Songs");
    viewPagerAdapter.addFragments(new AlbumFragment(),"Album");
    viewPager.setAdapter(viewPagerAdapter);
    tabLayout.setupWithViewPager(viewPager);
public static class ViewpagerAdapter extends FragmentPagerAdapter{
    private ArrayList<Fragment> fragments;
    private ArrayList<String> titles;
    public ViewpagerAdapter (@NonNull FragmentManager fm){
        super(fm);
        this.fragments = new ArrayList<>();
        this.titles = new ArrayList<>();
    void addFragments (Fragment fragment, String title){
        fragments.add(fragment);
        titles.add(title);
    @NonNull
    @Override
    public Fragment getItem (int position){
        return fragments.get(position);
    @Override
    public int getCount(){
        return fragments.size();
    @Nullable
    @Override
    public CharSequence getPageTitle(int position){
        return titles.get(position);
public static ArrayList getAllAudio(Context context){
ArrayList tempAudioList = new ArrayList<>();
Uri uri= MediaStore.Audio.EXTERNAL_CONTENT_URI;
String[] projection = (
        MediaStore.Audio.Media.ALBUM,
        MediaStore.Audio.Media.TITLE,
        MediaStore.Audio.Media.DURATION,
        MediaStore.Audio.Media.DATA, // FOR PATH
        MediaStore.Audio.Media.ARTIST,
    Cursor cursor = context.getContentResolver().query(uri, projection, null,null,null);
    if (cursor!=null)
            while(cursor.moveToNext())
            String album = cursor.getString(0);
            String title = cursor.getString(1);
            String duration = cursor.getString(2);
            String path = cursor.getString(3);
            String artist = cursor.getString(4);
            MusicFiles musicFiles = new MusicFiles(path, title,artist,album,duration);
            //take log.e for check
            Log.e("Path: " + path, "Album : " + album);
            tempAudioList.add(musicFiles)
            cursor.close();
    return tempAudioList;
James Watson
  • Forum posts: 1,605
Mar 1, 2021, 4:33:06 AM via Website
What's wrong with your code? ......(smug)
Helpful?
  • Forum posts: 4
Mar 1, 2021, 8:48:27 AM via Website
Hello James, good morning.
Replying your question of the forum it´s difficult to me answer correctly on the forum, because i tried to send images files and the NextPit don´t allow to send this format.
If you remember i sended the following message to the forum (see below):
So I could you send me your email, to send you all the code and the error images associated.
My email is: Josemmoreira1@gmail.com.
What´s your email?
Best regards
José Moreira
Helpful?
