Problem with Our Android App - Help Required
Dehaat Store
  • Forum posts: 4
Sep 26, 2018, 9:13:03 PM via Website
Hi,
We have an android App for our e-commerce business.
while using the app as a guest, it is working perfectly.
But after registering on the app, many of the product categories shows "Zero Product"
Can some one help us in solving the problem?
Link to the App: Dehaat.Store : गाँव का शॉपिंग मॉल :Online Shopping (On google Play Store)
Before giving us any random quotes, we request you to first analyse the problems in the app's user interface and then offer us your best quotes and time lines with the solution.
Reply awaited
Gennaro Diego
  • Forum posts: 10
Sep 27, 2018, 12:02:37 AM via Website
Hi,
Are you sure with the problem is Android?
The app load database by Website (PHP or other)?
Helpful?
James Watson
  • Forum posts: 1,607
Sep 27, 2018, 7:00:41 AM via Website
Does your APP connect to same database server for logined users and guests?
Helpful?
Dehaat Store
Dehaat Store
  • Forum posts: 4
Sep 27, 2018, 9:46:40 AM via Website
Thanks for the reply.
We are Not sure whether it is with Android or website problem.
The Freelancing person who developed the app has shifted abroad for his job.
Earlier when we had lesser number of products, there was no problem in the app. But as the number of products have grown up, this problem has started.
That is why, we asked to check the app, if some one can understand the problem and offer us the solution, time frame and pricing, we can initiate the contact.
Helpful?
Dehaat Store
  • Forum posts: 4
Sep 27, 2018, 9:48:57 AM via Website
Dear James,
App connects to the same database for both guest and registered users.
Helpful?
James Watson
Sep 28, 2018, 1:31:05 AM via Website
ls it possible that a database connectIon error occured then due to a concurrent connection limit about license control or poor performance of the db server?
(nerd)
Helpful?
Dehaat Store
  • Forum posts: 4
Sep 28, 2018, 11:43:07 AM via Website
Hi James,
Can you solve it? if yes, How much would you charge for it and how long would you take to resolve it?
Helpful?
Gennaro Diego
  • Forum posts: 10
Sep 28, 2018, 8:35:48 PM via Website
Hi Dehaat store,
with minimal information and without website PHP/mysql and android code... I think it very hard found the problem and calculate a price for solve the issue. (thinking)
Helpful?
