Camera problems with the Samsung Galaxy S7
Don Holt
Jun 19, 2016, 12:16:25 AM via Website
My camera app quit working. I have done a software update, a hard restart and everything else I can find to try but still camera does not work.
I purchased my phone from Verizon and the best they will do is take my phone get a factory replacement but I can not do without my phone for a couple of days, I use it for work.
Any help is appreciated.
pentel
  • Forum posts: 251
Jun 19, 2016, 2:41:56 AM via Website
Don Holt
To get the best help possible, you need to describe what is not working with the Camera app. Is it a software issue, or hardware or lens issue? A screenshot would help to understand the problem.
You actually have found the ideal solution: a replacement phone from Verizon. Accept the offer, you want a working phone and not a defective one.
This is where you need a backup phone. Get yourself a cheap unlocked phone from Staples or Walmart, etc. Costs under $100. The Android Blu phones are relatively inexpensive. Make sure the phone uses a micro-SIM card which the Samsung S7 uses.
James Watson
James Watson
  • Forum posts: 1,608
Jun 19, 2016, 6:34:15 AM via Website
What pentel said is a good solution.
— modified on Jun 19, 2016, 6:41:13 AM
