Last time,my Huawei phone meet the same case.I did below steps:
1.The phone is completely turned off first, then press and hold the volume down button, then press the power button until the screen lights up.
2.On the screen is the android robot and a warning exclamation mark. At the same time, press the volume plus or minus button to display the operation interface. In the recovery interface, the volume up and down keys are controlled up and down, and the power button is confirmed.
3.In the Recovery interface, press the volume down key to select wipe data/factory reset, then press the power key to confirm, then select Yes-delete all user data, press the power key to confirm.
4.In the Recovery interface, press the volume down button to select the wipe cache partition, then press the power button to confirm, then select Yes-Wipe Cache, press the power button to confirm.
5.After you finish, return to the recovery main interface, then select reboot system now to restart the phone.
